Vapcell INR18650 3000mAh K30 (Gold) 2020
Official specifications:
Model: K30 INR18650 3000mah 15A
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.5V
Typical Capacity: 3000mAh (0.2C discharge)
Min capacity: 2900mAh (0.2C discharge)
Weight: Max:48g
Internal resistance: Max:15mOhm AC 1kHz
Standard Charge: 1500mA,CCCV 100mA cut-off
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 15A
Max Discharge Current: 30A
A fairly high capacity 18650 battery that can deliver a decent amount of current.
The two batteries matches nicely, the battery is fairly constant it capacity with different loads, but it gets warm at high currents and I damaged one of the batteries at 30A.
Conclusion
This cell has a decent performance for the capacity and current.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
