xhp90 cheap chinese torches
19 posts / 0 new
forsh
Last seen: 14 min 32 sec ago
hi guys,new to the forum, been watching mat smith videos on your tube and desided to try mod hack my cheapy flashlight
does anyone know if its possible to use the chinese xhp90 type flashlights as a host
i think its a copy of xanes 1909 or something
https://www.aliexpress.com/item/32853466606.html?src=bing&albslr=2210010...
its this style
best wishes from finland
polarweis
polarweis's picture
Last seen: 13 hours 52 min ago
If you mod lights you want a well build host that can handle heat. I wouldnt spend to much money on modding something like that light you mentioned. A good starting point is a convoy c8+ or a s2+.
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
forsh
Ok I’ll research into the convoys
Thanks pal
djozz
djozz's picture
Last seen: 7 hours 36 min ago
Always good to start with Convoys, it saves you years of struggling with poor designs.
power911
power911's picture
Last seen: 17 hours 39 min ago
with convoy m3 we can even skip the modding part Big Smile
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
“Humans m
Funtastic
Funtastic's picture
Last seen: 9 hours 2 min ago
The M3 isn’t that good. Good quality, very bright but that is very short lived. The temp limit is too low and the brightness drops from 100% to a low 30% without anything in between
Texas Ace Lumen Tube calibrated with maukka lights
forsh
just ordered the c8+
but found there was 2 firmware modes
4mode and ramping
i ordered ramping, did i order good ?
what things can i do with the c8+?
thanks so much guys for your input
best wishes from finland!
olympus620
Last seen: 10 hours 27 min ago
I bought one of these a few weeks ago from another vendor who claimed he was selling me an XHP90 for $22.00. After receiving it and measuring the LED it only measured 7mm. I cannot find a comparison photo so I don’t know if I was sold an XHP70, SST70 or something else. Tail cap current only measures 1.7volts.
It would be nice to know if I could stack a resistor or two so it doubles as a hand warmer. It has an underutilized AOD480-30V N-Channel MOSFET.
forsh
Mine was a fake xhp
It’s something like a 7070 led , not sure the name but it was quiet bright
I measured the power draw from the tail end and it was 4.5 amps
On 2× 26650 battery’s on full power
Low power was less then an amp
alpg88
Last seen: 3 hours 25 min ago
wow, xhp 90 is out, this is first i hear about it, i must get out more.
p.s. i wonder if cree knows they make xhp90 led, cuz it is not anywhere on their site
forsh
They are not real Cree
It’s some Chinese knock off that they called a xhp90
They are bright but in zoomables
4chip led
I’ll make some pictures and review or something in the coming days
Chris
alpg88
4chip led
Chris
thanks, i figured that much, looked all over cree sites, found no mention of xhp90.
Skylight
Skylight's picture
Last seen: 14 hours 22 min ago
If Cree launches the XHP90 the chances are high that you will find a thread on BLF first. Wink
I assume the XHP70 is much more efficient with a better color rendering than all of these 7070 or XHP90 clones.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 7 hours 8 min ago
Yea don’t buy from Brett store on Aliexpress.
http://budgetlightforum.com/node/66447
olympus620
alpg88 wrote:
wow, xhp 90 is out, this is first i hear about it, i must get out more. p.s. i wonder if cree knows they make xhp90 led, cuz it is not anywhere on their site
Your sarcasm was well received alpg88. As P.T. Barnum said, “There’s a sucker born every minute”. My post here wasn’t my first stroke of ignorance either. I requested a refund from the user on Ebay and included the specifications of 9mm for the ghost Cree XHP90. I included an image of my led with a micrometer display showing 7mm and explained the “XHP90” should measure 9mm. I feel like an idiot however, the good news is that my insistence on the CREE XHP90’s existence won me a refund. you have to fight fire with fire. lol
https://www.ebay.com/itm/184004426295
alpg88
i was not really sarcastic at first, at first i even thought they really made the led, then i started looking for datasheet, and then i realized it was just a name of none cree led.
rngwn
rngwn's picture
Last seen: 6 hours 22 min ago
Sounds like modding opportunity for me if the driver supports 12v version Wink
Though the build quality can be a concern.
Searching for High CRI leds since 2010...
Has finally gotten to the bottom after 10 years of delving deep into that rabbit hole of them high CRI lights...
High CRI, high quality lights doesn't need to be expensive, or is it?
forsh
Heat transfer is bad , it’s aluminium and painted where the pill should be , mods can be done with some major overhaul
Yokiamy
Yokiamy's picture
Last seen: 8 hours 58 min ago
Removing the NTC solves that problem
