10440's
32 posts / 0 new
kreisler
kreisler's picture
Last seen: 6 years 2 months ago
10440's
old4570 did a series of discharge tests of 10440's, check it out.
the AW 10440's are rated 320mAh (which seems like a honest number)
Also learn that the actual nominal capacity is 350mAh and not the (over-)rated 500mAh:
As a general rule of thumb, the max. continuous discharge current is 2C, which is -700mA (= -0.7A); please read it here:
http://www.batteryspace.com/li-ion10440cylindralcellaaasize37v350mahlc-1...
which links to:
http://www.batteryspace.com/productimages/aa/20060421/Spec_for_10440.pdf
Protected Blue Ultrafire 10440's did exist at some point in time:
http://dx.com/ultrafire-protected-10440-3-6v-500mah-batteries-2-pack-36026
...but they seem to be out-of-print and replaced by the Protected Grey Ultrafire 10440's (this OP!).
relevant cpf threads where (Protected) 10440's are discussed are:
W~O~W, now, finally, I'm a true AAA flashlight believer...
Protected 10440 (AAA size) Li-ion cells! Finally!!!
AAA/unprotected 10440 batteries
weather sucks, i am bored so why not start a thread about 10440's on bfl? most people do *not* own 10440's, neither Protected nor Unprotected, and they are indeed hard to get. the only accessible/acceptable brands which release both Protected 10440's and Unprotected 10440's are Trustfire and Ultrafire. even HKE hardly sells any 10440's, and DD doesnt carry Protected 10440's so what gives? Most non-Ch*nese flashlight retailers do *not* carry Protected 10440's in their program and only some do offer Unprotected ones .. but at what price? -- no thanks. Anyway.
The most sold protected 10440 model is the Grey Protected Trustfire 10440. Most ebay offers (and also HKE) cover this exact product and on forums people have bought this product and not any other competitive model.
There's one prominent dealer which has a little bit of choice: Dealextreme offers the aforementioned Grey Protected Trustfire 10440, but also Grey Protected Ultrafire 10440, and Grey Protected Fandyfire (Seriously?? Why not call it Won'tFire or simply FandyBrand or FandyName??!) 10440. One clever UK dealer sells grey TF 14500's but only grey Protected 10440's by UF (instead of TF), so what's deal?, are there noteworthy differences between the grey TF and the grey UF? -- Answer: yes!
It seems that there is one significant constructional difference: the conductive stripe attached at the top ("+" plus pole, nub) is either hidden/covered beneath the white paper ring (see grey UF), or it goes above the white ring (see grey TF).
This little difference in detail effectively leads to two consequences:
  1. the protruding nub results flatter if the stripe goes above the white ring (see grey TF)
  2. the nub's round shape becomes less defined and isnt perfectly circular anymore (see grey TF)
  3. the plus pole becomes extended and its safety distance to the outer circumference decreases (see grey TF)
Why are these points important? Well, they are only important if you make use of a copper sealing washer (or aluminum sealing washer) to extend the body/threads of your 1x AAA torch. In such a case, the inner diameter of the washer should be wide enough so that the plus pole of the cell could/would never touch the inner circumference of the washer when both the washer and the cell are installed in the torch.
First some explanatory pictures. After that we talk figures.
I received my grey UF's from DX where not very many customers reviewed the product. How does it get packaged/shipped? In a 2-pack wrap, and enclosed in a nice free battery case!
After unsealing the battery case and taking out the ware:
So what does it say on the wrap? The wrap contains some interesting information, 4.2V for fully charged and 2.75V when empty. We have yet to find out at which voltage..
..the protection circuit trips. Is it really at 2.75V, that's a bit late isnt it? How do we find out?
EDIT: With the UltraFire charger WF-188 it is easy to get the cells off the charger with 4.200V. Reinserting the cell 1x or 2x and you get the 4.200V. Overcharging isnt possible; so if you reinsert the cells in the charger repeated times after the LED has turned green, the max you might get is 4.215V. After 1.0hrs, cell1's remaining offline voltage is 4.189V and cell2's 4.161V (self-discharge). After 1.0week, the cell's voltage is down to ....V and ....V respectively. (20:42 o'clock, 2012-02-05; starting from 4.200V).
