Test/review of Hohm Tech School2
1 post / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 30 sec ago
Hohm Tech School2
DSC_2432
DSC_2433 DSC_2434
A two slot LiIon only charger from Hohm Tech that is USB powered.
DSC_2419 DSC_2420 DSC_2421 DSC_2422
The charger was in a cardboard box with specifications on it.
DSC_2427
The box included the charger, a USB cable and a instruction sheet.
The USB cable is very thick.
DSC_2435
The charger has a USB micro input.
DSC_2436
There are no buttons, only a led for each slot. The leds is red while charging and green when the battery is full.
DSC_2442
There is two current settings on the charger and they are selected by the battery length. There is a nice marking showing at what point the current changes.
DSC_2443
The charger has specifications on the back.
DSC_2439 DSC_2440
The connection are the common slider style that can handle from 32mm to 76mm, this means all batteries will fit.
supportedBatteryTypes
supportedBatterySizes DSC_2509 DSC_2510 DSC_2511
DSC_2512 DSC_2513 DSC_2514 DSC_2515 DSC_2516
The current for 10440 is a bit on the high side.
Measurements charger
  • When not powered it will discharge a LiIon battery with about than 0.22mA
  • When powered the charge will charge with less than 1mA when finished.
  • Below 0.5V the battery is assumed to defect and the red indicator blinks.
  • Between 0.5V and 2.8V the charger will use reduced charge current
  • Above 2.8V the charger will use full current.
  • Charger will restart if battery voltage drops below 3.9V.
  • Current changes around 60mm battery length as marked on the charger.
  • Power consumption when idle without batteries is 6.1mA from USB
HOHM%20School2%20%28SA18650-33%29%20%231
The charger uses a sort of CC/CV charging, but the current drops in fairly large steps. This is not a problem for the battery, but will mean slightly longer charger time.The charge time is not that long, because the charger maintain full current up to about full battery voltage, before it is reduced. Termination current is around 160mA, this is a slight high for some batteries.
HOHM%20School2%20%28SA18650-33%29%20%232
Second slot is similar, but the final voltage is slightly different.
HOHM%20School2%20%28SA18650-26%29%20%231
HOHM%20School2%20%28PA18650-31%29%20%231
These two batteries are similar.
HOHM%20School2%20%28BE18650-26%29%20%231
The regulation has some problems with this cell, but the end result is good enough.
HOHM%20School2%20%28KP14500-08%29%20%231
The smaller battery means lower charge current.
HOHM%20School2%200%2C5ohm%20%28SA18650-33%29%20%231
Simulating a weak charger or long cable with a 0.5ohm resistor do not prevent the charger from charging the cell, but the termination is not that good.
HOHM%20School2%20%282xSA18650-33%29
With two cells at 1A it cannot maintain full current as long, this means slightly longer charge time, but the end result is fine.
Temp7567
M1: 40.6°C, M2: 41.1°C, M3: 44.8°C, HS1: 53.3°C
Temp7568
M1: 57.0°C, M2: 45.4°C
PowerOnLiIon
The charger needs about 8 seconds to reach full current.
Unpowered%20voltage%20sweep
The charger will discharge a full LiIon battery with about 0.22mA.
Voltage%20sweep%200-4.25V%200.5A
Voltage%20sweep%200-4.25V%201A
The charge profile. The drop in charge current is probably heat related, the charger use a linear regulator and when the LiIon battery is at low voltage the regulator will get hotter.
Charge%20Solar%20LiIon
The charger will not work with a unstable voltage.
Conclusion
It is a simple and easy to use LiIon charger that does what it is supposed to do.
I will rate it as fairly good.
Notes
The charger was supplied by a Hohm for review.
