Searching a compact thrower
26 posts / 0 new
paetzi
Last seen: 3 days 15 hours ago
Hi, i´m actually searching for a new compact thrower flashlight.
I figured out that the Lumintop GT mini fits pretty good but is there a better flashlight in that size avaiable?
The Astrolux FT03 is to big for me i guess but i like the UI from it that i know from the EC01 that i own.
Thanks in advance.
Edited by: paetzi on 02/13/2020 - 09:26
MoreLumens
MoreLumens's picture
Last seen: 1 hour 43 min ago
I been thinking of Lumintop GT micro. If you could call it as “thrower”, but would be nice to get some more use for my 14500 batteries. I only got Fenix LD12 that uses those right now.
Maybe too small?
SerenityNow
Last seen: 1 day 9 hours ago
Emisar D1? Pretty compact… especially with the 18350 tube. Runs Anduril like the EC01 as well.
aginthelaw
aginthelaw's picture
Last seen: 5 hours 50 min ago
Manker u23, but read about the ui first
never fear shadows…it means a light shines nearby
raccoon city
raccoon city's picture
Last seen: 1 hour 8 min ago
My favorite compact thrower is the BLF-D80v2.
paetzi
I´ve also found that flashlight but i didn´t find any measured values how far it throws or the candela.
nuemtol
Last seen: 8 hours 40 min ago
Lightbringer
Lightbringer's picture
Last seen: 3 hours 15 min ago
P30. It’s different from the ‘mini, so which is “better” is a matter of taste/preference/need.
The ‘micro is even more compact than the ‘mini, yet still throws respectably, so…
MoreLumens
What about BLF X5? Nice lumens, but not sure about range.
Starkm32
Starkm32's picture
Last seen: 5 hours 32 min ago
Check out the D1S, compact ( almost ) enough for edc, and sweet throw.
Kevin Z
Last seen: 8 hours 46 min ago
Discontinued
JaredM
JaredM's picture
Last seen: 2 min 20 sec ago
Another vote for the P30 21700 version. About to get one and try a white flat swap
Starkm32
Starkm32's picture
Too bad it’s discontinued, I feel blessed to own such a sweet light.
(Why discontinue a good small super thrower such as the D1S, I wonder.)
Kevin Z
I’m glad I got one , best looking little thrower bar none .
Pure class.
Enderman
Enderman's picture
Last seen: 1 hour 23 min ago
Acebeam WL10 ?
MoreLumens
Is BLF X6 still available somewhere?
Funtastic
Funtastic's picture
Last seen: 2 hours 3 min ago
It was excellent but I had heaps of them have issues with the off time capacitor causing the medium press not to function correctly
What about the Eagle Eye X6, it’s still sold on AliExpress under another name
Texas Ace Lumen Tube calibrated with maukka lights
tatasal
Last seen: 2 hours 22 min ago
I have some of those lights mentioned above, for me the compact but heavy hitter is this one: Nightwatch NI01L IRAlite Osram White Flat
Take a look at this comparative photos, even versus the FT03 at medium range: http://budgetlightforum.com/node/68465
Yokiamy
Yokiamy's picture
Last seen: 4 min 35 sec ago
Try searching ‘Mezzol’
Edit, i still had one on my wishlist but now the are completely gone
bassoverflow
Last seen: 11 hours 22 min ago
Go for the Lumintop GT Mini and don’t look back.
Kevin Z
You might look back if the on button goes wonky Big Smile
JaredM
JaredM's picture
It really comes down to how ‘compact’ you desire, and if you want a side switch or tailswitch. I personally prefer a tailswitch and super simple UI on dedicated throwers – a lot of times just single mode – and a forward/momentary switch. Once the light is compact enough that it has a chance to actually be pocketed and carried in real life, I start to like having more modes/control.
IMO, these are my favorite throwers by size class (each ~5mm) and switch type (side vs rear). There are some gaps, but these are all lights that I have or consider having..
Side:
ET TX25C2 (32mm dia)
GT micro (36mm dia)
D4Sv2 (39mm dia)
GT mini (50mm dia)
Rear:
Convoy M2 (32mm dia)
D80-v2 OR NS22 Seeker (41mm dia)
C8+ OR M21A (44mm dia)
Nitecore P30 (50mm dia)
Dioda
Last seen: 1 min 59 sec ago
I can recommend Nitecore MH20GT. Very compact and has surprisingly good throw due to deep reflector with XPL HI inside.
paetzi
Thanks for all the help.
I do more like a side switch.
The nitecore is interesting but the price tag is to high for what i would get over the Lumintop GT Mini for example.
I ordered the Lumintop GT Mini and it will replace my Quark Turbo X that is placed in my car and waits for being used.
adnj
Last seen: 4 days 17 hours ago
Agreed.
shane1
Last seen: 2 days 8 hours ago
What are your thoughts on these?
Lumintop GT Mini
Nightwatch NS22 Seeker
Nightwatch NSX3
I only want to buy one thrower for now. Which if the above or an others?
Thanks shane
