[♛ FreemeGB] ASTROLUX MF01S-UV & MF01mini-UV Flashlight Group Buy - Preorder Now
106 posts / 0 new
freeme
freeme's picture
Last seen: 4 hours 53 min ago
[Mar 24, 2020] Preorder starts.
[Mar 10, 2020] Group buy feeler thread created.
ASTROLUX UV-C Flashlight Group Buy
MF01S and MF01 mini
©freemex1thedeals.com
Group Buy Price: from $XX.99
Freeme's Coupon:  Reply in this thread
Can't wait for our reply??
Description Price Usual Coupon Store Link
ASTROLUX MF01S UVC $101.99 $142.95 BGSUVC Proceed
ASTROLUX MF01S UVC + 4* SAMSUNG 30Q 18650 $121.99 $162.95 BGSUVCB Proceed
ASTROLUX MF01 mini UVC $56.99 $79.95 BGUVC1 Proceed
ASTROLUX MF01 mini UVC Bundle + HLY 5000mAh 26650 $61.99 $84.95 BGUVCB Proceed
Specifications:
Name: Astrolux® MF01S-UVC Powerful Sterilizer Lamp
Brand: Astrolux
Model: MF01S-UVC
Sterilization mode: 18x UVC+UVA
UV wavelength: UVC275nm
Bulb power: 3.6W
Sterilization power: 54mW
Functions: Sterilization, Detection
Drop resistance: 1.5m
Waterproof: IPX7
Size: 122mm x 72mm x 52mm
Length: x Head Dia. x Body Dia.
Weight: 498g
Package Included:
1 x Astrolux® MF01S-UVC  Powerful Sterilizer Lamp
1 x Goggle
1 x Lanyard
1 x Gimbal nut
2 x Spare waterproof o-rings
Express Your Interest Below
Try not to PM me
Edited by: freeme on 03/25/2020 - 11:57
freeme
freeme's picture
Reserved.
freeme
freeme's picture
Reserved.
freeme
freeme's picture
Reserved.
Dougdimadome
Last seen: 11 hours 3 min ago
Interested
Ryzbor
Ryzbor's picture
Last seen: 2 hours 19 min ago
Dangerous toys.
When will the normal MF01 mini be available with violet anodisation ?
virence.com Nichia E21A 3000K + 4000K Wizard Pro
Skilhunt H03 XP-E2 660nm Photo Red
MF01 Mini, Nichia SW40 tbd
Wizard 2000K TBD
maukka
maukka's picture
Last seen: 18 hours 48 min ago
UV-C, this can’t be real, say it isn’t real.
Skylight
Skylight's picture
Last seen: 10 hours 17 min ago
Sick Doesn’t UV C cause cancer in humans? Most UV-C lamps come with the advice to leave the room when turning them on.
Must be because of COVID 19 that Astrolux/Banggood is getting crazy now with disinfectant lamps.
My 7th Old lumens contest build: Matainvoy ML18S
My reviews: Sofirn SP31 V2.0Nightwatch NI40 StalkerSofirn C8F 21700Brinyte WT01 Apollo
freeme
freeme's picture
UV-C is dangerous stuff. This tool is not mend for everyone.
Ryzbor wrote:
Dangerous toys. When will the normal MF01 mini be available with violet anodisation ?
Prototype will be sent over to local professional lab for test/ certification this week.
maukka wrote:
UV-C, this can't be real, say it isn't real.
You will see more UV-C flashlight in the market in the coming months from other makers too.
Banggood with include safety glasses for their new UV-C flashlights.
Skylight wrote:
}P Doesn't UV C cause cancer in humans? Most UV-C lamps come with the advice to leave the room when turning them on. Must be because of COVID 19 that Astrolux/Banggood is getting crazy now with disinfectant lamps.
MNLegoBoy
Last seen: 5 hours 35 min ago
Interested, hopefully will be cheaper than most uvc lamps currently, this could change rock hunting, if it’s under about $80 the would be one of the cheapest uvc light, especially if they make it in a single or quad/triple light
Wowtac A1S BSS, Sofirn C8T, Wurkkos WK30, D4s, BLF LT1
"You can't be scared of the dark, if there's no dark to be scared of"
-Me
Omega_17
Last seen: 3 min 16 sec ago
How can you use this? You are not supposed to see the light and breathe the ozone gas. They are used to clean rooms when there is no one inside.
Parametrek
Parametrek's picture
Last seen: 3 days 17 hours ago
No we are going to see more things that claim to be UV-C. They won’t actually be UV-C.
UV-C lights can’t use traditional silica glass. They need to use quartz. Optical quartz is very expensive.
The MF01S has a 72mm bezel. Looking through a catalog (and scaling up because I didn’t find any that large for sale) the price of the glass alone might be $150.
