Gray Convoy S2+ SST40 1800lm + battery
7 posts / 0 new
pigimakos
Last seen: 1 week 6 days ago
Hey guys
i am new here both in this forum and to this ‘hobby’ Smile
i bought via banggood this flashlight “Gray Convoy S2+ SST40 1800lm” but i am a bit confused regarding the battery i should buy
i made a quick search and read about protected – non protected and as noob to all of this i got worry a bit so i need yr guidance on this
I found following one but based on the proposals i saw in this forum , it quite expensive and i dont know if it is justifys the price difference
Nitecore NL1835HP 18650/3500mAh 8Α
Samsung Flat Top 30Q 18650 , not sure if there is a protected version
I am located in Greece so any link to European seller would be highly appreciated
Thanks in advance for yr help
Edited by: pigimakos on 03/22/2020 - 14:15
forsh
forsh's picture
Last seen: 27 min 2 sec ago
I only use Samsung 30q and Sony Sony’s both unprotected
If my memory’s serves me right , the s2 that has the sst40 driver has low battery protection
Oh you think darkness is your ally
You merely adopted the dark, I was born in it ,moulded by it
I didn’t see the light until I was allready a man, by then it was nothing to me but blinding
The shadows belong to me
Fw1a pro might help in the situation !
scully012
scully012's picture
Last seen: 1 hour 8 min ago
S2+ lights from Convoy have low voltage protection and fit both protected and unprotected, flat and button top batteries. Just make sure that the max battery discharge rate is higher than what the light pulls on high.
whatsthepoint
whatsthepoint's picture
Last seen: 1 day 8 hours ago
In  the S2+ with SST40 and the Convoy 5A driver I use the unprotected flat top Samsung 30Q and unprotected flat top Sony VCT6.The flashlight ships with both springs bypassed for less resistance than just the steel springs.
I mostly use medium setting since it provides the light needed for most of my uses.My light is pre availability of biscotti firmware.
This may be the best factory made S2+
Here in the US genuine 30Q batteries are often on sale in the $3.00 to $4.00 range.
I don't buy Nitecore….IMO overpriced.
never underestimate the power of stupid people in large groups
scully012
scully012's picture
http://budgetlightforum.com/node/63587
Here is a link to a thread with links to reputable battery sellers worldwide.
bcm00re
Last seen: 5 hours 8 min ago
If you have the same version that I do (and I believe you do) then the driver can pull a max of 5 amps. I also have a sst40 equipped Convoy C8+ with the same driver. I use unprotected cells in both because from what I have read these lights have good protection circuits.
pigimakos
Thank you for Yr replies… You convinced me to buy 2 unprotected Samsung q30 Smile
