1S Boost Driver 6v-12v
20 posts / 0 new
Quadrupel
Quadrupel's picture
Last seen: 7 hours 18 min ago
bbs-raibas
2
Original source :Here & Here
Edited by: Quadrupel on 05/22/2020 - 15:50
Chatika vas Paus
Last seen: 1 hour 50 min ago
More info please.
It’s boost driver for 1 cell and 6V led I guess?
Is it programmable with blf firmware?
bikenber73
bikenber73's picture
Last seen: 9 hours 1 min ago
Awesome…..I guess?
Quadrupel
Quadrupel's picture
We shall see.;))
bansuri
Last seen: 1 day 2 hours ago
If it’s as fun as the other drivers I got from you then count me in!
raccoon city
raccoon city's picture
Last seen: 8 hours 57 min ago
Quadrupel your pleasure
Quadrupel your fun
It's the right one
The Quadrupelmint gum
WTF
Last seen: 2 hours 20 min ago
Is that a synchronous boost converter controlled by just an attiny? Pretty slick if you can pull it off. That gives me hope for a high power buck boost driver.
What kind of switching frequency do you expect?
WTF
Thanks for the schematic. I was wondering what F2 was being used for but still don’t see the need for it.
I believe the original driver switched at 300khz, it would be nice if that could be increased. Maybe replacing F1 with a Schottky diode might be easier than trying to figure out the band gap between F1 and the pfet. The band gap may need to change with load and temperature, and there could be some shoot through if the attiny gets too busy.
The attiny 1626 and 1627 are almost available. 20mhz clock speed and 12 bit adc would be nice for this application.
sidehack
Last seen: 2 hours 22 min ago
I was looking at a micro-driven switching controller a couple weeks ago but, with the chips I have available, couldn’t get a sufficiently high switching speed and decent resolution at the same time due to hardware PWM limitations. 6.8uH inductance probably helps with that; I wanted to stay under about 2uH to get high saturation and low DCR in a compact package for a 17mm driver. Slick use of the analog switch as a gate driver too.
Quadrupel
Quadrupel's picture
So, ordered PCB and components. Coils same size 7×6.5mm, 3 values: 5.6, 6.8, 8.2uF and caps 22, 47 and 100uF for experimenting and tuning. Big Smile
Agro
Agro's picture
Last seen: 6 hours 31 min ago
How are they better than 1616?
WTF
The 1616 has a 10 bit adc but it may not matter if you are using an op amp. The little bit I have read about the two series claims very fast adc conversions and a more powerful cpu. Either one would be an improvement on the old 85.
My biggest concern is the attiny could be spending too much time on other tasks and not spending enough time on the boost converter. If this thing works and the switching speeds can be increased it opens the door to higher power versions and maybe buck boost as well.
Agro
Agro's picture
Just took a closer look…I really like it. Smile
I wonder what kind of power can it deliver and at what efficiency.
id30209
id30209's picture
Last seen: 6 hours 59 min ago
It would be better in 20mm size and 2.5A @12V
WTB Titanium 4sevens 2xAA tube
Quadrupel
Quadrupel's picture
I guess efficiency should be about 80-85% and power.. maybe 20W?. Ordered few 20mm too.
Agro
Agro's picture
To be honest I find the efficiency underwhelming…what makes it so much less efficient than say GXB172?
sidehack
50mOhm series resistor and the rectifier drop, to start. Without a synchronous rectifier, conduction losses really pile up.
Nitewalker
Nitewalker's picture
Last seen: 4 hours 15 min ago
Quadrupel your fun
It’s the right one
Hahahaha, what was that all about Big Smile
Quadrupel
Quadrupel's picture
Yes, yes the best is synchronous rectification , but Ill be very happy with “only” 85% eficiency Big Smile
raccoon city
It's a (modified) commercial jingle for Wrigley's Doublemint gum.
