Brinyte SR8: a long-runtime thrower (4x18650), magnetic cable rechargeable, now discounted!
1 post / 0 new
tatasal
Last seen: 33 min 29 sec ago
Hi guys,
Brinyte has discussed with me this unique category flashlight….a thrower light (78mm HEAD) BUT with extra long runtime being a 4 × 18650 light…it also has a removable battery holder that can be recharged directly (w/o removing the 4 batteries) by using the USB cable to magnetic end OR you can remove the batteries and have it charged your way in your favorite charger!
Cree XHP35HI led is used.
Purchase link to the product: https://brinytestore.com/products/brinyte-sr8-rescue-angel-special-kit
(shipping of this heavy light is already included, btw)
Here you can see that the batteries can be removed from the holder for re-charging/replacing outboard the holder if desired.
TECHNICAL PARAMETERS
Beam Distance – 1050+m/1144+yds
Intensity – 270000+cd
Impact Resistant – 1m/1.09yds
Protection proof – IP68
Working Voltage – 5.5-8.4V
Dimensions: 217mm(Length) x 58mm(Body Dia) x 78mm(Head Dia)
Net Weight: 740g/26.10oz (excluding battery)
Edited by: tatasal on 06/30/2020 - 03:18
