Revive toast Ex11 v2. PD?
I found this old-school beauty in a drawer at home. One of my favourite lights ever :heart_eyes: but it is toast and have been in the drawer for several years now. I can’t remember exactly what happened with it but I recall something happened with the circuit board (?). In this modern world of high-tech lights I want to see if it is possible to go old-school again and revive it and make it my edc again. The Ex11’s and I have a special bond that go long back.
Do you think it is worth trying to revive? I am completely and 100% unable to try to fix it myself so i’m checking with you guys. Is there anyone out there (i’m in EU region) that thinks it’s worth a try and also willing and able to do so? I will of course compensate accordingly :slight_smile: Send me a PM if you think it’s possible to save my darling.
Thanks!
I used a 14mm E-Switch Mtn. FETDD driver with Moppydrv. UI (Mtn.Electronics D4 UI is on 17mm and up drivers) knocked off the nobly bits and filed it down to 12mm and piggy backed it onto the old EX11v2 driver board… it works flawlessly now!!! :+1:
I fit the board for a XM-L to the brass pill and flowed a 50.2 3v emitter, opened up the reflector to fit…
Added a cheap $1.50 SS clip and now it’s making 1800+ lumens…
BLF member Lexel is making 3x12mm Anduril drivers for the other EX11v2’s I have…
BLF member CRX would be the man to do the modding for you…
I guess KawiBoy1428’s suggestion for Lexel (driver) and CRX (mod) was spot on!
One thing you must be aware of is that these drivers will “only” work well with 16340 Li-Ion 3.7V batteries and not CR123a!
IF you want to use CR123
you can buy a replacement EX11.2 atm
sent you a PM also
Mine works fine with a CR123 just lower output…
Well, after saying what I wrote, I started thinking about that possibility too, as the CR123a is 3V and the driver LVP can go down from that!
Thanks for the input and correction :+1:
Yep :beer: … also the nice thing about Mtn.Drivers…. you can order No LVP… you can run down CR123 lithium to almost nothing if need be…like for vehicle/glove box lights, but it’s on you if your run Li-ion’s….
x2
could you please measure your andurilEX lowest lumen output on 16340?
With Anduril, I would keep the LVP and be happy not to use CR123. I prefer rechargeable cells.
So, if I wanted to have an Anduril 11.2 light, I would need a 14mm driver with Anduril from Lexel, and then? Piggy back it onto the original light PCB?
No 14mm is the stock driver size there abouts… you can take a 14mm and file it down to 12mm or a bit more to fit inside the pill. Lexel is making 12mm drivers… easy peasy just have to center the piggy backed driver to the old board so it fits inside the pill…
I have the 4” T/A Maukka Lumen Tube it will not read accurately at that low of a level… it says ZERO but looks to be about 2 Lumen…not as LOW as you like my man! :wink:
I am afraid I am still not quite clear on the process. So, I order a 12mm Anduril driver from lexel, and then use that in conjunction with the original board, after I remove the electronics or something like that? Would you be able to provide some explanatory pictures of the process please?
thanks
I get so many conflicting reports on the low modes on anduril… one guy says it goes sublumen, the next guy says it does not… :person_facepalming:
this post has a couple of photos
until KawiBoy1428 gets back from his nooner
Yep… you connect the piggy backed driver to the wiped old driver board… you need a meter/wiggy to find the trace location that suits best for the three connections to each other then just attach your leads from the piggy backed driver to your LED board… I have provided pics above…you can blow them up…I didn’t take step by step pics because I do this a lot… :smiley: But it is easy once you wipe the board out…and ring out the traces…
Here is a pic of a different light but the same mechanical e-switch driver as the 11v2 this is a LD-4 6amp linear e-switch driver to a NovaTac board…
On this driver board… the center trace is + the other 2 longer traces are Grnd - and the small blue trace at the far right…closes to the edge is the signal trace you connect (wire) to the piggy backed driver e-switch pad… you can see the only wire used was for the e-switch to signal trace… in the below pic…
The part I am not clear about is how to get from this…
… and a 12mm Anduril driver to this…
The old driver bare PCB and the new Anduril driver are in contact. How and what is connected in between them?
I am sorry if I am beinbg a pain and it is your right to keep your process secret if you choose to, of course :slight_smile:
Nope… no problem… the 2 are joined together by solder… the only wire I have to use is the signal trace wired to e-switch pad. I blob + and - on both and either use a big Iron or Hot Air to melt them together. So say for the top driver connection to the wiped contact board I blob both and from the battery side of the contact board I’ll use a heavy Iron and melt them together thru the battery side of the board using that trace or pad… the ground is easy… load up the tip of the Iron and melt to 2 previously blobbed points or solder bridge them together… the main thing is you have to plan, lay everything out, prep, check, then execute… that is the beauty of it… :+1:
I will take Three please :+1:
I had a dream that there is an Anduril swap for the AA Copper Tool, capable of running on Eneloop… then I woke up to ask you to build it :wink:
I think Anduril is e-switch only… isn’t it? The Tool is push button… so for push button ramping there is…
Crescendo Clicky Firmware (attiny25)
ToyKeeper has been at it again! Crescendo is an awesome clicky ramping firmware with thermal control, among many other awesome features.
I have one light using Crescendo…. the only one… reverse clicky is a must…IMHO
great info
where is the Buy it Now Button?
A CuTool AA with ramping is going to be Awesome!
I dont need the rest of the Anduril blinkies and whistles…
I see your point about needing eswitch on anduril and avoiding forward w Crescendo… the devil is in the details
Happy Interdependence Day! :partying_face:
I’m sure there will be a Tool Ti AA with Anduril one day… :wink:
