Skilhunt E3A (AAA twisty) - First Look
28 posts / 0 new
gchart
gchart's picture
Last seen: 2 hours 1 min ago
I bought the Skilhunt E3A in Slate Blue, Neutral from AliExpress as soon as it was announced. But while I’m waiting for that to arrive, I noticed some are being sold on Amazon (US) so I picked up a Carmine Red one to check it out. I just got it today, so I haven’t done a full teardown, output check, or runtime test so I’ll revisit once those are done.
What I received from Amazon was the cool white version – unfortunate, but means that I’ll probably be tearing this down to (1) see whats inside, and (2) see if the LED is replaceable. Everything looks and feels great. The anodizing is great. The TIR is lightly pebbled and quite floody.
AAA battery, AA battery, Skilhunt E3A, Olight i3E, Lumintop EDC01, Jetbeam Jet-u, Astrolux A01, Sofirn C01S
Anthony Nguyenn
Anthony Nguyenn's picture
Last seen: 15 min 47 sec ago
Thank you for great pictures I’m a big sucker for smaller lights. This E3A looks great as it is on the same size as Olight i3E. Beam pattern seems floody and nice spill.
Only thing I wish they would include a pocket clip. It looks like there are 2 positrons for the reversible clip.
Lumintop Tool AA 2.0 Nichia + CW| Lumintop Tool AAA | Lumintop EDC 18 6500k| Lumintop EDC 01| Convoy S2+ 7135*8 5000k | Convoy S2 UV Nichia |Massdrop Vega AA NW |BLF A6 NW | Nitecore Tube 2.0 | Sofirn SD 05 | Sofirn 01S 4000k| Klaurus G15 | Klarus HR1 Pro | Thrunite T10T v2 NW| Thrunite T1 Black + OD Green | Thrunite Ti3 CW+ NW| |Rovyvon A3x Nichia | Rovyvon A5x Cree | Rovyvon A23 Nichia | Wuben E19 Nichia | MecArmy SGN 6 | Wowtac BSS V4 | Wowtac W1 | Wowtac H01 | Ultratac A3N Nichia | Wurkkos FC11 |  Wurkkos WK30
Thrunite T2 |
gchart
gchart's picture
I couldn’t resist the urge. Had to get a glance at what’s inside.
Looks like a single board with the LED mounted on it. Board is glued to an aluminum pill. Real easy to take apart, the pill isn’t glued in.
Scallywag
Scallywag's picture
Last seen: 1 hour 34 min ago
Well, we’re certainly not reinventing the wheel here. The TIR seems nice, and having more options for AAA twisties is probably not a bad thing.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Unheard
Last seen: 8 hours 29 min ago
Can the bracket of the polarity protection be pulled out of the pill? Or will it break?
I have not realized that this light is as small as the i3E, if not smaller! Should get one.
gchart
gchart's picture
I’ll try again today. Didn’t have much time to play with it last night.
Agro
Agro's picture
Last seen: 1 day 21 hours ago
Dammit, I hoped for a real thermal path.
Thanks for the pics gchart!
gchart
gchart's picture
Ok guys… another quick teardown. As it turns out, there is NO GLUE. What I saw as glue was actually thermal paste between the board and the pill. The white clip can carefully be removed. After doing so, the board comes right off. That entire area that is covered in silkscreen is a big thermal area. So while this isn’t a MCPCB, it has a big thermal path right to the pill and is covered in thermal paste. For 100 lumens, that seems sufficient. LED swaps would be difficult though… perhaps with hot air reflow.
EDIT: looks like the IC is the tried and true PAM2803
The resistor says 043 (underlined). If I understand correctly, that would mean R043 = 0.043 Ohms. But for a PAM2803, that would mean a LED current of 2.2A which certainly isn’t right. If it were a 0.43 Ohm resistor, that would make sense… translating to an LED current of 220 mA.
MascaratumB
MascaratumB's picture
Last seen: 2 hours 4 min ago
Thanks for the “deconstruction” gchart! Seems like the original setup is made to “stay as it is” ! And with a nice led, I guess it is not bad at all Wink
Nice light! Thumbs Up
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3/ 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Unheard
Thanks a lot!
The i3E could be placed in the pan right on the contact pad to reflow the LED. I’d try the same here.
contactcr
Last seen: 43 sec ago
Unheard wrote:
Thanks a lot!
You could probably kapton tape the components on either side of the positive contact button too.
On a side note, the “Red” in the above pictures doesn’t look anything like the promotional pictures.
TeeJayEDC
Last seen: 2 days 2 hours ago
Hey gchart, is that the real color Red? Look more like tan/brown to me. The color does not look like Red on their Amazon listing or website.