The above pics look like photos but they arent. They are scans made with a PC scanner. I've searched the inet and found some nice photos by a dealer:
Let's note as important piece of information the dimensions of the cells. My own measurements with a digital sliding caliper:
cell1, diameter 10.19mm (10.44mm@stripe), length 47.11mm, weight: 9.068g
cell2, diameter 10.21mm (10.47mm@stripe), length 47.03mm, weight: 9.025g
The DX product page was very inaccurate and incorrect. It stated "4.6cm" but as we've seen the actual and accurate length is ~4.71cm. This number is important as we will see. Popular 1x AAA/10440 torches like the Tank007 E09 can run on Protected 10440's with lengths up to 46.00mm but cant close the electrical circuit with cells longer than that! In such a case we would have to insert a 1x standardized copper sealing washer of 1.0mm thickness to bridge the connection between body tube and driver's PCB.
The grey Ultrafire cell has a very clean, round symmetrical circular nub (unlike the grey Trustfire cell!!) and thus is perfectly suitable to work along an unmodified standardized copper sealing washer. Well, you could probably find a plain washer in your house somewhere, that's fine. Just make sure that the inner diameter is between 8.0-10.0mm and the outer diameter between 11.5-12.0mm. If you choose the inner diameter to be 8 or 9mm, then the cell cannot penetrate the washer, which means that you are limited to the use of 1 washer of ~1.0mm (or less) thickness because of the ~1mm height of the cell's nub.
If you choose the inner diameter to be 10.0-10.5mm, then cell fits through the washer, which in turn means that you could use 2+ washers of (any) thickness and the height of the nub wouldnt play a role anymore: when you pile/stack several washers you end up with a tube, like an extension tube for your flashlight body!
Check out how well hidden the stripe is underneath the white paper ring. This ensures that the nub area is small and not extended but nicely circular with the original diameter of ~5.0mm (4.93mm, to be exact). Furthermore it is possible to identify the nub as a nub. The nub is shortish, around 1mm only, but it protrudes distinctly and clearly cant be called a "flat-button top":
In the following picture we see how the cell (diameter 10mm) is debarred from penetrating the small washer (diameter 8mm). So if the cell wants to make contact with the driver's PCB of the torch's head, its nub has to be slightly longer than the washer's standardized nominal thickness of 1mm. In the case of the grey UF cell, no problem! ( And i am not so sure in the case of the grey TF cell because its nub looks less protruding!!! )
In the above picture the red number (1.75mm) measures the safety distance between the cell's (+)plus pole and its (-)minus pole. With the washer's inner diameter of 8.0mm, we get a safety ring of 1.75mm "thickness" which is by visual inspection of the above picture totally sufficient. In a torch like Tank007 E09 the washer wont have a chance to create a short on the cell .. because of the 1.75mm distance.
If you choose a different cell (presumably the grey TF) *and* a smaller washer's inner diameter *and* dont fix/glue the washer on the driver's PCB, then a rattling washer will most likely create a short. ( A short isnt too bad because you have bought a "Protected" 10440, am i right? haha )
The following example of a standard Alkaline AAA cell showcases how easy it would be to short-circuit the battery with a rattling washer:
HARDER and EASIER refer to the following purchase i made:
Using your plain hands, it's much easier to sand down the 13.5mm outer diameter to the prospected, say, 11.80mm --- copper is soft!! --- than to grind the 8.0mm up to some safer inner diameter, say, 9.0, 9.5 or even 10.0mm.
As demonstrated earlier, with the grey UF cell, you *dont need* to sand/grind a washer. Just take the 8.0x12.0x1.0 washer and no further action required, e.g. in the Tank E09!
If you want to use the grey UF cell in the iTP A3 (Aluminum version preferred because of its anodized threads!), then you would have to add 1 unmodified 8.0x12.0x1.0 washer in the below picture by dropping it onto the driver's PCB:
In other words, with the grey UF cell and the iTP A3 you would end up with 2 (stacked) copper washers but as mentioned in the 10440 for ITP A3 Eos-thread, i do *not* recommend using the grey UF cell in an A3. (The grey TF cell might fit in the above picture, i.e. with 1 washer only and glued to the Titanium bod; it has been reported that it does.)
Now that you have understood (hopefully!) the details of the washer method, it should be easy to realize that the Protected Fandyfire cell or the Protected grey TF cell should *not* be used in conjunction with rattling washers. Check their tops (nubs) closely and you would understand why:
The following picture demonstrates how a single washer (here: home-made. just piece of wire!) is sufficient in the iTP A3 to work with a Protected 10440. Trick: Use a Protected grey TF, not a Protected grey UF! Also note that the wire doesnt form a closed ring. This way the cell is able to "penetrate" the ring, and the advantage being: The minimal height of the nub (Looks like a flat button top!!) doesnt pose any problem, and the (+)positive pole of the cell would touch (=electrical contact) the center of the driver's PCB anyway!
