Ampsplus 18350 1200mAh (Black) 2020
Official specifications:
Battery Size: 18.00mm x 38.60mm
Nominal Voltage: 3.70V
Nominal Capacity: 1200mAh
Min. Rated Capacity: 1150mAh
Charging Metod: CC/CV 4.20V
Discharge Voltage: 2.70V (Average Cut Off)
Charging Current CC: 500mA
Rapid Charging Current: 1000mA
Energy Density: 4.19Wh
Continuous Discharge Current: 6A
Protection Cut Off Discharge Current: 6A
Weight: 29 gram max
Colour: Black, Silver, Purple
Version: Button Top
Protection Circuit Board / PCB: Yes, Protected
Type: Rechargeable, |INR, Cylindrical
High capacity 18350 with protection circuit.
The two cells do not match in capacity, because it is protected cell they can still be used in series.
The protection is higher than 7A, I will guess at around 8 to 9A, as can be seen in my test one protection tripped during a 7A discharge and they both tripped immediately when I tried a 10A discharge.
Conclusion
I am not really happy about these batteries, capacity is a bit low and they are different, but then they are much better than many of the old generation 18350 (\<=700mAh types) and they are protected.
Notes and links
The batteries was supplied by Ampsplus for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
