Test/review of YLE NCR18500 A225 2250mAh (Green)
Official specifications:
  • Nominal voltage: 3.6V
  • Nominal capacity: 2250mAh
  • Minimum capacity: 2150mAh
  • Charge voltage: 4.2V
  • Standard charge current: 450mA
  • Maximal charge current: 1575mA
  • Discharge cut-off voltage: 2.5V
  • Nominal discharge current: 450mA
  • Maximal continuous discharge current: 4000mA
  • Operating temperature: 0°C ~45°C
  • Storage temperature: –20°C ~ 60°C
  • Cycle life: 300 cycles
This is a YLE 18500 battery from Ebay (The order included a invoice with a address in Berlin).
The two cell match nicely and can easily deliver the rated 4A.
Conclusion
This looks like a good 18500 cell. Capacity is high for the size, but it is not a high current cell in any way.
Notes and links
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Performance is good.
Name is misleading :neutral_face:
Nice job, thanks!
:+1:
Thanks HKJ! Much appreciated! I could not find the cell in the comparator though. Was I just missing it?
I do not know why it is missing, I have started a new build of the comparator and will upload it when it is finished. Then it may take some time before it is pushed to the website or maybe it is a cache that has to timeout.
Check in an hour or two if it is included.
It’s in there now! Very thankful for all your work and testing.
