Test/review of Ampsplus 18650 3500mAH (Black) 2020
Official specifications:
  • Battery Size: 18.40mm x 68.85mm
  • Nominal Voltage: 3.60V
  • Nominal Capacity: 3500mAh
  • Min. Rated Capacity: 3400mAh
  • Charging Method: CC/CV 4.20V +/-0.05V
  • Discharge Voltage: 2.70V (Average Cut Off)
  • Standard Charging Current CC: 1475mA
  • Standard Charging time: 270min.
  • Continuous Discharge Current: 10A
  • Protection Circuit Trip Cut Off: 2.75V
  • Battery rate: 3C
  • Weight: 49 gr.
  • Colour: Black, Silver, Purple
  • Protection Circuit Board / PCB: Yes/ Protected (Maxell)
  • Version: Button Top
  • Type: Rechargeable, High Drain, NCR
This is high capacity protected 18650 battery with a fairly high current limit for a protected battery.
The two cells match nicely, but the protection do not protect a high continuous current, there I stop due to temperature.
I forgot to mount the thermo sensor on one of the batteries.
Even without thermo sensor it trips after some time at 15A.
Conclusion
It is a good battery, but with the protection the maximum continuous current is about 10A continuous or 15A peak. The protection do also provide over discharge and charge protection (They always do).
Notes and links
The batteries was supplied by Ampsplus for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Thanks for the review HKJ.
Any indication what cell they used?
Thanks HKJ!
I don’t know but it looks like it’s the same cell as what’s in the keeppower p1835j. The speculation was that the KeepPower was either 35E or ncr18650GA.
