Would you purchase a 14500 version FW1A "mini" if it existed?
115 posts / 0 new
Oli
Last seen: 2 hours 20 min ago
With a single sst20 2700K. Ready, aim, throw.
Oli
JaredM wrote:
Just imagine an FW1A that’s ~20mm shorter and ~5mm narrower.
Seems to me it should get closer to 25mm shorter. The depth of the reflector would be shorter. Although the ability to take a button top might be better. And the inner sleeve should not be carried over so,,,?
SKV89
Last seen: 6 hours 57 sec ago
I just realized FW1A is by lumintop and they already have the GT Micro for those who like single emitters with high throw efficiency. I guess this one would make sense for a triple. It would be the first 14500 triple on the market.
jon_slider
jon_slider's picture
Last seen: 1 hour 42 min ago
it will not be a triple
ToyKeeper wrote:
There really wouldn’t be much point in making it a triple.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 55 min ago
It is no longer sold, but this is/was a 14500 on the market!
And made by a BLF member: vestureofblood (also know as Matt Smith from AdventureSportFlashlights Wink )
Ultimate TRI EDC:http://budgetlightforum.com/node/55320
I turned my Jaxman E3 into a triple a while ago Smile But it is not as fancy Silly
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3/ 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
SKV89
I disagree that there’s no point in making a triple. Some people use their lights in doors and prefer floody lights. Also there are SO MANY single emitter 14500 out there including Lumintop’s own GT Micro, Tool AA, E05C, ED15, L1A, EDC05, Duke, Prince Mini, D10; I don’t see much reason to make another single emitter 14500 to compete with their already huge selection. A triple on the other hand would be unique. For me, I would be more interested to see a 4x or 9x E21A mule. I love the 16x E21A mule in the KR4 so much.
jon_slider
congrats
but that is not an 18.5mm diameter light
the point of AA, to me, is to use a thinner host.
there is no triple optic for 18.5 diameter, that I know of
for those who want a triple, the FW3a is already that
there is also already the RRT-03 that is a triple, that can be used with AA… but it is not 18.5mm diameter either
they dont run Anduril…
you seem to be restarting a wish list, without the benefit of reading the previous posts
SKV89
You got me there Smile
Oli
Yes the question was fw1a. A 3/4 size (in all dimensions) with 200m of throw. Warm and high Cri for indoor use. But still able to reach out and touch something way out outside. The GT micro is larger in all dimensions. I don’t want to go over 27 mm head for horizontal pouch belt carry. Or pocket.
abbazaba
abbazaba's picture
Last seen: 1 week 10 hours ago
Definitely buying an AA and AAA Andruil if they happen
jon_slider
Me too, but I dont expect they will run on primaries, nor eneloop.
ALL the Anduril lights I have heard of require LiIon.
The AA Tool that CRX has converted to Anduril, requires LiIon too:
ToyKeeper
ToyKeeper's picture
Last seen: 16 min 46 sec ago
Yes, there are several 14500 throwers, like the GT Micro. But this isn’t about making throwers. The point is to make something small.
If anything, I’d argue that lights like the GT Micro and BLF X5 don’t really make sense. The head is so big, it’s a bit silly to use such a small cell. The X5 really should have used 18650, 18500, and 18350 cells instead of 14500. But it didn’t, so it basically got obsoleted as soon as the Emisar D1 came out. The X5 was cute to look at, but the D1 was far more practical.
That’s really cool… a work of art, even.
On the other hand, it’s not small. As emarkd put it, “Its a handful, not really a small light and definitely not lightweight”.
If his picture shows the dimensions accurately, it appears to be about 105 mm long and 24.5 mm in diameter… but I have an 18650 triple which is smaller than that. My brass 18650 triple is 102.5 mm x 21.9 mm.
My favorite AA-sized lights, however, are about 17 mm wide and 80 mm long. So I’d ideally keep 14500 lights around that size.
zak.wilson
Last seen: 4 days 23 hours ago
“A reasonable EDC light, not minmaxing for some attribute” is… not the BLF default, I think.
It’s my default though. I have more impressive lights, but it’s the Zebralight SC64c LE that makes it into my pocket most days. A 14500-powered, tail-e-switch light running Anduril and taking a similar approach to performance tradeoffs as the Zebralight would also get a lot of pocket time from me.
Ceilingbounce – flashlight testing and runtime graphs for Android
ToyKeeper
ToyKeeper's picture
zak.wilson wrote:
“reasonable… not minmaxing” … would … get a lot of pocket time from me.
Yeah. It’s not exciting, but it’s incredibly useful.
If I understand correctly, it’s also basically the reason why Hank has two brands. Emisar is for minmaxed lights which produce as much light as possible even if it might not entirely make sense. Noctigon is for more reasonable designs which are meant for steady, sustained output. Direct drive vs regulated.
So I think Noctigon would be a good option for a small EDC-oriented light.
Personally, I’d love to see a few designs…
  • 14500 tail e-switch with one LED, designed to be as small as possible. Would ideally have a version with a high-CRI neutral LED, and a driver regulated to … maybe 2A? Deep-carry one-way clip at the tail.
