Broken Convoy Light
4 posts / 0 new
pirate joe 22
Last seen: 1 week 3 days ago
Broken Convoy Light
Has anybody ever dropped a Convoy S 11 on the ground and broken it ?
I have broken several Convoy S 2s by dropping them only 3-4 feet.
What breaks inside and how do I fix it ?
Tomogchi
Last seen: 11 hours 42 min ago
Sometimes the springs that touch the battery collapse from being dropped. And the battery cant make contact. Try putting a screwdriver from the – of the battery to the body of the flashlight. And see if it turns on. Streching the spring would fix it until the next drop
Also the switch could break internally (not likely but can happen). Test the same way. Battery – to body of flashlight.
Option 3 is some solder joint broke somewhere, and you might get lucky and be able to resolder the joint. It should be viewable (lifted from driver, or led pcb).
Also if the battery is protected, the fall could have damaged the circuit board on the battery. Swap with a known good battery (or test voltage if you have a volt meter).
There are other ways a flashlight could break, but these are what came to mind first.
It all started with just one flashlight.
MascaratumB
MascaratumB's picture
Last seen: 2 hours 31 min ago
3 questions:
a) When you mean “broken” what do you mean? It stops working? Does physically break in some way?
b) They are modded or stock flashlights?
c) Where did you bought them: from Convoy (Simon) or other store/seller?
Sometimes what happens is that it doesn’t break but it gets loose in someway. Other times, impact may cause some damage on components or provoke “shorts”
Some suggestions:
a) try to see if the retaining ring in the tailcap is loose or tightened, and if so, adjust it/screw it tight.
b) check the same thing with the retaining ring and/or the pill in the head. And the battery tube too, check if all the contacts are being made.
c) unscrew only the tailcap, leave the battery in and, using a conductive wire/pair of scissors/ tweezers, try to make it work by placing 1 contact in the battery negative and 1 contact in the non-anodized part of the tube. This will help you understand if the problem is on the tail or on the head.
d) if after doing this the flashlight doesn’t work, try to unscrew the pill, check if there is any contact between the reflector and the wires/solder on the Led PCB, as they may be some kind of short.
e) if nothing of this works, maybe it is a driver problem Oops
Hope it helps. Thumbs Up
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
NeutralFan
NeutralFan's picture
Last seen: 10 hours 8 min ago
Good advice MascaratumB! I can’t think of anything else to try. It seems it should be a mechanical problem, like a retainer ring not tight enough, since the driver and LED should withstand a lot of impact.
I’d rather use my flashlight around the house than turn on the lights.
