Lumens-And-Lux-Light-Explained-In-A-Single-Image
A picture is worth a thousands words! So for those trying to figure it out...
But if you despise pictures...
candela: intensity of a light source (similar to a unit of power like the watt)
lumen: the flux of photons (with an intensity given in candelas) passing through a given solid angle - e.g. a sphere around a candle (lumens = candelas x steradians)
lux: flux of photons passing through a given surface area (lumens per sq. meter)
And somehow, we (stupid BLF’ers) still use kCd as an indication for throwers :wink:
So does the surface area of the emitter affect Candela?
What is the meaning of “strenghth” in this picture? The words are spoiling it :innocent:
Yeh, I don’t like this picture analogy either.
Candela is how we measure throw (light direct from the light source at a given distance)
Lumens is total light.
Lux is how bright it is at a given point regardless of where the light is coming from.
How I would word it:
Lumens = Amount of light emitted in total.
Lux = Amount of light emitted on to a surface.
Candela = Amount of light emitted on to a point.
To me that’s still not 100% clear. What’s the difference between a point and a surface? It doesn’t factor in distance for candela.
Lux = Light measured at a point/surface (the receiving area of a lux meter)
Candela = Light measured at a distance from the source (calculation of lux)
