V10r Ti, Eye10 TiC, Jetbeam TCR-1
draft in progress
1. TCR-1
92 grams w 18350
22.7 mm head
no trit fin option
no tailswitch
dial has consistent texture, protrudes 1mm from the rest of the body
screw on clip
xml, reflector mod available to improve the beam with 219b
2. TiC
100 grams w 18350
23.3 mm
yes trit fins predrilled from factory 2x8mm
no tailswitch
dial has 3 knurled areas and 3 flat areas
screw on clip
3. V10r Ti
95 grams with 16340
22.8 mm
yes trit fins (aftermarket accessory drilled 1.5x6mm)
tailswitch (aftermarket trit button)
dial has consistent spaced texture and sits flush
no factory screw on clip
xpg, excellent bewam w 219b swap
Opinion
I like the TCR-1 overall hand feel the most, it is my first pick for EDC
I like the look and feel of the dial of the V10r Ti the most, I dont like to EDC a light with a button.
I like the trit fins of the TiC the most, its a bit fatter and heavier than the TCR-1, but the trit fins win the contest.
I very much like the Carbon Fiber section, it gives a good visual contrast to the head, so I always know which end Im putting my hand on.
With the TCR-1 I find it hard to visually locate which end is which.
The Sunwayman has good visual target distinction, the head is obviously different from the body, and I like the aesthetic
I like the TCR-1 control ring the least
I like the V10r Ti control ring the most
I like the extra phat body the TiC the least
