Does anyone have dimensions? Outside diameter and height?
I need the measurements to find a replacement reflector for a 4x18a I ordered for a sbt-90.2 and driver swap. It would be nice to find and order a replacement reflector before the ‘host’ arrives. The sbt-90.2 is on a 32mm mcpcb and I’d like to keep the original reflector as-is for the option to revert. Convoy doesn’t offer the reflector itself and I’d have to remove a bit over 2mm from the base to fit with the shim under the new mcpcb. It would be nice to order a few in case I make a mistake cutting down the replacement.
Possibly ask Simon from the AliExpress Convoy store. I’ve had luck getting parts if shipped with other items. But parts usually are ones he carries in the store. Never hurts to ask though. Simon has helped a bunch of folks here before.