To cut the whole story short:
Either use a Grey Protected UF with a 8.0x12.0x1.0 copper sealing washer or use a Grey Protected TF without it (e.g. in the Tank E09). And in the iTP A3, in either case you will need an (additional) conductive spacer (either in form of an open wire ring or in form of a sanded 10.0x11.8x1.0 copper sealing washer).
Last question: In the E09, what is better, the UF with a washer or the TF without a washer?
My answer: The UF with a washer.
reason1: the UF cell has a great built quality. compare the nub area.
reason2: the washer provides a relaxed fit. i would assume that the TF without a washer is a very tight fit in the E09 (and it also depends on the manufacturing tolerances of the E09's body).
reason3: no further reason. that's it. isnt that enough reasons? ha :Sp
Unprotected Blue Ultrafire 10440's. Looks like 10440's are not very popular these days. It's true, only few torches can handle them flawlessly. Either they are too long (47mm wtf) or their voltage would fry the driver (4.2V wtf). Anyway, for documentation purposes and our records lemme continue to blah haha. Today i received the Blue Unprotected Ultrafire 10440's from DX. Many people on DX bought this product, and it was one of the first 10440's on the market. On DX you can find several reviews and packaging photos. My DX order came with a FREE battery case, and the 2-pack was not shrink-wrapped:
While it is known that you could feed Protected 10440's in the iTP A3 EOS with help of one or two copper sealing washers (and in this case you better use the Aluminum version of the iTP A3!!), the short threads and the o-ring placement suggest that it is not the securest (or safest) way to run 10440's in the A3. Water could pass the o-ring and enter the torch, or you could lose the head entirely because of the wobbliness in the short threads.
Before i continue to blah, let's have a look at the unprotected cell:
I am not sure why it says "voltage of cut-off discharge". The cell is *not* protected so in theory there is no cut-off voltage during discharge. When the cell is depleted and no more capacity is left, then the voltage will be down to some low level. Maybe that's the 2.75V they are talking about. When your cell has indeed reached such a low voltage (of 2.75V), i am not so sure if recharging could turn out hazardous. A first critical mark is 3.6V. On forums many people advise not to discharge beyond the 3.6V mark. Well, once i've got my multimeter i will check at which exact voltage the Grey Protected Ultrafire 10440's cuts off the voltage (tripped protection).
self-discharge test. With the UltraFire charger WF-188 it is difficult to get the cells off the charger with 4.200V. Reinserting the cell 11x or 12x and you get the 4.200V. Overcharging isnt possible; so if you reinsert the cells in the charger repeated times after the LED has turned green, the max you might get is 4.225V. After 1.0hrs, cell1's remaining offline voltage is 4.167V and cell2's 4.161V (self-discharge); after 1.0day, 4.134V and 4.131V; after 1.0week, the cell's voltage is down to 4.092V and 4.112V respectively. (below self-discharge test started on sunday evening, 20:42 o'clock, 2012-02-05; both cells starting from exact 4.200V).
elapsed timeremaining offline voltage (unmarked cell)remaining offline voltage (marked cell)
04.200V4.200V
1.0hour4.167V4.161V
1.0day4.134V4.131V
1.0week4.092V4.112V
2.0weeks4.076V4.104V
3.0weeks4.066V4.099V
4.0weeks4.048V4.096V
5.0weeks4.013V4.093V
6.0weeks3.973V4.091V
7.0weeks3.931V4.089V
8.0weeks3.912V4.087V
12.0weeksn/a**4.084V
19.0weeksn/a4.077V
25.0weeksn/a4.073V
35.0weeksn/a4.066V
**i am using the unmarked cell in my LD01, that's why it is from now on "not available" anymore for this observation
+++++++test interrupted at this point, 8.0 months (=35.0 weeks) is long enough a test period me thinks!+++++++
As you can see from the above table, self-discharge rate for the blue Ultrafire 10440 (unmarked cell) is rather fast. But no worries, this is common for all 10440 cells. EDIT: well, not really. as you can see the marked cell self-discharges very slowly!!