If there is anything other than quartz then the light isn’t producing UV-C. Bare emitters are also an option that would work.
Bare UV-C emitters are more dangerous than you can imagine. If an emitter is powerful enough to project sterilizing death rays several inches to a surface then touching that emitter for a few seconds will give a bad sunburn and after a few minutes guarantee skin cancer. According to the models anyway. They might not be accurate when dealing with levels that are 1000x more intense than what we see on a sunny day. (I will check my math again and cite sources in a later edit to this post.)
So what are all of these “UVC” emitters using? Anything but UVC! A quick search on ebay shows “365nm-380nm UVC” lights for example. It is likely that the lights are using something like this. Those LEDs are 310nm. UVC is defined as the area between 100nm and 280nm. Common germicidal lamps are 254nm. 310nm is UVB.
The difference in color between 254nm and 310nm is a factor of 1.22. That is about the same proportion as the difference between the colors yellow and red.
Actual UVC LEDs are also very expensive and I haven’t seen any cheap versions that looks legit.
Try the largest, fastest, most flexible flashlight search engine: parametrek.com
40 brands, 2027 models and still growing!
NEW: US battery database and European battery database
djozz
djozz's picture
Last seen: 12 min 31 sec ago
Quartz glass is not that expensive in China, an example: https://www.aliexpress.com/item/4000092520926.html?spm=2114.12010612.814... . But I guess we want to know if they do use a quartz lens, and what leds are used, partnr or link please and wavelength and radiometric power.
And of course: this will be one dangerous flashlight if really UV-C, for your eyes but also for your skin, causing burns and it is carcinogenic.
bassoverflow
bassoverflow's picture
Last seen: 12 hours 12 min ago
Hmmmmmmmmmm, interested as I like to live on the edge…
4492011
Last seen: 9 hours 43 min ago
Interested.
mortuus
mortuus's picture
Last seen: 23 min 32 sec ago
how is this light supposed to be useful to an average blfer here?
...where Frugal meets with Flashlight!
species8472
Last seen: 1 hour 28 min ago
Interested, depending on the final details.
weklund
weklund's picture
Last seen: 7 min 13 sec ago
Interested.
... Happy Landings ...
MoreLumens
MoreLumens's picture
Last seen: 7 hours 26 min ago
I love that banner. This kills the corona, guaranteed.
Th558
Th558's picture
Last seen: 6 hours 20 min ago
interested..I guess
scintillator
This light needs a remote control in my opinion.
Set the light in position,leave the room then turn it on.
That being said,I am interested.
specialk
Last seen: 2 hours 41 min ago
Interested
freeme
freeme's picture
scintillator wrote:
This light needs a remote control in my opinion. Set the light in position,leave the room then turn it on. That being said,I am interested.
Lexel
Lexel's picture
Last seen: 7 hours 44 min ago
Skylight wrote:
Sick Doesn’t UV C cause cancer in humans? Most UV-C lamps come with the advice to leave the room when turning them on. Must be because of COVID 19 that Astrolux/Banggood is getting crazy now with disinfectant lamps.
you don’t need safety glasses as UVC does not penetrate all the way to the retina, but anything like skin gets a terrible time being sterilized
good UVC LED like Klaran 50mW costs about 20$ in quantity naybe 10$, then 20$ for the quartz glass window, likely they use a plastic aluminum coated reflector
so looking just on LED and optics we hit 200$
If they go cheap with 3-5mW LEDs there is no purpose using 18 of them if 2 Klaran can do the same output
Adhara wrote:
Parametrek wrote:
… UV-C lights can’t use traditional silica glass. They need to use quartz. … … If there is anything other than quartz then the light isn’t producing UV-C.
Nonsense.
Schott for example produces several glasses in standard borosilicate formulations for just this purpose, we use them for entrance windows.
below 300nm you need quartz glass (fused silica) borosilicate will block UVC
Lexel
Lexel's picture
Ask Schott how much B2O3 it contains, it has to be a glass that has almost none in it or it would block UV
such glass composition is called quartz not borosilicate
MNLegoBoy
Adhara wrote:
Lexel wrote:
Adhara wrote:
Nonsense.
Again, flat-out incorrect. E.G. Schott 8337B, a borosilicate, transmits the 200-300nm range handily, and is intended for use in scenarios where such transmittance is needed.
Borosilicate glass is 80-90% silica(SiO2), the main chemical component in quartz
-Me
MSQRD
Last seen: 1 week 4 days ago
Interested!
Glenn7
Last seen: 1 day 17 hours ago
yes interested
808Hi
Last seen: 2 days 19 hours ago
Interested
MoreLumens
All who are interested could you say why would you like to have that lamp? Its kinda special so just curious.
MNLegoBoy
Rocks!
-Me
