Lumintop GT Mini vs GT Mini Pro (YouTube)
https://youtu.be/AzVDmFB6p5o
Features
  • Cree XHP 50.2 led, over 3,500 lumens output
  • Over 57,753cd beam intensity, over 480m beam distance
  • Runs on one button-top 18650 or 18350 with the included short tube
  • 29.5W, 9A FET driver. Parasitic drain while OFF is ~27 μA.
  • Anti-reversed design, prevents reversed battery installation
  • 43 mm ID, aluminum, smooth finish
  • Aluminum with Type III hard-coat anodizing
  • Tactile with back-lit rubber boot
  • Equivalent to IP68, underwater 2 meters
  • Size: 50 mm Ø head x 132mm length
  • N.W.: 150g without cells
User interface: [1] Default Intuitive Narsil smooth RAMPING UI. Instant access to a 2.5 A TURBO mode is also provided. [2] Conventional discrete level MODE-SET UI is available. [3] MOMENTARY mode.
https://lumintoplighting.com/lumintop-gt-mini-pro-3500-lumens-xhp502-led-high-intensity-outdoor-flashlight-p0068.html
Order just placed for one! So cheap with the TOPLMAX20 discount! Looks like a winner to me and I can’t wait to add it to my others!
Sweet!
FYI: reflector in Mini fits a bit loosely in the mini Pro. The Mini Pro reflector doesn't fit in the Mini at all.
Hmm. I keep getting “connection reset” trying lumintoplighting.com
Secure Connection Failed
An error occurred during a connection to lumintoplighting.com. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG
Works for me. Try clearing your cache and going into incognito mode.
I had to turn off my VPN, otherwise I couldn’t connect to their website either.
