AA/14500 Driver
6 posts / 0 new
how2
Last seen: 1 day 1 hour ago
AA/14500 Driver
Hi All My Smallsun M10%mode died tioday I tried a 14500 battery.
I clicked it on and off then NO LIGHTCry
I need a good driver any modes that will accept AA/14500 batteries.
The driver seems to be 15-16mm
Is this a good one?
http://www.dealextreme.com/details.dx/sku.25505
Would like up 4.2v
Thanks
Edited by: how2 on 10/19/2010 - 22:30
fran82
I would recommend  http://www.dealextreme.com/details.dx/sku.15880
BUT, BUT, BUT this driver can be destroyed sometimes with 14500. (the typical problems with LEDs with LOW Vf )
Also this http://www.dealextreme.com/details.dx/sku.25505
BUT, BUT, BUT HAS the same problem, this driver can be destroyed sometimes with 14500. (the typical problems with LEDs with LOW Vf )
So, I reccomend a driver for a type of batt you use. Most hybrid drivers has that problem
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
how2
I made it driect drive. I cutting off a recsistor looks like the rubber thing in this link
http://www.dealextreme.com/details.dx/sku.20330
Then i added some solder. It became a bright 1 mode.
I was playing with it today and it then reverted back to 5 mode. That did not last that long.
Now it's 1mode.
How did it revert back to 5 mode?
agenthex
agenthex's picture
Last seen: 6 years 11 months ago
That's the inductor used to step up voltage (ie oscillator). When you take it out, you permanent disabled the voltage boost part of the circuit. The "modes" part of the driver is seperate from the voltage regulation. Try batteries of different levels and see if that matters.
Did the light die because you tried a 14500 or was it dead already?
This may help
http://budgetlightforum.cz.cc/node/624
Your driver is not the same, but you've taken out the part labeled L in that picture.
I'm not an expert on this, so maybe you can ask Tido who seems to know what he's talking about a bit more.
Reading this makes you smarter: http://lesswrong.com/
how2
Yes it worked for a few mintues on 14500 and then died. But my ultrafire M10 1mode works fine.
how2
The Smallsun M10 now is a 6Mode now.
Cannot decide wheather it wants to be a 6mode or 1modeLaughing
