13,000 lumens from a single 21700 cell. Yes, it also has normal modes.
92 posts / 0 new
richbuff
Last seen: 9 min 20 sec ago
It looks like it is possible to get 13,000 lumens from a single 21700 cell.
3 x XHP70.2, reflectored, not a mule, 4.05 oz/115gm w/o battery. 1.41 in./36mm head diameter.  27mm body diameter,  110mm length.
IPX-8, USB-C, removable battery. Other features apply.
Imalent MS03, product information and pictures were just announced two hours ago.
Yes, it also has normal modes for normal runtime and normal heat generation, too.
It is so nice to have exciting new red hot screamer flashlights, so close to the terminal decline and fall of human civilization.
For less performance, use smaller flashlights, and for most performance, use largest flashlights.
Edited by: richbuff on 05/04/2020 - 07:32
Tater Tot
Last seen: 15 hours 41 min ago
Holy hotrod, Batman!
Th558
Th558's picture
Last seen: 7 hours 14 min ago
Looks like that thing a gonna be crazy efficient! I’m a bit sceptical of the 13k figure though. Wonder how they fit such a powerful driver in there. Maybe they have multiple PCBs for the driver? If it can actually do 13k I might have to get one.
Edit: It’s so short. How is one meant to hold something that hot?
CM2010
Last seen: 9 hours 58 min ago
Group buy and I’m in.
Scallywag
Scallywag's picture
Last seen: 8 hours 29 min ago
Gotta be somewhere in the region of 4.5-5A per emitter (if 6V). So we call it 30W per emitter, 90W total – Loneocean has developed a 100W boost driver. Now you just need to pull the whole ~30A/3V from a single cell, so toss your 30T in!
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Th558
Th558's picture
How about three SBT90.2s! jk Big Smile SST70s might work though.
ChibiM
ChibiM's picture
Last seen: 17 hours 37 min ago
1lumen.com is going to review that bad boy... hopefully it'll arrive soon.
mortuus
mortuus's picture
Last seen: 9 hours 38 min ago
given their reputation and QA.. i would have to say big no to their lights…
...where Frugal meets with Flashlight!
nick779
nick779's picture
Last seen: 1 day 14 hours ago
Agreed, especially at that wattage crammed so small.
Hikelite
Last seen: 1 week 6 days ago
110mm long, bulbous XHP70.2 LEDs, driver with inductor (cause boost), 21700 long cell but it is not a mule?
The body has 1mm thickness everywhere or how is that not a mule?
Th558
Th558's picture
As long as it doesn’t explode in my pocket I’m good Big Smile
mortuus
mortuus's picture
https://www.imalentstore.com/products/imalent-ms03-13000-lumen-flashlight
really fugly light… the switch is too high up.. u will probably burn yourself reaching for the button holding it with one hand…. and hardly any deep fins wow… where should all that heat go Facepalm
Jack Kellar
Jack Kellar's picture
Last seen: 8 hours 53 min ago
Gets a nuh-uh from me too. I have zero plans of buying an IMALENT for as long as their designs put power before safety and build reliability.
BaronVonEissler
BaronVonEissler's picture
Last seen: 1 day 15 hours ago
No interest.Never bought their brand and never will.
-QC has bad reputation, lights blowing up/catching fire! Ughh
- Terrible spot for switch.You will be burning your finger when decreasing turbo!
-Lousy cooling fins for heat shedding
-Probably get about 30 seconds of turbo before your fingers have blisters!
- These small lights with overkill output are useless and not practical to me.
I stick to bigger lights that have great output, sustained for 5 to 20 minutes depending on the outside temp. and better heat shedding, QC and run time.
You can't hide me from me.
middle age man
Last seen: 3 hours 32 min ago
The beam in the photos looks very blue; quoted run-time of 45 seconds on turbo and 1 minute on high (8,000 lm). 72 minutes at 2,000 lm would be useful with NW emitters; a single cell version of the Haikelite MT03 and MT09.
