What would be your ideal mode configuration on a flashlight?
41 posts / 0 new
sb56637
sb56637's picture
Last seen: 7 hours 26 min ago
BLF #1: Moonlight → Very Low → Low → Medium → Maximum
17% (15 votes)
BLF #2: Very Low → Low → Medium → Maximum
18% (16 votes)
BLF #3: Very Low → Maximum → Low → Medium
2% (2 votes)
BLF #4: Maximum → Medium → Low → Very Low
10% (9 votes)
BLF #5: Very Low → Medium → Maximum
12% (11 votes)
BLF #6: Low → Medium → Maximum
20% (18 votes)
BLF #7: Maximum → Medium → Very Low
12% (11 votes)
BLF #8: Only 1 Maximum mode
2% (2 votes)
DX #9: Strobe → SOS → OSO → dit-dit-dit → erratic → seisure
6% (5 votes)
Total votes: 89
Edited by: Anonymous (not verified) on 08/23/2012 - 16:18
sb56637
sb56637's picture
Key:
Moonlight0.2 lumen
Very Low1 lumen
Low6 lumens
Medium65 lumens
Maximum150+ lumens, varies per emitter
Well, we finally have at least one manufacturer (Mrlite) who is willing to offer custom modes the way we like them. I'd like to see what is the most popular around here.  My vote goes for BLF #1.
I strongly favor a mode arrangement that starts off on the lowest mode for the simple reason that I like to know that I can power on the light in an emergency situation with an almost dead battery.  If it starts off on high it could waste that initial charge of recuperated energy that a dead battery acquires after sitting, which is usually enough to fire up the low mode and keep it running for a while. But I understand that some of you almost always use the highest mode, in which case you might not want to click through 5 modes to get to it. A possible compromise would be BLF #3, which starts on the lowest mode and then alternates back and forth betwen lower and higher modes.
Vectrex
Vectrex's picture
When (good) memory is available, then this is very relative...
9 -> the modes of horror .... Wink
sb56637
sb56637's picture
Vectrex wrote:
When (good) memory is available then this is very relative...
8 -> the modes of horror .... Wink
Well hey, they call it a flashlight don't they? Wink And now you want a flashlight that doesn't flash??
OK, I think I know why they call it a "torch" in Europe.
Vectrex
Vectrex's picture
In Germany it is called "Taschenlampe" - meaning "pocket light" ... well my Solarfarce Extreme (sig) seems to differ.Wink
Is ramping totally unrealistic, BTW? There once was one dropin on DX. Or still is.
BTW where is my SIG... oh no, terrorists Surprised
Don
Don's picture
Last seen: 3 years 5 months ago
I could also go for Med - v. low - low - max if I had to as most of the time I'm likely to be using medium most of the time. I do prefer my modes to follow in order though so that each mode is more than the last, or less than the last. M L H can be annoying when you don't know which mode you are in. I would say stick to 3 modes if they are non-sequential, more than that will become confusing. MrLite's stock 9 settings are IMO a good example of how not to do it.
Or Option 5
But I would like it to start on a low level in case I don't want more - if I do, it is no big deal, if i don't I'm not blinded by the glare.
Moonlight is unlikely to be much use to me here - waaaay too much light pollution.
Just noticed, our siglines don't appear here.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
sb56637
sb56637's picture
Sorry for my terror-inducing forum. First seisure modes on a flashlight, then missing signatures! Looks like they don't show up on polls, apparently.
Don
Don's picture
The really terror-inducing thing is that there is probably someone out there who really, really wants option DX9 - a new option appeared - this one used to be 8
Cry
Vectrex
Vectrex's picture
I will have nightmares... what a cruel admin...  CPF was nothing compared to this ... Wink
sb56637
sb56637's picture
I'm with Don, by the way, I strongly prefer a programmable, ramping driver. But this poll is just for fixed modes, since a ramping driver requires too much additional engineering to make it feasible for a quick, inexpensive BLF custom mod.
sb56637
sb56637's picture
What's with all these complaints about missing signatures?  Tongue out
Good grief, Drupal is truly comprehensive, but mind-bogglingly modular sometimes. I seem to find some new configuration option every time I crack open the admin control panel.
Vectrex
Vectrex's picture
I want BLF #4 with low voltage detection... which already some of the cheapest lights have(was it the Skyray S-A1 ?)... we are talking about 'with mode memory' - right?
sb56637
sb56637's picture
Yep, in worst case there will be no mode memory.
What is this low voltage detection? It would only switch on in low mode in case of low voltage?
