[♛ Group Buy] ASTROLUX FT03 Mini XHP50.2 (4200lm) / SST40 Anduril AUX LEDs USB-C 18650 Flashlight - SHIPPED
186 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 1 hour 25 min ago
Funtastic wrote:
If you look closely at my photo, the very center has a yellow spot, I haven’t seen this before on an XHP50.2. Hard to see the spot on some screens
Thanks freeme but this is different.
I think it’s more to do with the reflector shape and focus than the led type. You can try adding a paper spacer under the centering ring to change the focus slightly.
I dont know if this is a common thing with the FT03 mini 50.2.
Funtastic
Funtastic's picture
Last seen: 4 min 39 sec ago
freeme wrote:
No yellow spot at dead center of the beam.sealed
Funtastic wrote:
If you look closely at my photo, the very center has a yellow spot, I haven’t seen this before on an XHP50.2. Hard to see the spot on some screens Thanks freeme but this is different.
I have two monitors, one shows it that has accurate colours, the other is not visible
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
raccoon city
raccoon city's picture
Last seen: 25 min 28 sec ago
I can see the yellow spot on two different monitors, but I honestly don't know what it means.
Funtastic
Funtastic's picture
It’s a focus issue but don’t think it can be fixed without removing the aux board. I think the reflector is too high. The SST40 is perfect though
freeme
freeme's picture
Last seen: 18 min 58 sec ago
coolcoolcool
Worthy of FT03 badge.
©freemex1thedeals.com
varbos
Last seen: 6 min 48 sec ago
I have the same (dark spot in beam center) in a Skilhunt M200. I guess it is just a minor error in reflector geometry or position.
Tom E
Tom E's picture
Last seen: 23 min 7 sec ago
Received mine today with the SS bezel. Overall it's impressive. Mine is the 5000K SST-40, might be my first 5000K SST-40, and I do like this LED's tint and beam in this light.
The AUX LED setup is a bit confusing but I think I understand what's going on. Besides the switch LED, there are 4 separate LED SMD's around the main LED and they cycle through 6 patterns of:
   RED, RED/GREEN, GREEN, GREEN/BLUE, BLUE, BLUE/RED (no white as the manual says)
You can't stop the cycling, can't select a separate color and have it stick. The reason is it doesn't work like an Emisar light is because it's using the ATTiny85 MCU, not the 1634, and therefore doesn't have the I/O pins or memory to control that many LED's. The AUX LED blinking is probably controlled by the add-on AUX LED board, assuming it's a Lexel design (?).
You can't even stop the switch LED from blinking, so maybe there's a firmware mod as well? Dunno, I find it annoying - only option to stop it is by turning it all off.
Ooops! My Bad! 6 clicks plus click/hold toggles through solid color choices.
Funtastic
Funtastic's picture
What? I can choose what colour I want with the aux leds and it stores it after removing battery etc
Tom E
Tom E's picture
For my 5000K SST-40, on a VTC5D, I measured 9.05 amps (clamp meter), 1840 lumens at 30 secs (Maukka cal'ed), and 95 kcd.
Funtastic
Funtastic's picture
Tom E wrote:
For my 5000K SST-40, on a VTC5D, I measured 9.05 amps (clamp meter), 1840 lumens at 30 secs (Maukka cal’ed), and 95 kcd.
That’s pretty decent. I got 1920 lm with the 6500K using a 30Q
I find it amusing how the manual states they achieved 4200 lumens with a 30Q (XHP50.2) ANSI, while I only got 3460
Tom E
Tom E's picture
I'll use manufacturer's lumens at times, which is about 12% higher, least for the honest ratings.
d_t_a
Last seen: 28 min 56 sec ago
I see this behavior in some other flashlights (some Sofirn, like SP32A or SP31v2.0 and also sometimes on the Convoy S2+ with XPL-Hi).
I haven’t gotten the FT03-Mini XHP50.2 yet so I can’t check.
I’ll need to double-check other XHP50.2 flashlights (SP33v2, SP33v3 or Convoy S11) to see if they also have this “yellow spot” in the center of the hotspot…
Tom E wrote:
Received mine today with the SS bezel. Overall it’s impressive. Mine is the 5000K SST-40, might be my first 5000K SST-40, and I do like this LED’s tint and beam in this light.
The AUX LED setup is a bit confusing but I think I understand what’s going on. Besides the switch LED, there are 4 separate LED SMD’s around the main LED and they cycle through 6 patterns of:
You can’t stop the cycling, can’t select a separate color and have it stick. The reason is it doesn’t work like an Emisar light is because it’s using the ATTiny85 MCU, not the 1634, and therefore doesn’t have the I/O pins or memory to control that many LED’s. The AUX LED blinking is probably controlled by the add-on AUX LED board, assuming it’s a Lexel design (?).
You can’t even stop the switch LED from blinking, so maybe there’s a firmware mod as well? Dunno, I find it annoying – only option to stop it is by turning it all off.
