I forgot I ordered this driver and now it's here! Anywho, is this driver pretty much universal? Like I can use a wide variety of of emmiters like XPL, XPL HI, SST20, SST40 etc.
Yep, remove (or add) as many as you want. Can also do some custom builds on modes too (I’ve made a custom one for my daughter’s light that only has 0.1, 1, and 10%).
I take it FET works in the constant-current part of the output. Like it runs in the low voltage switching region and so by controlling voltage, the FET becomes sorta like a resistor and therefore the driver is more stable? Is this why it’s better for example for the L6?
If you learn to customize and flash firmware, Mountain Electronics moonlight special would fit the dual-channel requirement but I don’t think Richard offers it with Biscotti since it’s not natively made for dual channel.
Or you take your existing driver, cut a trace to separate a single 7135, then run an air wire from a MCU pin to the now-isolated 7135.
If you can flash firmware but aren’t comfortable customizing it, I have done builds that would work.
Bistro won’t fit on the attiny13a that’s on your board. My Babka firmware (in Toykeeper’s respository) is like an extended version of Biscotti and would work.