Anw nice color options though.
gchart
gchart's picture
Sorry, I messed with my camera settings in my initial images and I’m colorblind so I have no idea how accurate the colors are.
Here’s one I just took. Outdoors (obviously) under a direct noon sun sitting next to some ripe tomatoes. Default image settings on my Pixel 3. How’s this look?
I hope I never lose this one in the grass because I’ll never be able to find it Tired
TeeJayEDC
Facepalm Evil Evil Evil Thumbs Up
Hmm…. Hats off for your skills. I have no words. Such a sexy photo. Hahaha
contactcr
much better, initial pictures were favoring a burnt orange color
Unheard
You will. If you own a C01R.
@contactcr, I need to get this tape anyway Thumbs Up
gchart
gchart's picture
Interesting… the deep red light of the C01R would help a colorblind person distinguish between red and green?
EasyB
Last seen: 1 hour 7 min ago
gchart wrote:
EDIT: looks like the IC might be the tried and true PAM2803
Thanks for the interesting teardown.
Just curious, do you think that boost converter could be used with a UV-C LED with ~6V Vf? I could not find a Vout max in the datasheet.
Unheard
The grass won’t reflect much light as opposed to the flashlight. No color vision needed.
Edit: Tried it. The theory was good at least Big Smile Facepalm
gchart
gchart's picture
Good question. It looks like the ratings top out at 6V. As long as you don’t go over 6V it might work.
The posts at this link seem to think the same: https://electronics.stackexchange.com/questions/340226/driving-two-leds-...
iamlucky13
Last seen: 5 min 33 sec ago
So it didn’t really work?
I would have hoped for a result similar to in this test with an artificially colored surface:
http://budgetlightforum.com/comment/1677320#comment-1677320
Notice in the normal photo which squares on the toy are red and which are green, then compare how those squares appear in the photo lit by the C01R.
flightless22
flightless22's picture
Last seen: 1 hour 17 min ago
Very interesting light, the knurling is a nice change of pace. Thanks for the tear down.
LH351B is a peculiar choice though. Shocked
Unheard
Cactus vs. red C01 (same anodization as C01R): undecided. The cactus reflected a lot of red light, the red flashlight reflected surprisingly little red light.
patmurris
patmurris's picture
Last seen: 6 hours 17 min ago
Real tiny AAA twisty!
I just ordered one slate blue NW from AE to see how it goes. 8.65 euros shipped looks like a good deal.
Thanks for pointing it out.
gchart
gchart's picture
Look what arrived today! The Slate with a neutral LED. Quite nice.
contactcr
Mine comes today from Amazon. Curious if the TIR opening is big enough for a larger LED but I assume it’s the same dimensions as Sofirn one with tiny opening.
Will probably try to reflow whole board with components in place later tonight
contactcr
Stock Cool White is 102 lumens, just under 6000K CCT and above BBL. Looks mostly white but a slight light blue hue to beam. Not my taste but I didn’t really care cause it was getting removed no matter what.
The anodizing and machining is excellent, definitely the best i’ve seen on an AAA light ever. One thing I dont like is the threads are stiff. It’s very hard to operate one handed. Since it only has one mode maybe it’s OK. It seems like it uses the same TIRs you can find on the Yaji aliexpress store but I didn’t confirm this yet.
Mod time, liberal use of kapton tape just to keep stuff from falling off:
Fail #1: Try to channel heat through brass button. Nothing bad happened but I gave up when the heater was around 215-220. Not sure if heat path wasn’t good or if they used lead free.
Fail #2: (not pictured) try to use soldering iron on brass button from the bottom. Duh, brass button wants to come off instantly, had to re-center it after it slid.
Success: Preheat from the bottom, used the hemostats to keep it in place and keep everything pressed on the brass button and then I used hot air from the top. I dont think I ruined the LED but it definitely took more heat than I expected.
I ended up slicing a LH351*C* 4000K 90 CRI. Since it was sliced it already had some 60/40 solder on it and I put a liberal amount of flux paste between the old Skilhunt solder and my 60/40 tinned and sliced LED. It went on much easier. I’m not certain the original solder on the pad fully melted but at the very least it’s flowed on top of their solder if not completely re-flowed. Oh well it’s <250 mA and I’ll redo it if it fails.
Now it’s >90 CRI and 63.5lm – bigger drop in output than I thought but it makes sense going to NW+sliced+high CRI
gchart
gchart's picture
Geesh, 0.0000 DUV?!
Really glad it worked for you. Helps gives me some confidence that I might be able to do the same. I’ve got a boat load of Luxeon V2 in 4000K and 5000K that I got for a song. I might switch in a 4000K and try playing with the current set resistor to get a lower output (for use as a reading light).
