Sony VTC6 doesn’t make 20a continuous button-tops and Samsung 30Q are only 15a. So who is the best alternative for the Haikelite?
On the Nightwatch Stalker, no big brands make 26650 so who is trust worthy? I heard of Orbitronic, Keeppower, Shockli, Vapecell but who is truly king? The Stalker is running an SBT90.2 that I hear puts max pressure on even the best batteries. It draws 18a so the battery has to be 20a continuous. Thank you.
I think if you can find Samsung 30Q or VTC6 in button-top format, they should be good for the MT09R… the MT09R gets hot very quickly on Turbo mode, so it will step down quite quickly (probably less than 20 Amps power consumption after a short while?)
Sony VTC5A and Molicell P26A would be some of the most high-drain (Vapcell has a rewrapped Sony VTC5D and can add button-top [I have ordered these button-top Vapcell rewrapped VTC5D from Vapcell before] - their Vapcell 2800mAh (VTC5D), would likely also be good. Not sure who sells button-top P26A though.
