i would not bother, there is a chance that you will brick the control board when you cut off power. when it bricks, it is permanent. it is made that way for safety, if there is something abnormal with the pack, board controller kills it permanently, so it doesn’t explode, losing all power is very likely is one of those cases,
20v it is 5 or 10 cells, good quality high current cells are 6-10 each. (then you need tab welder, nickel strips, ……) you can get new oem battery for about 40-50.
I wouldn’t replace individual cells, because (obviously) used cells can be down to, say, 50% capacity, and you’d be replacing the “worst” cells of the bunch with brand new ones.
I’d get cheap but decent cells and just replace the whole pack’s cells if I absolutely had to (eg, if the packs aren’t available anymore).
Usually, I’d just go the other way around, ie, pull the cells, toss the bad ones, and use still-good ones in low-stress lights.
You will need to invest in a battery tab spot welder to be able to build/repair battery packs. Soldering is not a good idea - it is both more likely to damage the cell (heat) and less durable for a tool that is going to regularly experience shocks and vibration. You do not want those solder joints to crack and start arcing and burning holes in your lithium cells, as we know…
Most DIY-level spot welders can only handle relatively thin tabs made of nickel strip (as opposed to the “proper” material of copper), usually 0.10mm and maxing out up to like 0.20mm thickness. You need an industrial machine to spot weld copper tabs of the thickness (0.50mm+) usually found in tool packs - both the copper material and the much higher thickness make it a lot more difficult.
You need those really thick copper tabs for the type of power a modern tool can draw. Not totally accurate numbers, but to illustrate it, 0.20 nickel flows like 5A and you need that 0.50 copperto safely handler the 50+A that tools can draw sometimes. I have a spot welder and I use it primarily to build e-bike battery packs where I have like 7 parallel banks of cells. In that scenario, the individual draw from each cell isn’t excessive and thin nickel strips are appropriate.
I HAVE used my spot welder to rebuild tool packs (and will continue to as needed), but I ONLY use those packs in very light duty applications. When I run a high drain tool, I use a healthy OEM pack.
i was looking for cells with tabs, very few sell those, and it is usually not high current cells that are sold with tabs.
as for nickel strips, i took apart makita, ryobi, and dyson v10 batteries, all of them see 20-30A but none had copper strips, all had nickel, some thicker some thinner, but all about 3\8 wide. so i think if OP uses that he will be fine. i would be more worried about circuit board bricking more than anything.
as for soldering, if you do it as you normally solder wires, it is very likely to melt plastic separator inside the cell, however there is a way to solder and not damage cells, it has been done many times by a guy on a russian bike forum, he used low temp solder, and 90w soldering iron, the trick is to melt solder fast, so it doesn’t stay hot long enough to melt the plastic all the way thru, but it requires practice, i suspect he killed a few cells before he got it right, but it is not for everyone, he claims that his packs work just fine, no dead cells,
Curious, have you seen many 18650 with tabs? I know that tabbed cells are common for Ni-Cd, sub-C, stuff in the RC car world (or maybe I should say “were” common? maybe li-po took over for high discharge stuff). But I haven’t seen (or looked) much at tabbed 18650s.
Are you sure they weren’t plated copper? I thought the same thing when I opened up my first couple packs, but then when I investigated further (cut or scratched the strips) they were all copper underneath.
i cut them, so i’d see if there was a copper under, i actually still have a strip from dyson v10, i’ll post picks when i come home,
also it makes little sense to plate a copper with nickel, the benefit of copper’s lower resistance will be thrown out if you plate it with nickel, your strip will have resistance of nickel, since electricity flows outside the conductor, might as well use cheaper nickel strips.
maybe it was steel, copper plated first then nickel plated, copper plating is excellent base for other plating over it, it sticks good to almost anything and almost anything sticks good to copper, but copper is pretty bad for spot welding due to lower resistance, thus higher resistance nickel is used for plating so it can easily be welded with spot welder. to spot weld copper you need special mini arc welder
s. now that i think of it i still have a cell from ryobi pack with pieces of strip still attached, i’ll post pics of it too
I also thought about replacing cells in some old packs, no OEM batteries available.
