S2+ King Of The Mountain Led??
16 posts / 0 new
Hank33
Hank33's picture
Last seen: 1 week 2 hours ago
What’s the bestest 6500K led that’ll give the farthest brightest throw in a smo S2+?. It’s gotta work with a 17mm driver and I don’t mind if it gets super hot super fast. No triples or quads, just a 1 led setup. Plus I’ll be using a BL A6 driver.
"It's super bright, super tough, and super efficient! What more could you ask for?"
The true mystery of the world is the visible, not the invincible.
oweban
oweban's picture
Last seen: 2 hours 19 min ago
SST20 or XPL-HI. I’d err on the XPL-HI to avoid super-green.
forsh
forsh's picture
Last seen: 8 min 50 sec ago
maybe a sst40
convoy s2+ running sst40 6500k 1800lumens
https://www.aliexpress.com/item/33009862476.html?spm=a2g0o.productlist.0...
Oh you think darkness is your ally
You merely adopted the dark, I was born in it ,moulded by it
I didn’t see the light until I was allready a man, by then it was nothing to me but blinding
The shadows belong to me
Fw1a pro might help in the situation !
NeutralFan
NeutralFan's picture
Last seen: 3 hours 38 min ago
I would recommend the Luminus SST-40 N5 6500K LED. This is the description Mountain Electronics has:
  • The SST-40 is a super-high power output 3V nominal LED. If your goal is maximum output from a 3V LED without concern for overall efficiency or heat, then this is the one you’re looking for! Capable of 2,000+ lumens direct-drive with an FET driver @ 7-8A.
And if you want even more throw you can slice the dome, but that will also lower the CCT.
I’d rather use my flashlight around the house than turn on the lights.
Souichirou
I have a question would you consider a Osram CSLNM1.TG though the output would be less than the SST-40 variant but throw in the light should exceed that of the SST-40
G0OSE
G0OSE's picture
Last seen: 6 hours 23 min ago
So glad I read that, if not a bit late since I already ordered sst20 triple last night lol – did know what the difference was 20/40 – now I do lol!
Maybe I’ll get a triple of that 40 later on.
whatsthepoint
whatsthepoint's picture
Last seen: 1 day 2 hours ago
[/quote]Maybe I'll get a triple of that 40 later on.[/quote]
The SST40 is XM size and uses an MCPCB designed for XM LEDs
I've not seen an XM  MCPCB in 16mm or 20mm for a triple LED build. Maybe there are some made for specific flashlights?
Usually the triples on 16mm and 20mm are 3535 LED Compatible.
I've built triple S2+ using XPL Hi 1A,XPL Hi 1B,XPG3 S5 3C and Samsung LH351D 5000k using Noctigon 3XP MCPCB.
The XPL Hi 1A is the brightest while the Samsung LH351D 5000k is my favorite.
All have had Hoop's copper pill and Carclo 10507 optics in them.
never underestimate the power of stupid people in large groups
Hank33
Hank33's picture
For the week that I used it, the tint’s not bad for a 6500K. The usual white light with a nice even tint spot. I’m building a Samsung LH351D 3500K next. Try out the different tir lenses from Simon. Smile Hmmm wonder how the tint of an XP-L HI 3000K compares with the LH351D?
polarweis
polarweis's picture
Last seen: 5 hours 42 min ago
I tried many leds in s2+. flat white has most throw by far. But downside is heat and difficult to center. But even without perfect centering it will outthrow xpl hi.
But it will never be a real thrower.
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
JS93
Last seen: 3 days 11 hours ago
Sub’d!
forsh
forsh's picture
ive a few sst40s in convoys s2s
one is 6500k and its super white and throws quite nicely
and a 5000k that throws and nice tint
ive got a triple nichia 219c 4000k also and thats nice
convoy s2 so underated!
love them
ive a few for sale
JS93
How about when it comes to triples? Whats the current king for brightness and tint?
219c’s seem to be the common favourite!
Barkuti
Barkuti's picture
Last seen: 2 hours 16 min ago
polarweis wrote:
I tried many leds in s2+. flat white has most throw by far. But downside is heat and difficult to center. …
3030 Osram ∅7 mm hole reflector centering gaskets can be obtained now, at Kaidomain for example (hope you like the new gasket naming convention I suggested BanL in his thread). And Simon Mao (Convoy) sells 3030 gaskets for ∅9 mm hole, by the way. Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
wle
wle's picture
Last seen: 3 hours 16 min ago
to really throw you need a reflector about 4x the diameter and 4x the length
then anything would work Smile
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
buck91
buck91's picture
Last seen: 1 day 5 hours ago
I’m running a Convoy boscotti S2+ with SST-20 and OP reflector and its still quite throwy. I actually really like that light, great tint and CRI and a very useful throwy but balanced beam. I had a S2+ with XPL HI and smo reflector and never cared for the beam. Wasn’t that much tighter than my OP but had a LOT of tint shift and rings.
Barkuti
Barkuti's picture
Actual beam profile differences between smooth and orange peel reflectors are rather small, this means a smooth reflector is just a tiny bit more throwy than an orange peel one. Orange peel reflectors, however, make smooth beams without rings or other artifacts which may be quite noticeable with certain emitters and/or gasket configurations using smooth reflectors.
