On ebay there are two different discriptions of this charger. Which one is the better one to get?
One says:
Charger Specifications: |
- This charger can charge 6 pcs 14650/17670/18650/18700 batteries at the same time.
- Six independent charging channels.
- Three modes charging method,( trickle charge, constant current charge, constant voltagecharge), monitor the status of each battery real-time when charging.
- Monitor IC temperature itself.
- Input : DC 12V 2A.
- Constant charge current:600mA±10%.
- Constant charge Voltage:4.2V±1%.
- Adaptor input::110V~240V AC 50/60Hz.
- Adapter output: DC 12V 2000mA.
- Charger operation temperature:0℃~40℃.
- Note:Please don't charge concurrently the 18650 and 14500 battery in wp6 charger.
The other says:
features:
- WP6II is a professional pulse charger designed for Li-ion battery, it can charge six 10440/14500/14650/17670/18650/18700 3.6V/3.7V Li-ion battery simultaneously but independently. It also can apply to 14500 (AA Size), 10440 (AAA Size) and 16340(ICR123A) Li-ion battery when use connectors (spacers).
- WP6II' s charging bay from left to right, two bays one group, only one battery in the group is processing CC and CV method while two battery are pulse charging method.
It is designed with undervoltage lockout and Algorithm (CC.CV) charging method which can monitor the battery' s status real time and control charging safe automatically. If the battery's voltage is lower below than 4.2V, WP6II will start charging automatically.
- WP6II adopts over and under voltage disconnecting technology which can ensure the battery' s energy will not lose even the input power suddenly cut. It makes the charger safer and more reliable
- WP6II has good heat dissipating ability.
- WP6II Charger adopts reverse-polarity protection circuit board
Which oen should i get?
