This is a high current 21700 cell with good capacity.
The two cells match nicely, but do not like a continuous 30A discharge (I only tried that on the first cell). The capacity donot change much with load.
Conclusion
This is a good high current cell, but 30A continuous is too much for the internal fuse.
Looks like a good battery, but strange it doesn’t hold up to the 30A continuous discharge that it states. I wonder how close it is though, like 25A, 28A, 29A?
Not really, many brands rates their cell to the limit or slightly above.
The original specification might have stated 30A continuous with cut-out at xx°C
Thank you, Richard. It’s what Vapcell advertises, and also what they told me, but I kind of doubt it. The cell is heavier and wider than the original 40T (74.8g vs 67g and 21.6mm vs 21mm) The inner wrap on the positive pole is black, while the 40T’s is white (apologies, I don’t know if it’s called an inner wrap or not). Personally, I feel like it’s a big brother of the Vapcell 3750mAh (Blue) 2018, which Henrik also tested. These 2 cells are very similar in diameter, weight and the colour of the inner wrap.
Blgg, I would respectfully disagree.The width could be different, at least in part, because Vapecell re-wraps them. This might account for some of the weight too. The Vapecell 3750 has a slightly different looking construction on the top. I think it is probably the same as the Golisi 3750 cell (notice how the different wraps give a very different look on the top when they are on). I don’t think either of those are Samsung’s or the same as this. The top of this cell looks like a 40T. The color difference on the top is due to the wrap not the cell itself. The different weight and discharge characteristics might be an indication of either a small manufacturing change or better lot of cells that Vapecell got a hold of. Vapecell has been very honest with what cells they use. I think the minor discrepancies between this cell and the 40T are not strong indicators that the cell is not a 40T. The similarities it does have with the 40T (which are greater than the differences) and Vapecell’s reputation are evidence which tilts the scales in favor of it being a 40T.
Checking for info about this battery and came across this message again.
I notice the “summary table information” indicates information for “Vapcell INR21700 3750mAh (blue) 2018” instead of the Vapcell 4000mAh 21700 (gold). Are the information correct or just a typo in the heading of the table info?
BTW, this Vapcell 4000mAh 21700 (Gold) is not the same as the Vapcell G40 4000mAh 21700 (white), which doesn’t appear to be tested by HKJ yet, right?
It is a typo in the header. I copy the header from another battery and then modify it and this time I forgot the title. The rest is correct, the title will also be correct when the caching has updated.