  • 18650/18350 light with side e-switch and one LED, designed to be as small as possible… similar to the Olight S-Mini. Regulated driver limited to ~3A or ~5A, with a lower channel added for good moon/low modes. Beam profile of about 10 cd/lm. Deep-carry one-way clip at the head, styled like the older Olight clips. Mild texture; no aggressive knurling.
  • A D4 or KR4 with tint mixing from 2700K to 6500K, or maybe 3000K to 5700K. Two regulated power channels limited to 3A each. LED choices of E21A, XP-L HI, or SST-20.
So, basically two small EDC lights (14500 tail switch and 18*50 side switch) and a quad with tint mixing.
Not sure what they’d be called, but maybe something like… Noctigon E41, E31/E61, and TM4? (E = EDC, TM = Tint Mixing, 3/4/6 = 18350, 14500, 18650, 1/4 = number of LEDs)
Oli
The FW1A is a pretty compact good thrower. If a mini fw1a isn’t going to throw 200 m or more then I’d have to change my vote. I don’t have any AA lights (and won’t ever) nor any 14500 lights and probably won’t unless I can get over 200m and keep it smaller than an fw1a. I can see why the small size would appeal to some people. The success of the fw 3 + 1 is mostly due to compact size and power. To stray from that doesn’t make sense.
zak.wilson
I expect an FW14 with a White Flat 1mm would exceed 200m FL1 throw, and that probably should be an option, because there are people who like to minmax, and they spend money.
JaredM
JaredM's picture
Last seen: 1 hour 1 min ago
I’m on the same page with TK here. I’m just looking for a well executed 14500 light under ~20mm dia utilizing a single emitter and a 1.5-2A regulated driver. Ideally the reflector used was made to a size compatible with the TIR optics for maximum flexibility there. Everything doesn’t need to be a hotrod or superthrower.
20mm. Screw on (D25A style) clip. Single 3535 emitter. 500-600lumens. ~5kcd. Clean beam. Good glass/lens. Aluminum! (SS bezel okay). Tail E-switch with proper weight and countersinking.
Nismo
Nismo's picture
Last seen: 2 days 9 hours ago
I wouldn’t, I already have a Sofirn SP10S which does the job well. It has a Samsung LH351D @5000k 90+ CRI and good throw/flood balance. The UI isn’t the best on it though.
I hate the button on my FW1A, it triggers just by my thought of touching it and I don’t like locking my lights since when I need a light I need it fast.
EDIT: Seems like few people mention the SP10S here? Any reason for that?
Current lights:
Emisar D4V2 SST-20 4000K, D4V2 Ti SST-20 2700K amber switch LEDs, D4V2 Ti SST-20 4000K cold white switch LEDs, D4SV2 SST-20 3000K | Fireflies PL47G2 XPL HI V3 3A, PL47G2 SST-20 4000K Lumintop FW1A SST-20 4000K Nitecore LR12 XP-L HD V6, TUP XP-L HD V6 | Sofirn C01S SST-20 4000K, SP10S LH351D 5000K, IF25/LT1-M SST-20 2700K + 6500K w/3D printed diffuser, BLF SP36 LH351D 5000K, BLF LT1 | ZebraLight SC53Fc XP-L2 4000K Convoy C8+ SST-40 6500K
jon_slider
glad you are enjoying your sideswitch light
google said it is 21.3mm in diameter
I prefer to use a tailswitch, which is why I mention the AA Tool as my example for a possible 14500 Anduril host. It is 18.5mm in diameter, which I think of as thin.
I like TK’s interest in 17mm diameter even better.
a tailswitch seems like a good match to a thin host.
and I just like tailswitches better than sideswitches
I also prefer a UI that clicks on and also clicks off.
I find the sofirn UI less fun, due to hold for off.
JaredM
JaredM's picture
Sounds like you need the o-ring mod for your switch. Stiffens up the actuation and eliminates accidental activation.
Nismo
Nismo's picture
Interesting, I will definitely check that out. Thanks!
Current lights:
BOO5TED
BOO5TED's picture
Last seen: 1 day 2 hours ago
I posted this in another thread but here ya go.
BOO5TED wrote:
Disassemble the tail cap, if it has a retaining ring you can remove it with snap ring plyers or the end of a binder clip. I used the binder clip because that’s what I had.
It should look something like this when done.
Remove the little “nub” (as some people call it) from the center of the rubber part of the button and replace it with the o-ring. It should look like this.
Reassemble everything without the “nub”.
I forget what size the o-ring is but I’ve heard the o-ring from inside of the valve caps on your tires works also.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
scalpel_ninja
Last seen: 4 hours 21 min ago
For US sizes, a #36 O-ring worked well for my FW3s.
Edit: just to add that size is readily available in packs of 10 at Lowe’s and Home Depot in the plumbing section.
Inova X5 | Maratac Inspection AAAx2 | Wowtac A2S NW | FW3A SST-20 4000K + 18350 tube | FW3T SST-20 4000K + 18350 tube | Noctigon KR4 Ti/Cu E21A 4500K (en route) | Thrunite Ti3 NW
JaredM
JaredM's picture
1/16” nominal thickness. Either 5/32” or 3/16” inner diameter.
dash size 008 or #36 in US hardware stores