Let's note as important piece of information the dimensions and weight of the cells. My own measurements with a digital sliding caliper:
cell1, diameter 10.20mm, length 43.94mm, weight 8.395g
cell2, diameter 10.19mm, length 43.93mm, weight 8.644g
If we round these numbers, then the average dimensions of the product are: 10.2 x 43.9
( for comparison purposes, the average dimensions of Eneloop AAA: 10.2 x 44.2 )
Finally let's have a group picture with the entire Dino family, cheeeeese!! Big Smile
( click to enlarge! Wink )
Sorry, couldnt resist. DD brings so much happiness to our doors. And the many dinos .. all full of chlorophyll. So yummy! Love
Ok, gotta look after the BBQ.. Beer
Further observations/notes:
I've been using the unmarked cell in my LD01 R4 for months now, without problems with the cell and without problems with the flashlight. It is very easy to tell when time has come to recharge the (unprotected) blue Ultrafire: when you turn on the LD01 and begin to wonder 'hmm the light isnt too bright anymore is it?' then the remaining offline voltage has just passed the 3.600V (and voltage under load may be 2.5-3.0V), and when the light doesnt come on on Hi- and Med-modes any longer then the resting voltage has passed the critical 2.75V threshold and the cell voltage under load may well be at 2.0V or even less. At this point your WF-188 charger will refuse to recharge the cell, and what you need to do is letting the cell's voltage recover to its resting voltage. For example, when i quickly took out the cell and measured 1.7V "under load" and let it rest for 12 hours over night, the cell recovered to 2.880V remaining offline voltage. With this voltage the WF-188 didnt have any objections and accepted the cell for a 1st charge process. The red LED turned green after 51min, and cell voltage was only 4.157V. After repeated re- and re-inserting the cell alternately in the 2 trays of the WF-188, i was able to gain up to 4.209V+ after a total of 66min, which makes for an additional 15mins charging time to reach my desired terminating end voltage. But, of course, due to self-discharge this would be down to 4.088V again after only 1.0 hour. Compared with the tabulated data, the 4.088V should not be the remaining voltage until after more than 1.0weeks .. This discrepancy tells us that my unmarked cell has aged quite a bit during the past few months thru its frequent use in the LD01 and ITP A3. In other words, the older (=frequent charges and discharges) your cell is the less charge will it hold and the self-discharge process will proceed at a much higher rate. No problem!, you bought 10440's in order to use them, didnt you?, and not in order to store them, right? There we go Tongue Out
capacity of my 4pcs 10440's. capacity measurements with Imax B6 down to the standard "3.00V" Imax B6 cut-off voltage:
UltraFire Gray Protected *red marked cell* 254mAh@-0.1A (repeated tests: 261mAh, 260mAh), or: typical if not charged fully to 4.200V: 245mAh)
UltraFire Gray Protected *unmarked cell* 225mAh@-0.1A, rest offline voltage 3.3V (repeated test: 229mAh)
UltraFire Blue Unprotected *red marked cell* 334mAh@-0.1A , rest offline voltage X.XV (repeated test: 338mAh)
UltraFire Blue Unprotected *unmarked cell* 278mAh@-0.1A , rest offline voltage 3.3V (repeated test: 282mAh)
In summary: 10440's are a wonderful source of joy and inspiration! ( ??, haha )
*FMI* i got 4 i/o sh
Edited by: kreisler on 10/20/2012 - 11:19
Vectrex
Vectrex's picture
Last seen: 1 month 6 days ago
You don't start a topic under 5 pages, do you? Or as Boaz would put it... "I was interested in a RC-29 .... and now I want to kill myself." Wink
Streamer
Streamer's picture
Last seen: 3 months 3 days ago
LOL...Kreisler has a way with his topics.  But he does a wonderful job and is VERY thorough.
  From his review on rc-29 I couldn't resist ...and it is a VERY NICE torch indeed.
QUALITY little piece.     Keep it up Kreisler !!!      Cool
Now back to topic 10440...
BetweenRides
BetweenRides's picture
Another fine essay, kreisler! Makes me want to stick with Eneloops.....
Tecmo
Tecmo's picture
Last seen: 4 months 5 days ago
I ended up cutting the pcb out of one of my 10440s for my itp....
