Looking for a Flicker-Free 20W CC-Driver
6 posts / 0 new
Zelda
Zelda's picture
Last seen: 5 days 4 hours ago
I search a replacement constant current driver for a new fixed lamp.
The stock driver is flickering with 100 Hz Facepalm (Philips myLiving LED Spot Worchester 4flg. 5056411P0)
Specification:
Current: 350 mA
Max width: 68mm
Max length: 165mm
Max height: 27mm
Required voltage @ 350 mA: 50V
A lot of “documented” flicker-free driver are available only at 75w or above.
Some expensive DALI-Drivers are flicker-free, but the width is too large.
I own a flicker-free driver (Self SLT20-350IFG), which would have been within the required specs, but I hear a 50 Hz buzz Flat Stare
Can someone recommend me a driver?
(A CC driver with 700 mA and 25 V, should also do the job. I can connect the LED’s to a 2p2s configuration)
Edited by: Zelda on 01/16/2020 - 17:09
bobflux
Last seen: 3 weeks 6 days ago
Meanwell APC-25-350 – a bit too thick but specifies low ripple so should be flicker free
PLM-25-250 – I think this one would fit, but probably not flicker free
IDLC-25-350 – datasheet mentions “flicker free” and specifies 5% current ripple
There are quite a lot of others, not expensive, on meanwell site (link should set proper search criteria).
After you have the reference you want, you can order it from amazon or aliexpress since I don’t think meanwell sells to individuals directly.
Zelda
Zelda's picture
Thank you for the hints, I finally found a small one on amazon. (Eaglerise LS-20-700 LI1)
From an other manufacturer, I found also a small DALI Driver. (HuaTec LS-25M-DALI)
Bocian
Bocian's picture
Last seen: 4 days 10 hours ago
bobflux
Very interesting link Bocian! Thanks!
I’m looking for a similar driver, flicker-free, for 6-10W 36V COB, but… dimmable with 0-10V or PWM, instead of triac dimmable. Basically a cheaper alternative to Meanwell. Got links?
Bocian
Bocian's picture
In my practice, almost all dimmable AC / CC power supplies operate at high frequencies so they are flicker-free.
example
