Ampsplus 16650 2500mAh (Black) 2020
Official specifications:
Ampsplus 16650 2500mAh Battery Protected
Battery Size: 16.60mm x 67.50mm
Nominal Voltage: 3.70V
Nominal Capacity: 2500mAh
Min. Rated Capacity: 2400mAh
Charging Method: CC/CV 4.20V~4.35V
Discharge Voltage: 3V (Average Cut Off)
Standard Charging Current CC: 1250mA
Fast Charging Current: 2500mA
Standard Charging Time: 4hrs
Continuous Discharge Current: 6A
Energy Density: 9.25Wh
Battery Rate: 2C
Weight: 41 gr. max
Version: Button
Protection / PCB: Yes , Protected
This is a protected 16650 LiIon battery
The two cells match nicely, but the capacity is nowhere near the rated 2500mAh, the cells are also very hard pressed at 5A load.
The missing capacity is due to it being a 4.35V cell used at 4.2V.
Conclusion
This cell is a fairly good 16650 protected cell, but do not expect the rated capacity.
Notes and links
The batteries was supplied by Ampsplus for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
