Help Removing Retaining Ring in FW3A Tailcap for Glow Button
18 posts / 0 new
chrisddo
Last seen: 29 min 58 sec ago
Hi fellas…the updated FW3A’s have a black retaining ring in the tail cap and I’ve tried everything to pop it out to install a glow button. I tried small flatheads, dental tools, etc. but do not want to scrape away any thread. Any advice you may have is much appreciated. Thank You!
atobe
Last seen: 5 hours 32 min ago
You need one of these https://www.harborfreight.com/snap-ring-pliers-with-interchangeable-head... or you get creative with a binder clip’s clip.
ᕦ(ò_óˇ)ᕤ
Firelight2
Firelight2's picture
Last seen: 1 hour 4 min ago
I just use tweezers. Haven’t had a problem removing the tailcap retaining ring in any FW3 series light yet.
Henk4U2
Henk4U2's picture
Last seen: 25 min 27 sec ago
This is of course a very silly remark but: did you try to turn it in the right direction.
My FW3A has only one righthand (clockwise) thread.
That means the retaining ring uses the same thread as the body/tube.
So turn it counterclockwise to loosen it.
And it is essentially to use two pins when tightening or loosen it.
That can be done by a set of needle nose pliers. I use two SS nails, always does the trick.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 9 min ago
$3.00 (small) Needle Nose Plier’s………….. Righty Tighty-Lefty Loosy……
KB1428 “Live Life WOT
chrisddo
This helps immensely…I have some needle nosers so I’ll give it a try today.
Also, the thin silicone gasket on the tail side was ripped and fell out when I opened the tail..should I be worried about that at all?
Thanks again guys!
Firelight2
Thanks again guys!
When you say “thin silicone gasket”, my guess is you’re referring to the thin white o-ring above the clip. That o-ring isn’t needed for waterproofing and not having it won’t compromise the light. All it does is prevent the clip from rotating when the light is sealed.
If you don’t want the clip to rotate, you could try removing the black inner tube from inside the body tube. They usually come with a second white o-ring intended to center the tube, but in my experience it isn’t really necessary. You could remove that second white o-ring and place it just about the clip (between the clip and the black o-ring).
chrisddo
Mine didn’t come with any extra white/translucent o-rings (just 2 black o-rings) but I’m sure I’ll figure it out.
Thanks
chrisddo
KawiBoy1428 wrote:
$3.00 (small) Needle Nose Plier’s………….. Righty Tighty-Lefty Loosy…… !{width:49%}https://i.postimg.cc/k5N223hY/IMG-1501.jpg!
I just realized, from your images, that maybe you misread what I meant with the retaining ring..it has nothing to do with the 2 circular holes on the board for twisting removal or the board itself…but an actual black metal retaining ring on the whole board itself…most likely Lumintop’s attempt at keeping the coil straight from a lot of prior complaints. Here is image I lifted from another flashoholic that spotted it as an update.
thank you
middle age man
Last seen: 12 hours 12 min ago
The same retaining ring on my FW3A is now also too tight to move; I have tried tweezers and snap-ring pliers without success.
chrisddo
Exactly…it’s insanely tight and I don’t want to scrape the sidewalls with too much force and thrash the threads. I ordered a Snap Ring Set from Amazon Prime but the virus has slowed down all shipping so I’ll report when I get everything. Otherwise, if I can’t get it to work I’ll have a nice Cyan Glow Button for Sale Cheap Silly
middle age man
I have tried Channellock 926 and 927; if I apply too much force, the tips slip out of and abrade the notch in the retaining ring.
atobe
I’m in SG/Alhambra I’ll loosen it for you with my snap ring pliers if you stay 6ft away from me.
ᕦ(ò_óˇ)ᕤ
chrisddo
Ha..really! Deal! I’ll PM you. Smile
pinkpanda3310
pinkpanda3310's picture
Last seen: 19 hours 15 min ago
If you’re using excessive force with the pliers in the notches then you might well be chewing up the threads and locking the retainer in position.
chrisddo
I noticed that as well..went in between the indents with a little force and a tiny bit of metal dust scraped out so I stopped until I have the right tools ordered.
atobe
Yeah let me know, mostly free on the weekend with this quarantine going on. Let me know if you want the o-ring mod also, I can bring one.
ᕦ(ò_óˇ)ᕤ
chrisddo
awesome, just PMd you…