That’s strange. Like Funtastic mentioned, mine can also cycle the Aux LED colors or choose 1 color (or even the “Voltage” indicator color), much like the aux-LEDs of the Emisar D4v2.
Funtastic
Funtastic's picture
I sold an SP33 V2 last night and while testing noticed the yellow but the FT03 Mini is most noticeable, only on a white wall though of course
JasonWW
JasonWW's picture
Your sure it uses the Attiny85? I don’t think I’ve seen any pictures of the driver or the unique centering ring.
Funtastic
Funtastic's picture
There’s nothing unique about the centering ring, doesn’t do any centering, the screws are holding everything centered, it’s just insulating the reflector
Funtastic
Funtastic's picture
I honestly don’t know what Tom is talking about because I can change colors and have it save.
From manual
“Note: The button led wire is connected with green, so it will be on when aux led colors include green like yellow, green, cyan, white. The button led will be off when aux led colors are red, purple, blue.”
Tom, the button will only flash if you have it cycling the colors. Can you not change the colors at all? I do 6 clicks + click hold and it cycles through colors, release on the color you want, if the aux led flashes and you release, then it selects the cycling again.
JasonWW
JasonWW's picture
I thought the centering ring had leds built into it.
Funtastic
Funtastic's picture
JasonWW
JasonWW's picture
Funtastic wrote:
Does the centering ring fit around the outside of the leds thereby not doing any real centering?
All those components are added on top of that custom mcpcb?
Tom E
Tom E's picture
Ooops! My bad! Totally missed the 6 click plus hold, or as the manual says: "7 clicks but hold the last click". I do have problems with the high click count settings, guess because I'm old smile
So, must be a 1634 MCU in order to control all these LED colors.
Sorry Funtastic - thought you were kidding or something - wasn't sure.
JasonWW
JasonWW's picture
If anyone has a driver pic, I’d love to check it out. Thanks.
Tom E
Tom E's picture
No driver pic yet - did that though for the EC03.
Is this mini the first production light with the AUX LED's in a reflector? I can see more of these - it sure doesn't seem to effect the lumens or throw. The SST-40 beam does have some artifacts, but some is caused by the SS bezel on mine, and others are noticeable but not that bad.
Having the AUX LED's in a reflector is impressive! I know mods have been done before like this. I can see this happening in a lot more lights - it's great for mid size and small throwers, but also would be nice in single LED EDC's.
I noticed the price of the SS bezel went up - I paid $5 at the time, now it's $8. Not sure if there was an extra discount.
djozz
djozz's picture
Last seen: 17 hours 8 min ago
I paid 5 for the SS bezel and that is enough, 8 dollar is excessive. The aux leds in the smooth reflector indeed look particularly nice, they add a lot of bling to this light. Crown
Dep668
Last seen: 2 days 3 hours ago
Could i get a code? I received an email during the pre order but never did make the purchase than
freeme
freeme's picture
Sent.
aklferris
Last seen: 15 hours 46 min ago
interested. am i too late? coupon codes aren’t working for me @ Banggood for the light & acc.
RageAgainst...
Last seen: 1 day 21 hours ago
Interested
freeme
freeme's picture
Sent.
Tom E
Tom E's picture
JasonWW wrote:
... Does the centering ring fit around the outside of the leds thereby not doing any real centering? All those components are added on top of that custom mcpcb?
Sorry, no one answered this.
Yes - it's a somewhat standard centering ring but it fits around the 4 outer LED's. The LED's are mounted on an AUX board custom fit on top of the MCPCB, pretty much the same way AUX boards work on the TIR optic lights. It's nothing new, but it's a new application of these AUX LED's. The driver must be a more advanced MCU because it's the only way you can get it done.
My bet would be Lexel is behind this design but there's lots of silence and mystery... Mystery because of the silence, but BG/Astrolux/Mateminco seem to do this - come out with a really nice light for the price, but don't release any for early review.
Really doesn't matter I suppose - I find it to be another BLF inspired trend, hoping we will see more of them! This is a quality light at a great price for what you get.
Wish it just included the SS bezel.
Tom E
Tom E's picture
Here's some better pics of the AUX board and parts - I do like GREEN:
Can be downloaded - not sure of the configuration?
Driver retaining ring and centering piece:
Close up of the centering pieces. There is some slop on the AUX board where this fits, so the LED may not center dead on:
The AUX board. 5 wires: green wire is green, blue wire is blue, red wire is red, black is ground, and not sure what the white wire is for, but appears to be connected to the green LED after the resistor, so maybe it's for the charging circuit. Those SMD LED's have 4 connections: 3 colors and ground. The layout allows the centering piece to lay flat, but unfortunately leaves too much slop space, least for perfection in centering. I think it's very close to centered by default, but not perfect perfect.
Sorry, didn't pop out the driver - I know pretty much what's there, and lots of wires to de-solder and re-solder.
clever but simple - again, I like it! In one aspect here, they did better than the Emisars/Noctigons by using a brass driver retaining ring rather than glue -- much appreciated.
The OP should really include pics of the AUX LED's in different colors. Betta most don't even realize it's there!