SashiX
SashiX's picture
Last seen: 5 years 11 months ago
LMAO, kreisler :bigsmile: Great job, man Wink
Those gray UF are much longer than blue UF Shocked (much longer than I expected Flat Stare ). Blue UF will fit better for sure, but you have to test the cell from time to time, just to have the V under control.
turboBB
Dang Kreisler, this is a heckuva thread and timely too!  I'm looking for quality 10440's so I'm going to be spending some time reading this whole thing.  Thanks for posting all the thorough details!!
Pulsar13
Pulsar13's picture
Last seen: 11 months 1 week ago
19 weeks dedicated to test self discharge? Thanks kreisler!
kreisler
kreisler's picture
thanks for your interest guys! the self-discharge test for the 1 blue cell is still ongoing since i dont need it. i use the grey protected in my Tank E09 and the blue unprotected in my LD01. i hardly use my ITP A3 anymore and i would feed the identical blue unprotected. that's how i can continue to measure the remaining offline voltage of the 2nd cell (which i had marked with a red Sharpie/Edding).
the grey protected cells seem to hold the charge much better than the blue unprotected ones but it doesnt make sense to do self-discharge tests with them because i use them all the time (aged cells!) and it takes only ~50mins to recharge a completely drained 10440 cell (they typically hold 320-350mAh capacity).
as a general statement we could say that 10440's drop in remaining offline voltage at a higher pace than the bigger round cells (14500, 18650, ..), which was to be expected, but that's no big problem because recharging 10440's takes only 50mins (with the 300mA charge rate setting of the WF-188).
Boro
Last seen: 2 hours 51 min ago
Very much appreciate your solid efforts!
NightCrawl
Last seen: 4 years 1 day ago
You didnt measure load voltage there. Load voltage could be anywhere between 0.1V lower or 1V lower.
DarkSide
DarkSide's picture
Last seen: 2 years 6 months ago
Wow, food for thought. I have bunch of the old blue 10440’s . I use them all the time in applications
that were never intended to get such a kick in the A—..-. Does the same apply to 14500’s , in general terms?
kreisler
kreisler's picture
hlsgbud
Last seen: 1 year 9 months ago
hlsgbud wrote:
11/14/2012 – 02:09
hi, can I ask you about charging for 10440?
How do I know if a li ion charger can charge a 10440?
I have already ordered a nitecore intellicharger i2 which is on the way before I decided to get 10440. However it does not list 10440 as supported which leads me to think 10440 has special requirements. I read somewhere that i4 charger is also not that good for 10440.
I have this:
http://dx.com/p/universal-ac-charger-for-aa-aaa-6f22-18650-battery-ac-10...
I wonder if it can work before I really have to get another charger just for 10440.
I also have:
http://dx.com/p/digital-li-ion-18650-battery-charger-6105
and an AA/AAA charger for my eneloops.
Can any of the above work for UF protected 10440? If not, recommendations are appreciated.
Thanks for your advice.
kreisler 11/14/2012 – 02:47
Hi,
the safety rule of thumb for charging LiIon’s is that the charge rate should not exceed 2C. In fact, optimal charge rate would be between 0.5C and 1.0C.
10440’s have a capacity of 350mAh, so C = 350.
This means that optimal charge rate would be 1.0C = 350mA or 0.5C = 175mA or anything in between.
The i4 delivers ~350mA if you charge 2 cells at the same time, i.e. 1 cell in slot#1 and 1 cell in slot #3). If slots#2,3,4 are empty and you charge only in slot#1, then charge rate is 750mA. That is over 2C, because 2.0C = 2*350 = 700.
I think that i2 delivers 500mA? (i dunno). 500mA is over 1.0C (=350mA), so it could be a bit dangerous to charge 10440’s with 500mA.
In fact, many cheap 10440’s dont have 350mAh but less, e.g. C = 270. In that case, 500mA would be close to 2C. As mentioned, 2C is considered too high.
Your universal AC charger delivers 320mA to LiIons (see specs at the back of the charger). That is approx. 1C for a high quality 10440’s, and over 1C for a cheap 10440’s.
If your cell has 320-350mAh capacity, then yes you can use the Universal AC charger! (If the cell has 250mAh only, then.. i would still use the charger haha.)
If you have further questions, we will copy paste the entire PM discussion on BLF Silly
Thanks, best, kreisl
Think I should share this information from my pm with kreisler.
(I have reformatted the pm and removed some other unrelated content.)
hlsgbud
I saw the bottom of kreisler’s post.