MoreLumens
MoreLumens's picture
Last seen: 9 hours 14 min ago
Stainless steel switch because plastic/rubber ones would melt?
agnelucio
agnelucio's picture
Last seen: 1 month 6 days ago
It looks quite strangely proportioned. A floody light of that size should have a larger battery area surely…
Should have high efficacy at low-mid levels, though I’m very sceptical of the 13k claim.
Make sure to use 30A+ cells and oven mitts.
Lightbringer
Lightbringer's picture
Last seen: 15 min 52 sec ago
No, no, no. You’re conflating “Imalent” with “Immolate”.
But who knows. Maybe it’s got a 13000lm pre-flash, then steps down to something less… fiery.
Firelight2
Firelight2's picture
Last seen: 4 hours 3 min ago
“Immolate” is what happens when this accidentally turns on in your pocket! Evil
Mark M
Mark M's picture
Last seen: 4 weeks 7 hours ago
What a nice feature. Love
richbuff
Brief, maximum turbo in a flashlight is kind of like underwood 10 mm Glock 29. I don’t plan on using them much, I don’t use them much, but it’s nice to know that they’re there if needed.
Nice pillars of creation avatar!
SKV89
Last seen: 2 hours 38 min ago
I hate the usb-c rechargeable batteries. I wish the usb-c was on the flashlight host. Given this is Imalent, I’m pretty sure actual lumens is about 10-11k lumens. Their QA got better with the MS18 and R90TS so quality should be good.
Sirstinky
Last seen: 25 min 14 sec ago
That thing is an expensive dynamite stick. Taming 3 xhp70.2 esp. 6v is a tall order. You’d need a crazy boost driver on 1 cell. 90W for one battery is asking a lot. Given losses in the driver for efficiency, true draw is probably closer to 100W or more.
mortuus
mortuus's picture
yes tell me about it lol… for that power u want a blf q8 ish host or something as minimum to handle that kind of lumens…. who the heck wants 10k lumens in their pants ? lol… Facepalm
Th558
Th558's picture
Me. I want 15K so I probably won’t buy this Big Smile
Rexlion
Last seen: 3 hours 38 min ago
richbuff wrote:
Yeah, so we can see it coming, right? A well-lit demise…. Silly
Lightbringer wrote:
I always thought they were synonyms. Wink
SKV89
I would love to have a 20k pocketable light even if it is only good for 7 seconds. “Turbo” is not meant to be sustained.
richbuff
Rexlion wrote:  "Yeah, so we can see it coming, right? A well-lit demise….  Smile  "
I have some lights that have lots of battery capacity and one little teensy eensy weensy led sitting on top of all that battery power. However, due to some kind of off-beat personality profile that is all my fault, I don't feel excited about them. One day, science will develop a pill that will cure me. I will probably take two pills, get very excited about uber practical lights, and destroy my liver. Until then, give me single cell lights with enough multiple emitter power to blast me off to Heaven!
By the way, 444 posts, nice!  My fav TC Contender is JD Jones SSK hand Cannon in .444 Marlin, throated long, so the bullet does not take up precious case capacity.
en.wikipedia.org/wiki/.444_Marlin
edit: SKV89 posted when I was posting. His post, diectly above this post: "I would love to have a 20k pocketable light even if it is only good for 7 seconds. “Turbo” is not meant to be sustained." Yes, I agree. Turbo is meant to be there, when need be.
Bbtw: I ordered two of these from my fav modder/supplier. My guess is that he won't be able to boost them.
SKV89
richbuff wrote:
Bbtw: I ordered two of these from my fav modder/supplier. My guess is that he won’t be able to boost them.
Hard to say because HL drivers aren’t that good. Maybe even a spring bypass from your fav modder might bump up the output a bit.
mortuus
mortuus's picture
so why the need for so much lumens in the blink of an eye ?
texas shooter
Last seen: 7 hours 36 min ago
You’ll sound like my kids. Just admit it we’re here because we like bright shinny hand held lights. Some of you posting all the critiques are going to buy it anyway. I’ll probably get it and tell my non flashlight cohorts “It’s takes a Tesla battery and produces 13,000 lumens, as much as 10 headlights.” I’ll have it for grins and giggles for awhile then probably sell it to someone who wants it more.
