What brands and which models of flashlights fit my needs?
4 posts / 0 new
rogue2020
Last seen: 2 days 3 hours ago
Hi everyone,
I would like to ask your suggestions and recommendations for flashlights which can fit the following requirements:
1. Able to sustain 1500 – 2000+ lumens (high mode)
2. Light throw distance of 300 – 400+ meters for around 1.5 hours to 2 hours (in high mode).
3. Single battery or multiple battery setup.
The practical use for this light would be for night-time hiking or camping trips that could flood the area with reasonable amount of illumination without having to change batteries after every hour or so.
For now, I’m thinking AstroLux FT03 SST40W, but I understand its High mode won’t last for long.
Any other suggestions would be most welcome.
Many Thanks & Regards… rogue2020
Edited by: rogue2020 on 07/28/2020 - 23:41
Scallywag
Scallywag's picture
Last seen: 14 hours 27 min ago
You’ve pretty much limited yourself to multi-battery lights. This is for two reasons: such high outputs require a large light to be able to sustain the output without overheating, and the power requirements of such high sustained outputs exceed the capacity of single cells (even the larger 21700s and 26650s).
For example, the Zebralight sc700d (reviewed here ) is one of the most efficient lights in the single-cell format, due to its driver technology and the emitter chosen. As you can see from the graphs in the review, output at 3000>1800 lumens (step=down due to temperature) does not last a full hour.
Also, the throw requirement combined with the lumen output requirement will necessitate a larger light. The most efficient combination would probably be XHP35-Hi to achieve “1500-2000” lumens as well as the require throw, but you’ll be looking at ~1.25A at 12V to achieve that, which will again drain single cells in about an hour. More efficient for lumens per watt gets XHP50/70, but then you need larger optics for the same throw…
A good option might be the Astrolux MF02. Other lights like Convoy L2/L6, Sofirn SP70 come to mind. If the throw is sufficient, you could try the multi-cell multi-emitter “soda can” lights like the BLF Q8, Sofirn SP36, Emisar D18, etc.
Edit: forgot to address the SBT90.2. I would avoid it for this purpose: it’s less efficient than other options at the lumens you’re talking about, and it’s a $40 emitter so you’ll be spending that much extra on the light to begin with.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Lightbringer
Lightbringer's picture
Last seen: 28 min 59 sec ago
Wellp, if you want “long distance throw” and the mutually-exclusive being able to “flood the area”, you’ll likely have to choose one or the other.
jojosupir
jojosupir's picture
Last seen: 3 days 5 hours ago
Try reading review of convoy 4×18
