[REVIEW] Sofirn SP33 V3.0
14 posts / 0 new
mizou51
Last seen: 5 hours 38 min ago
Hello, I just made a quick review of the new Sofirn SP33 V3.0 Kit from amazon
Kit include :
-light
-26650 battery 5500mah
-USB3 cable
-lanyard +orings
-adapter tube for 18650 and 21700 batteries
This light is great and use the cool features of the narsil UI like firmware...
High output of 3500lm and USB charge feature
Machining is very good and overall quality is high
Interesting LED in the side switch button for battery level
Feel free to ask any questions
I need to update with a beamshot video and a battery lifetime graph
 Specification
※ Sofirn SP33 V3 uses CREE XHP50B 3V LED with a lifespan of 50,000 hours
※ Working Voltage: 3V-4.2V
※ Battery Options: One 26650 / 21700 / 18650 Li-ion battery
※ Dimension: 126.6mm (length)× 37.5mm (head diameter)
※ Weight: 144±1 gram (without batteries)
※ Flashlight body: Aerospace grade 6061 grade aluminum alloy hard-anodized anti-abrasive finish to get solid built body
※ Toughened mineral glass lens
※ The waterproof level: IPX8
※ Protect from improper battery installation
※ Mode Memory : Last mode remembered  (except Turbo and Strobe)
※ Advanced Temperature Regulation (ATR) technology: the brightness level will adjust automatically when the temperature goes up or down, there are 3 lines: 45℃, 55℃, 65℃, the higher the temperature is, the more the brightness will drop to prevent overheating. When the temperature is low enough, the brightness goes up again automatically.
※ Power Indicator: Each time the light is turned on, the battery level indicator will automatically display the battery status for 5 seconds.
Blue constant on: saturated
Red constant on: poor
Red flashes: critical
Edited by: mizou51 on 06/04/2020 - 16:12
Lightbringer
Lightbringer's picture
Last seen: 1 hour 23 min ago
That’s the big donk with the XHP50.2?
mizou51
yes i just updated the thread with the specs
SerenityNow
Last seen: 11 hours 46 min ago
I like this light. Hope Sofirn comes through with the proper Amazon code. I want one!
Thanks much for the review. Looking forward to Part 2.
Lightbringer
I got a couple of the v1s, which I like. No v3 yet.
Sofirn
Sofirn's picture
Last seen: 13 min 29 sec ago
Thanks for your share this Sp33 V3.0 review
sparkyDK
Last seen: 12 hours 36 min ago
I need a new USB charge 26650 light for my car, this seem reasonable.
mizou51
YES ! that’s not too big and it can do 3500lm !
Also if you like the ANDURIL UI you will be satisfied
sparkyDK
Not familiar with that UI, probably way more complicated than i like,,,,,, i like it super simple my Q8 are almost too much for me.
cm64
Last seen: 2 hours 23 min ago
re Sp33 V3.0
Great flashlight – except for the switch.
freeme
freeme's picture
Last seen: 20 min 10 sec ago
Heh, these look familiar... cool
mizou51
cm64 wrote:
re Sp33 V3.0 Great flashlight – except for the switch.
why ?
mizou51
freeme wrote:
Heh, these look familiar… cool
yes my youtube channel videos about the C4 charger. Great one that I use every day since 2 years…still working perfectly
cm64
mizou51 wrote:
why ?
I find it very hard to click the switch for the right length of time to switch on & off.
I have to click a few times to switch on or off. (I have a BLF LT1 & it has a great switch – no problems clicking for multiple times)
maybe with time I will learn to use it Smile
Otherwise a great product.
