Vapcell INR21700 5000mAh (Blue) 2020
Official specifications:
Model: INR21700 5000mah 12A
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.5V
Typical Capacity: 5000mAh (0.2C discharge)
Min capacity: 4900mAh (0.2C discharge)
Weight: Max:75g
Internal resistance: Max:16mOhm AC 1kHz
Standard Charge: 1500mA,CCCV 100mA cut-off
Quick Charge Current: 3000mA
Max Continuous Discharge Current: 12A
High capacity 21700 batteries.
The two cells match nicely. The 12A rating looks to be correct, the batteries did not like higher discharge current.
Conclusion
These looks like good high capacity batteries.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
