Differences in AWG wire specs
16 posts / 0 new
kat
Last seen: 46 min 16 sec ago
I got these multimeter leads that have printed 22AWG on the wires:
http://www.aliexpress.com/item/4000061196885.html
Then I bought 10 meters of 22Awg wire from here:
https://www.aliexpress.com/item/32903241720.html
and they have printed on them 22AWG but they are much thinner. So I am confused, what’s the deal here?
MtnDon
MtnDon's picture
Last seen: 6 hours 52 min ago
At least one seller is lying. Have you measured the actual wire with the insulation removed?
virencelights
virencelights's picture
Last seen: 7 hours 14 min ago
one seller is not being honest likely
Virence Custom Built; ArmyTek Viking Pro E21A 6500k 9080 Quadtrix, Bob Sir Bob Custom Built Zebralight SC64c 219b 4500k 9080.
Jetbeam AAA 9080 E21A 9080 5700k, Jetbeam AAA Nichia HCRI Red Led.
kat
But why would they have both printed 22awg on them?
I measured the thin one with a micrometer, but it’s so thin I can’t be sure the value is correct (around 0.22 mm)
MtnDon
MtnDon's picture
Same answer as above; someone is lying and has taken it as far as having the wrong value printed on the wire. I cannot think of any other answer. AWG is a standard; physical deviation = a lie someplace. I have a gauge like this for measuring. https://www.amazon.com/Whitelotous-Stainless-Thickness-Measure-Diameter/... (the reviews on this one seem to be very good or very bad…. as if they had quality control problems on some. ?????
Johnv
Last seen: 3 days 13 hours ago
It’s square mm.
hank
hank's picture
Last seen: 4 hours 24 min ago
Someone without a clue about the meaning of the writing copied it from somewhere else, because it made the item easier to sell.
They don’t care that if you use it as marked relying on the info, you could burn your house down.
Quote:
Caveat emptor in Chinese:
让买家当心
Ràng mǎi jiā dàng xīn
“CE” is also said to mean “Chinese Engineering”
It’s like putting “tactical” on flashlight descriptions, something to write that makes potential buyers believe it’s worth more than it is.
You’ll also see “CE” written on things. That’s frequently done to fool a potential customer:
https://en.wikipedia.org/wiki/CE_marking#Not_to_be_confused_with
Quote:
The European Commission is aware that CE marking, like other certifications marks, is misused. CE marking is sometimes affixed to products that do not fulfill the legal requirements and conditions, or it is affixed to products for which it is not required. In one case it was reported that
  • “Chinese manufacturers were submitting well-engineered electrical products to obtain conformity testing reports, but then removing non-essential components in production to reduce costs”.18 *
A test of 27 electrical chargers found that all the eight legitimately branded ones with a reputable name met safety standards, but none of those unbranded or with minor names did, despite bearing the CЄ mark;18 non-compliant devices were actually potentially unreliable and dangerous, presenting electrical and fire hazards.
and here’s the relevant footnote for that:
Quote:
18__ Buckinghamshire Trading Standards: What’s in your socket?, 2008. Detailed article on hazards found due to poor-quality AC adapters. “The good news for the consumer is that there appears to be a cheap charger for any make or model of mobile phone, toy or hand-held games consoles that you might require – the bad news is that it could kill you!”
dudunphy
dudunphy's picture
Last seen: 2 weeks 2 days ago
There are many types of wire insulation. The meter leads may be thicker because of the type of use. If you look at the pics they have two coatings on the meter leads and only one coating on the rolls. The wire inside is probably the same gauge.
Edit: Different ambient temps, chemical or sunlight resistance and overall usage all a factor in insulation types.
http://www.titanwnc.com/nec-csa-designations/
Dustin
MtnDon
MtnDon's picture
I thought it was obvious that AWG refers to the diameter of the actual conductor, not the OD which would include the insulation layer.
moderator007
moderator007's picture
Last seen: 3 hours 10 min ago
That’s exactly what it is for as far as I know. Usually silicone meter leads have a lot thicker sheathing than standard silicone wire. Im guessing to take more abrassive and flexing abuse so they last longer. I have ordered the same AWG silicone wire size from several different places in the US and china. They can have different size sheathing on the same wire conductor. Teflon wire from what I have seen usually has a much smaller sheathing than silicone wire in the same AWG rating.
It be hard to say if one seller is lying or not unless you measured the conductor diameter. I have purchased silicone wire from Aliexpress way cheaper than in the US with the wire being just as good quality. This is the store I purchased from. https://www.aliexpress.com/store/2916004?
Lightbringer
Lightbringer's picture
Last seen: 4 hours 59 min ago
Back when looking for bulk wire on AX, I’ve seen “18ga” wire that said rather prominently, “not American 18ga” or something to that effect. You could get 22ga wire that’s labeled “18ga”, and it’s just horse$#|+. But that’s their disclaimer, so you can’t return it.
Plus, cheap stranded wire is often not made from continuous strands as it should be, but is mostly made from random scraps of wire twisted together. So you could strip insulation off a wire-end, and pull out 1-2 short strands of wire, too.
It’s disgusting.
ggf31416
Last seen: 1 week 20 hours ago
https://en.m.wikipedia.org/wiki/American_wire_gauge
22 AWG should be around 0.64mm in diameter WITHOUT the insulation. 0.22mm not counting insulation would be 31 AWG.
CNCman
CNCman's picture
Last seen: 3 min 4 sec ago
Thanks for the links “ moderator007 “, I really needed that for the silicon tubing for my water cooled flashlight ! Thumbs Up
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
Lexel
Lexel's picture
Last seen: 10 hours 22 min ago
20A on AWG22 is quite optimistic on the probe link
Usual probe leads in Europe have 0.75 or good ones 1.5mm²
Dave_C
Last seen: 1 week 3 days ago
It’s disgusting.
lol, no. No wire is made like that. It’s impossible, they couldn’t even put the insulation on, it wouldn’t run through the machine or unspool. Maybe you cut too deep when you tried to get the insulation off, or maybe it was damaged because they bent it too tightly to package or ship it, but even the cheapest junk wire uses continuous strands. It may not be all copper, or that copper may have radioactive chinesium impurities in it, but it started out as single strands.
As far as the risk of getting less than pure copper, especially copper clad aluminum in its place which is particularly problematic when you were wanting high strand count wire for flexibility, i wouldn’t even bother trying to measure diameter. Hook up a test load for a known current draw and measure the voltage drop. What they claim the gauge is, isn’t nearly as important as the effective resistance in use.
I am not so sure it can be said that this generic wire is just as good as US wire. Often the silicone falls apart in a few years and comes off in chunks, and sometimes it even bleeds out some silicone oil and becomes nasty sticky.
kat
Speaking of silicone wire, I received this box of 18 AWG wires
https://www.aliexpress.com/item/32872439317.html
seems ok at first glance.
I only paid like 1.5$ for it because of that game Big Smile
