Test/review of Hohm 21700 Run 3023mAh (Black-white)
Official specifications:
  • Capacity: 3023mAh
  • Max Charge Rate: 5.29A
  • Continuous Discharge Rate: 39.1A
  • Max @ 80oC | 3.2V cut-off: 49.5A
  • Pulse | Peak: 56.4A (<=5 SEC ON >=30 SEC OFF)
  • Cycle Life Retention: 500 Cycles (73), 1000 (64)
  • Chemistry Type: QSP Li-NMC
This is a low capacity and very high current 21700 cell.
The two cell do nearly match and can deliver at least 30A with a minor capacity loss.
Conclusion
The batteries can deliver a lot of current, but capacity is in the low end for 21700 cells. I.e. these cells are mostly interesting if there is a need for very high current.
Notes and links
The batteries was supplied by Hohmtech for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Thanks again for these reviews…
“Diameter: 11.5mm” is likely a typo.
That do sound a bit on the thin side.
Thanks, I have fixed it.
