Any high quality storage cases for 8*18650?
25 posts / 0 new
ChibiM
ChibiM's picture
Last seen: 5 hours 17 min ago
I have a few 2*18650, 4*18650 and 8*18650 enclosed storage cases. And only the 2* storage cases are relatively strong.
My 4 and 8*18650 cases are close to worthless. The lips of the lock-system are hard to open and the part that keeps both sides of the case together starts cracking/have cracked.
Does anyone know of high quality 8*18650 or even better 12 or 16*18650 storage cases?
I'm not interested in 2-4-6*18650 storage cases. The more that fit the better.
I have these cases:
I found a few 10*18650 on Aliexpress but they look low-quality as well.
Dioda
Last seen: 2 hours 16 min ago
Im also interested. But preferably for 4 18650 cells, waterproof box.
vkor
vkor's picture
Last seen: 5 hours 9 sec ago
On 8 or more pieces I do not have, but here such container for storage 6×18650 very much likes, hermetically, made qualitatively. The model is called MecArmy B18.
Grigio
Grigio's picture
Last seen: 8 hours 53 min ago
Soshine Waterproof Battery Cases for 2 or 4 cells can be found at AliExpress, FastTech and even Walmart I believe.
Mocarny
Mocarny's picture
Last seen: 13 hours 24 min ago
power911
power911's picture
Last seen: 9 hours 8 min ago
Are the ones you using are pelican like cases?
I was gonna suggest Pelican 1010 with some custom cut foam
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
“Humans m
Paul321
Paul321's picture
Last seen: 2 weeks 2 days ago
I have this Plano Box, I haven’t fit 18650’s into yet. When I get home tonight from work I’ll give it a try.
Plano makes a variety of boxes, I bought this shot shell box which is too short to hold protected 18650’s
You could look into a pelican case, those are too expensive for me though.
Paul-
tempo
Last seen: 21 min 47 sec ago
MoreLumens
MoreLumens's picture
Last seen: 1 hour 34 min ago
I got this little while ago:
https://www.aliexpress.com/item/4000148043325.html
Not for batteries, but yeah they fit nicely too:
Inner size is something like 15cmX8cmX4.5 cm. 16×18650 fits nicely if needed without Storacells.
Could use a smaller size too.
Agro
Agro's picture
Last seen: 1 min 3 sec ago
I have the cheap 8×18650 boxes and I’m happy with them.
If you want stronger, maybe a 25-cell box would do?
Unloco
Last seen: 13 hours 30 min ago
I have a Solarforce V2 case (6*18650) but it is discontinued.
In a supermarket (in Montevideo) I found some cases of the same format and similar measurements, they also fit 6*18650 but they do not have the foam.
jf_smm
Last seen: 3 hours 34 min ago
I bought a bunch of these (not from this guy) and they’re pretty cool. Not waterproof but safe and not overly bulky.
https://www.ebay.com/itm/Large-Ego-wide-zippered-travel-storage-case-w-m...
kat
Last seen: 59 min 56 sec ago
I don’t like rigid boxes.
Nitecore NBM40 is the best because it’s made from silicone so it’s soft. You can throw it on the ground and it won’t damage batteries
https://www.youtube.com/watch?v=wiOHj5alrsw
Lightbringer
Lightbringer's picture
Last seen: 5 hours 12 min ago
Only means you ain’t throwing it hard enough. Silly
I got the 8-fers like up-top, with the little hooky-thingy on top. Look like LDPE and have some flex to ‘em, but those kinds of cases, 9 times out of 10 when I get cells in ‘em (in the mail), they’re cracked in one/more places, usually the corners.
carmantl
Last seen: 1 hour 19 min ago
I would warn against the powerpax. They look cool, but they eat my wraps up badly.
ChibiM
ChibiM's picture
Thanks for the responses.
Unfortunately, none of those are enclosed 18650 dedicated storage boxes.
I'd like one in the OP but of higher quality.
Agro's don't look the same but it's something I probably would be okay with. Not sure if 18650 batteries fit well.
I'd prefer cases with dedicated slots for batteries. I can find many types of enclosed cases without any slots so they roll around. I also would prefer not using an extra kit like MoreLumens show.
So basically I'm looking for a unicorn Big Smile
Pity
Thanks for the help guys. If anyone know where to get them, please let me know.
MoreLumens
I got few of those big Plano boxes for all kind of camping stuff, backpacks etc. Sportsman’s trunk mediums and larger one with wheels on the other end. Little expensive around here for a plastic box, but green is such a nice color and they stack up too. Good stuff I say. Thinking of getting guide series waterproof case or those StowAways if I find one somewhere. Just for small essentials when packrafting/boating and for those really rainy days. Let me know how those fit batteries though cos I always carry them with me too.
Yes I can recommend those:
Easy to get batteries in, but taking them off when fully loaded aint always so easy. I usually put some fabric strips with cells so I can just pull those and cell comes with it too. I would prefer instead of 2×2 more like 1×4 row. Probably getting some 2×18650 silicone holders next.
I have noticed that too. Helps a bit if you insert cells in a angle and remove them by pressing that “plastic claw” a bit outside. Thats the main reason I’m moving into silicone sleeves when edc and use these Storacells only for a long time storage.
Bwana
Last seen: 9 sec ago
I found some water tight small plastic containers at Dollar Tree . They are slightly longer then a 18650. I only have 4 extra cells but there is probably room for 6 in the container.
Much better quality then the dedicated one I got from Aliexpress and I think they were 3 for $1.00
Agro
Agro's picture
ChibiM wrote:
Agro’s don’t look the same but it’s something I probably would be okay with. Not sure if 18650 batteries fit well.
AFAIK a regular 12 gauge shotgun shell has 18.5 × 76.2 mm. Should be close enough.
ChibiM
ChibiM's picture
I'll have to keep searching locally. I e been thinking about possible lipstick storage cases. But so far no luck yet. Thanks for the ideas guys.
Paul321
Paul321's picture
This is the Plano Box, model number 4648-1, 3440 , this box does not have internal separation ribs.
I am able to fit eight 18650 cells along the length, and six more stacked on top. (seven should fit)
The cells are loose in this box , when not full the cells will roll about.
Obliviously this box is not designed for 18650 cells, it is a utility box I was able to purchase at Walmart for under $5
I have an idea which I haven’t tried so I don’t know if it will work, This is a water bottle ice cube tray
I don’t know if the cells would fit in those cavities, but if they do cutting the tray to fit into the box would be a viable custom storage case.
Paul-
ChibiM
ChibiM's picture
I found a case similar to yours. Although it's stronger than the dedicated 18650 boxes, I don't think I'm liking it so much. Because of what you also said: they roll about when not full. Little sad nobody produces high quality storage cases for 8+ 18650 batteries.
bmengineer
bmengineer's picture
Last seen: 9 hours 46 min ago
3d print a divider for your case?
Find all my reviews of flashlights and more gear at www.bmengineer.com
Henk4U2
Henk4U2's picture
Last seen: 20 min 40 sec ago
Here is someone who still sells the SOLARFORCE box. It says it fits 6*18650.
But it also says that 4*26650 fit in, so maybe some 3D wiggling is possible.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
ChibiM
ChibiM's picture
Bmengineer. I've been thinking about this as an alternative. Cut them in half and glue them. But then again it wouldn't look good.
The solarforce case looks like an open case without the dividers, unfortunately.
