I have re-flashed the Nanjg and Qlite drivers I have bought from mtnelectronics.com. Right now I could use a couple of nanjg 4*7135 drivers for a little project but mtnelectronics is out of stock. I have some Qlite with 8*7135 I could use but I don’t need the 8 and would rather not just remove them… seems like a waste.
My memory is fuzzy but I seem to recall reading here someplace that some attiny based drivers being sold may be locked, so they cannot be reflashed. I’ve tried searching the forum and have not come up with an answer.
Can anyone fill me in on whether or not that is true?
Where/who would be a good source for some drivers like the Nanjg 101-AK-A1 with 4*7135’s that can be reflashed?
13A's can be locked so our typical USB dongle are made inoperative to program them. You need the special Atmel kit, think the Dragon, to unlock them. So yes - they can be locked. You can even accidentally lock them based on fuse settings. I know, I bought some off of eBay that were locked - seller didn't understand but Richard at MtnE unlocked them for me (he has the Dragon tool), then I could program them.
The term “lock” is somewhat misunderstood here. As you wrote; programming pin #1 as IO bricks the MCU, it doesn’t lock it. Setting pin #1 as IO has no effect what so ever on the lock bits, just as locking the MCU with the lock bits does not brick the MCU.
Locking and bricking are not the same thing. A bricked MCU requires high voltage programming in order to flash again, a locked MCU doesn’t. According to the datasheet, a chip erase is enough to reset lock bits:
Guess we are missing the point of the OP. Call it whatever, but the fact is the driver can't be re-programmed - do you guys at least agree that it's possible?
Just change the prior words from "locked" to "bricked" please... This is kind of silly since you guys are arguing semantics while the OP points out a real world problem of not being able to reprogram drivers.
I have bricked some chips when I slipped off with the SOIC clip during flash cycle
If the reset pin is set to I/O the flash stick can’t communicate to the MCU anymore properly, so it should work with existing code but flashing again is not possible
There are a lot of drivers that are locked by PCB design shorting some flash relevant pins to ground
First, I have not reflashed many drivers. In fact, the only drivers I have flashed are Qlite 105C and Nanjg (47 or 101 variants) than I have bought from mtnelectronic.com.
I want a couple of Nanjg101's in the next month or so, but mtnelectronics is out of stock.
If I buy some nanjg 101's from, say, fasttech, KD, a seller on ebay or aliexpress, are the chances good that those MCU's will be reflashable?
The question is raised because of my fuzzy memory and limited experience. It's one of those situations where a little knowledge (my remembering something about a problem reflashing something) can be a dangerous thing. (making me wonder if the fuzzily remembered incident has any bearing on what I wish to do).
So, in short form, if I buy a Nanjg 101 from any of the common parts vendors will I very likely be able to reflash it?
If you have bought and reflashed that should be a simple "yes" answer. OR, if you have been unable to reflash a attiny based driver which ones? Somebody mentioned a problem with some Convoy branded driver. Maybe that is what I recall, but I don't recall the specifics.
i had a heated argument on another forum about that, i was told that 8 amc is too much for a small flashlights, and i should get 4 or 6, or remove some. i was arguing that, i’d rather have 8 and use mid level rather than removing 4 chips, and if i ever need to i can use all 8. but i was told, that when i use pwm to dim the light in such driver, efficiency of pwm will be lower than have no pwm but less amc chips. we never figured how much less efficient, if it even worth considering.
The thing to remember about 7135 is that they don’t magically guarantee constant current. They can’t create amps that don’t exist.
If you install 8 of them, that is a power REQUIREMENT of 2.8 amp at all times, even when the battery is low or has high IR (or both).
If you have (4) 7135, that is a power requirement of 1.4 amp at all times. Most batteries can provide that without stress.