“UltraFire Gray Protected red marked cell 254mAh@-0.1A (repeated tests: 261mAh, 260mAh), or: typical if not charged fully to 4.200V: 245mAh)
UltraFire Gray Protected unmarked cell 225mAh@-0.1A, rest offline voltage 3.3V (repeated test: 229mAh)”
What is does it mean by red marked cell and unmarked cell?
kreisler
kreisler's picture
hlsgbud wrote:
What is does it mean by *red marked cell* and *unmarked cell*?
remember i bought a PAIR of cells?
it is to distinguish one cell from the other.
i use a marker to mark one cell.
Thanks for sharing the PMs. Now everybody can see that kreisl is a nice guy helping fellow boardies in need ftw. i am the best!!
hehe..
UPz
UPz's picture
Last seen: 4 months 4 weeks ago
How we do say here, no tienes abuela, eh? Silly
scaru
scaru's picture
Last seen: 3 years 3 months ago
UPz wrote:
kreisler wrote:
Thanks for sharing the PMs. Now everybody can see that kreisl is a nice guy helping fellow boardies in need ftw. *i am the best!!*
How we do say here, _no tienes abuela, eh?_ :p
What does that mean? From my meager understanding of Spanish "you don't have a grandmother eh?"
UPz
UPz's picture
Hi scaru
Yes, that is. If you don’t have a grandmother you need someone else (kreisler itself!) to do compliments / praise / be kind on yourself.
scaru
scaru's picture
UPz wrote:
Hi scaru Yes, that is. If you don't have a grandmother you need someone else (kreisler itself!) to do compliments / praise / be kind on yourself.
Thanks. Smile
scaru
scaru's picture
kreisler wrote:
Couldnt figure that one out so I went to google translate. Does that mean "praise own shit safe"?
UPz
UPz's picture
more like: Own praise, sure shit
hlsgbud
There are 2 more options for protected 10440 which might get popular.
Hope there will be reviews for the batteries soon somewhere.
They could be identical or clones of those mentioned in the OP.
The protruding nub of the ultrafire one looks different as it looks smooth in the third picture on the site.
blue ultrafire 600mah
http://www.fasttech.com/products/1420/10000930/1078100-ultrafire-10440-3...
black trustfire 600mah
http://www.fasttech.com/products/1420/10000933/1078108-trustfire-10440-3...
how2
Last seen: 5 years 3 months ago
I have bought the Trustfire blacks.
poggg
Last seen: 5 years 10 months ago
Hi there BLFiers!
How2, have you got an iTP A3 by any chance to check them?
old4570
Last seen: 3 weeks 1 day ago
Very nice !  reminds me to check my 10440's , must be about a year or so since charging the one in my Maratac ..
Wow -  4.04 volts , and its been sitting in a drawer for about a year
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
how2
poggg wrote:
Hi there BLFiers!
No I want to buy the Ultrafire UF-T1
old4570
Image and video hosting by TinyPic
I cant vouch for the current crop of chargers , but the GTL charger is some what low current
for smaller batteries .
Ooops , thats the wrong way to do it !  - Been 2 years since testing  charger !   damn ....   Ok the right way now ..........
Ok , this is the right way to do it !
Where was I , thats right , the GTL charges at about 300mAh , now I cant vouch for the current crop of chargers
as this one is over 2 years old .  But if you want a low current charger , more suited to 16340 - 14500 and 10440
then you may wish to cinsider a GTL charger [ cant beleive I said that ]  , the quality is ??
Ouchyfoot
Ouchyfoot's picture
Last seen: 2 weeks 4 days ago
I have never tried 10440’s as of yet. While I was buying a couple of AAA Balder TD-0 I decided, what the hell, and grabbed a couple of cheap ultrafire 10440.(not a brand I would normally buy). As its taken so long for the lights to be shipped, I’ve since ordered a couple of AW ICR’s and an IMR, so I guess I’ll be exploring the world of 10440. I already own a UltraFire WF-138B (10440/14500) charger with a max charge rate of 250 mAh, so I guess I’m good to go.
Pulsar13
Pulsar13's picture
http://i48.tinypic.com/2qvxbls.jpg
Now... what kind of li-ion put out 60mA at dead short? A dead one. Lucky. Imagine if you had mistakenly tested dead-short on a fully charged one Laughing.
old4570
Lucky it was in the charger ! + its a protected cell , so the protection circuit probably cut in .. + low state of charge , + it was an AMP meter , so probably may have killed the meter rather than the battery going boom .