Don
Don's picture
Some lights will flash, or drop modes when the battery is low. My personal choice would be some sort of flickering that told you it wanted more power. HDS (Now Ra) lights used to do something like that, but I am very, very rarely in the $100+ light market - like twice in 7 years.
brted
brted's picture
Last seen: 2 weeks 4 days ago
I think 3 modes is about the most I want, so I picked #5 (might have picked Low-Med-High if it was offered). But usually 2 modes would work fine because on my 3-mode lights I am always skipping over medium and just using High for distance and Low for close up. But with 2 modes, if you need to run the light for a while then maybe Max isn't what you want and Low is too low. So I think the perfect thing is programmable modes, at the very least a programmable Low. Ramping is okay, but I'd be pretty happy just picking from one of the 5 modes you provided and it would be easier to get what I want that way. Plus I would want memory (or some kind of dual switch that would let me pick Low or High when I am turning it on). I rarely see a light get the Low right and people seem all over the map on what is a good low. Even you couldn't seem to make up your mind between 3 different Lows.
sb56637
sb56637's picture
Ah yes, my Romisen RC-I3 has the low power flashing alert. Personally it drives me crazy. Smile
Vectrex
Vectrex's picture
And I want to have a high PWM frequency (>1kHz) ... I'm getting more and more annoyed at my Maratac AAA and Solarforce 3-mode  Medium/Low-modes. Or better current regulated. I am starting to use high modes, even if I don't need it, just to avoid those pseudo strobes.
sb56637
sb56637's picture
@brted:
I'm sort of basing the mode options on the Fenix modes. I can definitely see myself using all 3 of those low modes. Moonlight for an emergency, Very Low for a dark house at night, or Low for a typical night outdoors.
Nautic
Nautic's picture
Last seen: 1 year 4 months ago
I would like to vote for Low - Medium - Maximum bur did not get the option.
But Im satisfied that I and others are in the lead so far.
Cheap quality is good - Expensive crap isn´t
brted
brted's picture
I agree, which is the problem with Lows: you need (okay, want) different levels for different things. That's why I'd just rather be able to set it (fairly easily). I think 4Sevens has the right idea with their tactical Quarks. I've come really, really close to getting one of their 2xCR123A neutral tint Quarks before deciding it wasn't worth $65 just for the UI when I'm pretty happy with my neutral 504B with a 3-mode NANJG driver. I still might do it. Wish they had an 18650 version (without buying the body tube separately), but could always buy a 17670 (or whatever they are).
sb56637
sb56637's picture
Ok, now there are options for:
and
fishinfool
fishinfool's picture
It was a very, very tough choice between DX #8 and BLF #6 but I finally went with #6. Wink  I love turning on my lights in max mode mainly for show-off purposes and because I just absolutely love super bright torches.  Cool
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
SirJohn
SirJohn's picture
Last seen: 7 years 2 months ago
Spacing wise what I would want is:
very low: 1 lumen
low: 15-20 lumen
medium-high: 80 lumen
high-turbo: blazing sun
This is assuming that the light puts out at the very least a true 150 lumens, preferably 200+. The inner kid in me would like at least one flashy mode even if its not entirely practical. Kids love flashy modes.
Don
Don's picture
very low: 1 lumen
low: 15-20 lumen
Easy enough to get - just about every light out there will do flashy modes. Some of them are even decent lights.
And a lot of them aren't.....
I probably have more than 60 lights that can do the disco bit and not one of them has ever been used for real in that mode.
sb56637
sb56637's picture
Strangely enough, I actually do have a practical use for strobe flashlights. Where I live, there are vicious dogs roaming loose all over the streets, especially at night. I have found a strobe light pointed at their eyes to be quite effective at staving them off without making a big ruckus.
But, as Don said above, lights with a strobe are a dime a dozen, and I already have...quite a few!  Smile  The rare thing is a light without strobes, so that's my current pastime here at BLF.
SashiX
SashiX's picture
Last seen: 6 years 6 months ago
I miss Med-->Low-->Max or Med-->Max-->Low options. Voted BLF #6.
old4570
Last seen: 4 days 15 hours ago
Very low = Moon mode 1-2Lumen
Low = 20Lumen
Med = 80Lumen
Hi = Max
In fact , I could live with , 20-80-Max for a 3 mode ...
Or even better still would be a light that just ramped ...
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Vectrex
Vectrex's picture
If only there where drivers available like the Nitecore D10 and D20 have. Ramping with shortcuts to low and max and also memory, that should suit everbody.
sb56637
sb56637's picture
BLF #2 is still winning by a very slim margin...
Vectrex
Vectrex's picture
Yeah, look what you did Mr. Admin... 3 mentally disordered people voted all-strobe... some Chinese manufacturers will read this poll and think: "There actually is a market for an all-strobe flashlight!"... it's all your fault, when the next ten flashlights on DX are all-strobe.... what started as a joke... it will haunt us .... I tell ya....
Wink
sb56637
sb56637's picture
Wink
No kidding! I'm halfway thinking about deleting those votes from the DX #9 option... Tongue out
