GT mini Pro
31 posts / 0 new
rost333
rost333's picture
Last seen: 3 days 22 hours ago
GT mini Pro
I found pictures of GT mini PRO on Facebook:
Emitter: Cree XHP50.2 LED
Flux: >3500 Im
Intensity: >57,753cd (ANSI throw >480m)
Firmware: Tom E’s open-source NarsilM v1.2
Driver
29.5W, 9A FET driver with conversion efficiency
that exceeds 90%. Parasitic drain while OFF is-27 uA.
Weight: 150g without cells
Dimensions: 50 mm Ø head x132 mm length
Edited by: rost333 on 02/02/2020 - 19:05
TexasToasted
TexasToasted's picture
Last seen: 10 hours 20 min ago
I wish they had replaced the rubber switch with something better.
Th558
Th558's picture
Last seen: 4 hours 22 min ago
Not that interesting to me. Was expecting a white flat when I saw the word “Pro”. Seems like it’ll be a good light but not for me.
anonymous_user
Last seen: 49 min 12 sec ago
So is Pro going to be new moniker for when Lumintop switches the LED to a XHP50.2?
BOO5TED
BOO5TED's picture
Last seen: 3 hours 53 min ago
Seems that way.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
HONDARIDER
HONDARIDER's picture
Last seen: 6 days 5 hours ago
Can’t find anything on it. The flat white would be awesome in this platform. Maybe in an FT03 also. Might have to make one myself. Also whish the 3v 50.2 would come in some warmer tints.
BobbyRS
Last seen: 2 weeks 2 days ago
So they changed the emitter and switched to a textured reflector and called it “pro”…is that all they did or am I missing something?
Lightbringer
Lightbringer's picture
Last seen: 37 min 41 sec ago
Unno, that’s what it seems like.
Lot more lemons, but also a bigger hotspot.
Intensity gets watered-down per unit area with the bigger die, but I’m guessing that’s where the amped-up number of lemons comes in, to make up for it.
Unno. The regular ‘mini kicks arse, so dunno if I’d “need” a high-strung version of it to throw a bigger disc of light downstream.
BobbyRS
Exactly my thought. Not sure how that constitutes as “pro” imo. “Pro” to me somewhat indicates things like stronger builds, beefed up output/performance, better quality parts, or even slight modifications to the form factor (more tactical looking/feel, different body for alternate larger capacity cells) improved waterproofing, etc.
Lightbringer
I like the ‘mini and ‘micro as-is, so I’m not complaining about the æsthetics or anything. In fact, I quite like them.
Even the button (“too rubbery”, “only half-lit”, etc.) doesn’t bother me.
So… yeah, I’m not sure what a “pro” version brings to the table.
mortuus
mortuus's picture
the switch is awful if the same.. i like the light but the mushy switch is some of the worst of all my lights..
and why does it have OP reflector ? Not sure this makes much sense to me why call it pro? the emitter needs a far bigger reflector imo..
i already have the astrolux ft03 with xhp50.2 so this light im not sure why they even made, did someone ask for it? havent seen any thread that they were gonna make on..
...where Frugal meets with Flashlight!
Lightbringer
Just a guess would be to (try to) smooth out a crappy corona, tint-shift, hole/cross, other nasty artifacts from the new chip if they’re introduced.
EasyB
Last seen: 4 hours 48 min ago
This light with a sliced XHP50.2 would be great IMO. Should be >3200 lumens and ~130kcd at 16A. Of course that is not thermally sustainable, but it would make a nice compact high output thrower.
For the record I have been using some 3V XHP50.2 from kaidomain. They are the 1D tint which they don’t carry anymore, but it turns out really nice when sliced. Nice neutral tint and a bit warmer than a Cree 3D. The corona is of course a bit greenish as you’d expect with the flip chip and side-phosphor, but to me it is not a big deal.
Johnv
Last seen: 7 hours 42 min ago
I wish a new BLF-GT MIDI, like the size of the Astrolux FT03.
