AA Twisty with Long Runtime
11 posts / 0 new
spyderco monkey
Last seen: 1 week 1 day ago
I’m looking for a reliable, AA Twisty light with L-M-H interface, with an emphasis on long runtimes in L-M, and no mode memory (light always comes on in low.)
The current Maratac AA does:
Low Mode, 5 lumen output for 75 Hours
Medium Mode, 50 lumen output for 4.5 Hours
High Mode, 235 lumen output for 75 Minutes
Are there any AA Twisties out there with longer L-M runtimes?
wle
wle's picture
Last seen: 7 hours 46 min ago
not sure but try lumintop tool AA
they have a twisty version, with the magnet tail cap
at least it would be well made
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
wle
wle's picture
another thought, you may be able to get a non-twisty light to work
if it starts on low, and you could leave the tail switch ‘on’, it might do what you want. if you twist it anyway
wle
-Greg Lemond.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 38 min ago
A while ago I created this thread. Maybe it has some answers for you, not necessarily in those conditions you’re searching for:
http://budgetlightforum.com/node/68034
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
spyderco monkey
wle wrote:
not sure but try lumintop tool AA they have a twisty version, with the magnet tail cap at least it would be well made
The tool would be pretty close to ideal, but sadly has mode memory.
Meanwhile Zebralight has perfect modes and runtimes for what I’m looking for, but is not a twisty:
http://www.zebralight.com/SC53w-AA-Neutral-White-Flashlight_p_202.html
1.2lm = 312hrs
30lm = 21hrs
122lm = 4.2hrs
Lightbringer
Lightbringer's picture
Last seen: 3 hours 21 min ago
Runtime depends on the cell you’re using, its natural capacity, how “fresh” it is, etc., so I don’t put much stock in claimed runtimes.
That said, I thought the Jet-I was pretty good.
Think the Jet-II (16340) has nomem, but the Jet-I has mem.
jon_slider
jon_slider's picture
Last seen: 4 hours 14 min ago
> AA Twisty
you might like the L10
I like the 4 mode model w Nichia LED
http://www.sbflashlights.com/L3-Illumination-L10-Colors-Nichia-219-p284....
spyderco monkey
jon_slider wrote:
> AA Twisty
The runtime on that is terrible; 3 lumens x 30hrs, and doesn’t even list a runtime for the 30hrs setting.
spyderco monkey
I watched a pretty good youtube review of the Zebralight, and their runtimes were very accurate:
https://www.youtube.com/watch?v=eXbT4TmHG3I
Sadly, the Tool 2.0 has memory:
jon_slider
I do not consider Maratac output and runtime specs accurate, by any stretch of the imagination.. that is to say, they are notoriously overstated
try not to waste too much time comparing specs.. buy a light and use it, and if you dont think its close enough to your dream, buy another one, and compare it
you will know more about lights by using them, than by reading online specs
I did that too, when I first started out here.. it can be exhausting, frustrating, and essentially like spinning my wheels and going nowhere
imo, there is no magic flashlight that can run longer than any other, given they use the same battery and LED
it comes down to how bright the light is
therefore, the light with the lowest output will run the longest
that is why I suggested the 4 mode
plus, the light Im suggesting is High CRI
and that does not shorten the runtime, it only lowers the output
good luck with your search
and hang on to your wallet.. the longer you hang around here, the more lights you will try Smile
I suggest you clarify what sort of minimum output level you want, and find a light that has it.. forget about runtime.. thats what spare batteries are for.. Smile
buck91
buck91's picture
Last seen: 1 day 10 hours ago
jon_slider wrote:
> AA Twisty
I really like this as well as the L08 AAA version. I run the 4 mode for emergent long moon mode if needed but otherwise I prefer the functionality of the 3 modes better.