For nickel strips nkon proposes a service for spotwelding them at 0.5€ per cell, very good price IMO, with some cells at 3€ the whole thing wont be very costly.
But If you’re not in Europe that’s not helping.
About the potential bricking issue I thought about connecting another group of cell to the BMS during the whole replacement process, so that the BMS never see any cells going to 0V.
I have built a couple of battery packs before, I used a 240 watt soldering gun to solder on tabs. Lots of heating power for a quick solder joint.
I dont think that heating the actual case or the lithuim in such a quick or small amount can actually hurt the battery.
What purposes the danger with soldering onto the cell is the way the lithium sheets and anode and cathode is connected.
Since the anode (-) is connected to the case of the battery the cathode (+) is probably the more dangerous end for over heating.
What connects the lithium sheets to the anode and cathode is a tin strip that looks to be spot welded to each.
If this tin strip comes lose from either end then the battery is dead, no connection from the lithium sheets to the outside.
If the tin stip comes lose from the cathode (positive end) then its hanging lose on the inside of the battery where it could touch the battery case which is negative and a direct internal short.
HKJ has a few pictures that might help with understand what I mean. This is just my observation of how a lithium battery is designed.
you’d need a battery tab welder at least. You can get pretty decent high drain 18650s for ~$2/ cell, so if you have 4 packs to do you could easily do so for $200 or so, depending on which tab welder you get. Don’t bother trying to solder the cells - not from a damage perspective, but from having to fit the cells back in the case. There’s not much spare space in there!
As for disconnecting the BMS board, that’s a tricky one. I’ve recovered bricked batteries by charging individual banks, but the only time I’ve rebuilt a battery (large 40 cell ebike battery) and disconnected the BMS, it didn’t work ($800 mistake right there). I do have a lawn mower battery I’d like to build using a spare board, but I’ll wire in a “dummy” pack first to make sure the BMS lights up. One way around this when rebuilding packs is to hotwire in a “dummy” pack of the correct voltage, remove the old cells, add new cells and then remove the “dummy” pack. Not done this myself, but the theory is sound (make sure both old pack and “dummy” pack are at the same voltage) and I’ll be doing this the next time my ebike battery needs rebuilding.
Oh, and for high current draw applications, you can use 10mm x 0.1mm pure nickel strips and sandwich a layer of 0.1mm copper sheet between the nickel strip and the cell. The tab welder will weld straight through and make a solid connection between all three.
I had some success with cell replacements in my Makita battery packs. Using a butane soldering iron to solder some copper tabs. Lots of work, and costs for good cells (mid current /capacity as Sam 25R or Sanyo GAs).
Found new clones on Alibaba for cheaper than cells + shipping.
You might also ask among the Li-Ion recycler, Solar, and DIY Power Wall community. They have places like Dirt Cheap Batteries. If you salvage old packs, your price per cell can be well under a dollar. You’ll need a cell tester and conditioner.
Sorry, I guess I was thinking about heavy duty tabs that would be appropriate for tool packs / high amperage when I said that. You are definitely right, I have seen cells with tabs like that, but that paper-thin steel tab is good for maybe all of 2A current, so it’s not really going to work for OP’s purpose.
I have rebuilt NiCd/NiMh packs professionally - we were prohibited from rebuilding lithium (ion or otherwise) packs due by federal regulations.
I can’t say I’d recommend the DIY approach to lithium ion tool batteries. As already mentioned, the electronics tend to brick for all sorts of reasons as a safety feature. Not to mention having to weld tabs somehow. And then there are the legitimate concerns for safety. If we shorted a NiCd cell it would start to get hot and maybe glow or smoke - whoops, cut it out and grab a new cell. With LiIon, it goes worse, faster.