With sbt 90.2 emitter would be awesome.
id30209
id30209's picture
Last seen: 8 hours 22 sec ago
I like the ergonomics on mine. I have installed W2 in it and it’s much better than xpl hi.
But i’ll swap for W1 for more current/output.
W2 can get angry blue mortal color if IMR’s are used.
WTB  Jetbeam TCR1  &  Titanium 47 2xAA Quark
nuemtol
Last seen: 1 hour 32 min ago
Johnv wrote:
I wish a new BLF-GT MIDI, like the size of the Astrolux FT03. With sbt 90.2 emitter would be awesome.
sbt90.2 in the ni40 is a little similar
http://budgetlightforum.com/node/69362
mortuus
mortuus's picture
yeah shame they just did a light not many care for..
BobbyRS
Definitely leaves you wondering. I’m just really confused as to why they thought calling it a “pro” version was appropriate here.
Lightbringer
‘Cause “millennium edition” would be kinda dated? LOL
Hugh Johnson
Hugh Johnson's picture
Last seen: 4 hours 33 min ago
Sounds like my kind of light.
LumenMax
LumenMax's picture
Last seen: 1 hour 31 min ago
Thanks for posting my pictures. The complete album is located at https://www.facebook.com/LumenMaxNJ/media_set?set=a.1051829191838554&type=3 .
From the surface, yes, the only changes are:
  • OP Reflector
  • XHP 50.2 domed. 3500 lumens max?
  • Slightly brighter lit button (crescent shaped)
I'll scan through the manuals to see what else is different. I'm working on a groupbuy for the Pro and will start a new thread if it pans out.
metroplex
Last seen: 3 days 10 hours ago
  • OP Reflector
I’ll scan through the manuals to see what else is different. I’m working on a groupbuy for the Pro and will start a new thread if it pans out.
Do you know if the GT Mini Pro is a replacement for the GT Mini? I noticed that Lumintop’s Amazon store no longer lists the GT Mini, but still available on banggood.
justanotherguy
Last seen: 2 hours 54 min ago
I had a GTmini Vn with a white flat I believe. Gave to a friend’s dad
I believe it hit 300kcd….
anyone in NE ILLinois into get togethers?
Coyotehawk
Last seen: 4 hours 15 min ago
Lumintop is losing their touch imo. They gained a lot of hype from the GT project but seems most of what they’ve released since has been “eh”.
shoulder shrug.
Lightbringer
I’d like to see ‘em revive the ED20-T.
I just grabbed a couple shortly before they were discontinued(?), and it’d be killer with something like a more neutral or even warmer CT and nice tint (eg, a LH351), just not some greenie like some/most SSTs. Whatever it’s got now (forgot), it’s not greenish even with AR-coated glass, which is a really nice surprise!
Unique switches and UI, quite nice. Just need to make the damned clip removable, as it gets in my way.
Truth is, it’s hard to distinguish yourself in a market like flashlights where so many are “me too!” designs.
Lightbringer
Come to think of it, while my NW ‘micro is really nice, even the CW ‘micro I picked up later has a nice non-green tint.
Credit where credit’s due…
mortuus
mortuus's picture
shoulder shrug.
I would rather see them make a bigger version of gt mini but smaller then blf gt,, like a 21700 version with 60-70mm head or something.. look at the ft03 and its outstanding throw with the sst20..
mgracia85
mgracia85's picture
Last seen: 3 hours 8 min ago
mortuus wrote:
shoulder shrug.
I second that. Who would have the influence to talk to lumintop? I feel like a lot of people would be interested
I love my wife’s toy poodle
Johnv
BLF GT midi !
Hugh Johnson
So less throw is more pro?
BOO5TED
BOO5TED's picture
Apparently so, it’s more lumens but less throw. “Pro” to me would be better all around. Brighter, more lumens, higher candela, more throw etc……
