[US Only] Sofrin SD05 reviewer needed!
13 posts / 0 new
Sofirn
Sofirn's picture
Last seen: 12 hours 48 min ago
Hello guys,
Sofirn upgrade SD05 diving flashlight. 2550 lm IPX8 waterproof level, up to underwater 100 meters. If you have the interest please leave a message, we will contact you soon!
caramba
caramba's picture
Last seen: 5 min 43 sec ago
A diving flashlight? I would be interested reviewing a Sofirn one.
Sofirn
Sofirn's picture
Ok! already contacted you. ===PM send, please check. Thanks.
caramba
caramba's picture
Thank you Sofirn
Yacob29
Last seen: 1 day 8 hours ago
I’d be interested if you still need people.
ch1ir
Last seen: 6 hours 3 min ago
Interested, sending p.m.
Emisar D⁴, Astrolux C8, BLF A6, Sofirn sp36aV2, Reylight Mini Pineapple, BLF 348 KillZone, Lumintop IYP07, Emisar D18, Boruit D10, Manker e01, Ultrafire z1, Massdrop titanium AAA, Astrolux HL01, Armytek Wizard Pro Nichia, Tacklife LFL3A, Astrolux FT03, Zanflair T1
Anthony Nguyenn
Anthony Nguyenn's picture
Last seen: 29 min 55 sec ago
Really interesting in this one. Unfortunately I do not have other diving flashlight to compare with atm. However, I can review it from a swimmer/flashaholic perspective. Thumbs Up Big Smile
YogibearAl
Last seen: 33 min 35 sec ago
Interested. Will it handle salt water?
Rhino707
Last seen: 6 hours 37 min ago
I would love to.
arek98
Last seen: 18 hours 46 min ago
Hi Sofirn,
New review would always be nice, especially if this is a new version without timed step down.
We have already seen that this is a very nice light but…
As questions here “Will it handle salt water?”, unfortunately answer is .. not for long!
It is good recreational/occasional diving light. It is not a light for often diving even to keep it as backup (electronic switch causes constant if low current flow thru body)
Why? Because salt water is an electrolyte and it will cause aluminum to corrode.
As long as anodizing is intact it is ok but when it is gone these spots will see corrosion (white build up first, then pitting). And dive light gets banged up a lot, there are going to be chips in anodizing rather sooner than later.
If you made internal tube to pass current from tail to the head it would make body only little thicker but it would be MUCH better light overall.
Look what Xtar is doing with their lights, they even use Delrin for battery part with internal metal tube.
Point is that durable diving light cannot have current flowing thru metal body!
With that this is VERY nice light, I have few of them, some converted to blue, just I don’t expect them to last long ☹
Edit: Ok, maybe corroded at some spots body will not cause light to stop working but still it would be nice to do it properly Smile
Sofirn
Sofirn's picture
Thanks for your suggestion, we already submit it to the technical department
the4ds9
the4ds9's picture
Last seen: 1 hour 35 min ago
I have compared this diving flashlight to the Fenix SD11 which costs twice as much. This flashlight is brighter and has a good hotspot. It can be used to spot crabs in crevices during a dive.
hank
hank's picture
Last seen: 5 hours 42 min ago
I have bought several SD03s, which I think close to ideal to share with neighbors during emergencies.
As we live in earthquake and wildfire country, very somple sturdy lights can be necessary.
I’d like to compare these to the SD05
