Test/review of Charger Xtar X2
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 12 hours 56 min ago
Review Charger Xtar X2
DSC_3005
DSC_3006 DSC_3007
A two slot LiIon and NiMH charge with automatic current selection and both mains and USB power input.
DSC_2958 DSC_2959 DSC_2960 DSC_2961
The charger was in a cardboard with specifications on it.
DSC_3002
The box included the charger, a mains cable and a instruction sheet.
DSC_3008
The charger has input for both USB power and mains power input.
DSC_3011
There is a single button on the charger, it can be used to turn backlight on or restore backlight to full power.
DSC_3151
During power on all segments will be shown.
DSC_3150
No batteries in the charger.
DSC_3155
A LiIon and a NiMH battery.
DSC_3009
The charger has specifications on the back, with black text on black background.
DSC_3014 DSC_3016
The connection are the common slider style that can handle from 31.5mm to 77.3mm, this means all batteries will fit.
DSC_3012
The slots are marked with current, but the marking leaves out the 0.5A current that is used with short batteries.
supportedBatteryTypes
supportedBatterySizes DSC_3161 DSC_3162 DSC_3163
DSC_3164 DSC_3165 DSC_3166 DSC_3167 DSC_3168 DSC_3169 DSC_3170
The charge current is on the high side for 10440 batteries.
Measurements charger
  • A single long battery in slot #1 is charged with 2A
  • A single long battery in slot #2 is charged with 1A
  • When using both slow #1 & #2 the charge current is 1A on both.
  • When not powered it will discharge a LiIon battery with about than 3.5mA.
  • When powered the charge will charge with less than 1mA when finished.
  • Below 2V the battery is assumed to be NiMH, above LiIon.
  • Charger will restart if battery voltage drops below 3.9V.
  • Voltmeter has a minimum reading about 0.8V and will show that from about 0.3V
  • Voltmeter is within 0.04V
  • LiIon can be charged with 0.5, 1A or 2A.
  • NiMH is always charged with 0.5A
  • The display show 0.5A when charging NiMH, but the actual current is around 0.8A
  • Slots change charge current at 55mm length.
  • Background light goes to low brightness after 60 seconds.
  • USB input will supply some power when charger is mains powered, this is not very good.
  • Mains cable is 32mOhm for each wire, this is fine.
  • Power consumption from mains when idle is 0.42 Watt with backlight on full brightness an 0.25 Watt at low.
  • Power consumption from USB 5V is 45mA when idle full backlight and 24mA at low.
Charging LiIon
Xtar%20X2%20%28SA18650-33%29%20%231
A single LiIon battery in slot #1 is charged with 2A using a CC/CV profile, termination current is around 100mA
Display shows 3154mAh
Xtar%20X2%20%28SA18650-33%29%20%232
In slot #2 the charge current is 1A.
Display shows 3035mAh
Xtar%20X2%20%28SA18650-26%29%20%232
Display shows1950mAh
Xtar%20X2%20%28PA18650-31%29%20%232
Display shows 2599mAh
Xtar%20X2%20%28BE18650-26%29%20%232
Charging other LiIon batteries in slot #2 works nicely.
Xtar%20X2%20%28EF20700-30%29%20%231
A high current battery can be charged in slot #1.
Display shows 2902mAh
Xtar%20X2%20%28KP14500-08%29%20%231
A short LiIon battery can also be charged in slot #1, due to the shorted length the charger will use 0.5A charge current.
Display shows 572mAh
Xtar%20X2%20%282xSA18650-33%29
With two long batteries both slots are limited to 1A charge current.
Display shows 2927mAh 2942mAh
Xtar%20X2%20usb%20%282xSA18650-33%29
This is valid for both USB and mains power state.
Display shows 2926mah 3015mAh
Temp7671
M1: 37.9°C, M2: 38.0°C, M3: 41.2°C, HS1: 47.3°C
Temp7673
M1: 39.9°C, HS1: 43.6°C
PoweronLiIon
The charger needs about 6 seconds to turn on.
Unpowered%20voltage%20sweep%20%231
The charger will discharge a full LiIon battery with about 3.5mA.
Voltage%20Sweep%200-4.25V
Charge profile, the charger always start with a low current when voltage is below 2.7V.
Charge%20Solar%20LiIon
The charger cannot work with an unstable USB supply.
Charging NiMH
Xtar%20X2%20%28eneloop%29%20%231
The charger uses a good -dv/dt termination followed by a two hour top off charge.
Display shows 1989mAh
Xtar%20X2%20%28eneloop%29%20%232
The other slot is similar
Display shows 1834mAh
Xtar%20X2%20%28eneloopPro%29%20%231
The old pro cell get some capacity and terminates.
Display shows 380mAh
Xtar%20X2%20%28fujitsu%29%20%231
This high capacity cell is charged nicely.
Display shows 2399mAh
Xtar%20X2%20%28leise25%29%20%231
With the leise the termination is on the slow side, but it do terminate.
Display shows 2970mAh
Xtar%20X2%20%28eneloopAAA%29%20%231
The AAA cell is charged with the same current as the AA cells, here the 0.8A is a bit on the high side.
Display shows 715mAh
Xtar%20X2%20full%20%28eneloop%29%20%231
Due to the low current startup it takes the charger about 15 minutes to detect a full cell.
Display shows66mAh
Xtar%20X2%20%282xeneloop%29
Two cells are charged at the same speed as one.
Display shows 1858mAh 1878mAh
Xtar%20X2%20usb%20%282xeneloop%29
This also goes for USB.
Display shows 1880mAh 1840mAh
Temp7691
M1: 40.5°C, M2: 40.3°C, HS1: 50.2°C
PoweronNiMH
The charger uses the same time as for LiIon, before it starts on the precharge.
ChargingNiMH
As usual the NiMH charging is pulsing, this makes it possible to check the voltage with current off.
Top-Off-Charge
Top-off charge 1s at 1A every 20s or an average of 50mA.
Charge%20Solar%20NiMH
The charger handled unstable voltage considerable better with NiMH cells.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This charger works fine for both LiIon and NiMH, there are a few issues, but nothing serious.
I will rate it as a good charge.
Notes
The charger was supplied by a Xtar for review.
voip
Last seen: 4 weeks 15 hours ago
amazing review, thank you so much.
Blggg
Last seen: 1 hour 35 min ago
Brilliant work as always. One thing that I have been wondering about, Henrik, what if I pull out the battery which has been charged to a full 4.2V while it is still in a CV phrase. Like in the first graph of the 2A charge, the voltage has already roughly reached 4.2V since at 120 minute mark. Is that long CV phrase necessary?
HKJ
HKJ's picture
The battery voltage will drop a bit.
I have been testing different termination voltages and currents here: https://lygte-info.dk/info/batteryChargeTerminationTest%20UK.html
Blggg
Thank you very much.
Henk4U2
Henk4U2's picture
Last seen: 13 min 29 sec ago
Thanks for a fine review. Thorough as usual.
There is one thing I missed in the listing: XTAR calls it the 0V activation function.
I own an XTAR charger with that function and I must say it is very usefull (if needed). My Eagtac has a forward clicky and a mechanical lockout requires to loosen the tailcal untills it almost falls off. So there is a chance of accidental activation. My XTAR certainly saves the day on such an occasion. Of course the battery only returns to active duty after a firm shakedown in an analyzing charger.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Fox
Last seen: 3 days 13 hours ago
Nice looking charger.
Thanks for the review as always!
The most ugly place in the world! Surprised
