Test/review of Vapcell INR16340 850mAh T8 (Cyan) 2020
8 posts / 0 new
HKJ
HKJ's picture
Last seen: 12 hours 18 min ago
DSC_3077
Official specifications:
  • Model: INR16340 850mah 3A (RCR123A)
  • Size: 16.4*34.0mm
  • Type: button top
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 850mAh (0.2C discharge)
  • Min capacity: 820mAh (0.2C discharge)
  • Weight: Max:20g
  • Internal resistance: Max:65m? ?AC 1kHz?
  • Standard Charge: 500mA,CCCV 50mA cut-off
  • Quick Charge Current:1000mA
  • Max Continuous Discharge Current: 3A
Vapcell%20INR16340%20850mAh%20T8%20(Cyan)%202020-info
A 16340 LiIon cell with up to 4.2V
DSC_3075 DSC_3076
DSC_3078 DSC_3079
DSC_3080
DSC_3081
DSC_3082
Vapcell%20INR16340%20850mAh%20T8%20(Cyan)%202020-Capacity
The two cells are not perfect matches. The easily handles 1A.
Vapcell%20INR16340%20850mAh%20T8%20(Cyan)%202020-CapacityTimeHours
Vapcell%20INR16340%20850mAh%20T8%20(Cyan)%202020-Energy
Vapcell%20INR16340%20850mAh%20T8%20(Cyan)%202020-PowerLoadTime
Vapcell%20INR16340%20850mAh%20T8%20(Cyan)%202020-TripCurrent
Vapcell%20INR16340%20850mAh%20T8%20(Cyan)%202020-Charge
Discharge-Vapcell%20INR16340%20850mAh%20T8%20%28Cyan%29%202020-pulse-0.2%2010%2010-IR
Conclusion
The cell has very good capacity for the size, at least for current at 1A or lower.
With the cells not perfectly matches and unprotected it is best to use the one at a time and not in series.
Notes and links
This cell has the same size as CR123 cells, but is not a direct replacement (See here for more information)
The batteries was supplied by Vapcell for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
thefreeman
Last seen: 1 hour 36 min ago
Thanks for the test, so it’s better than the Vapcell 800mAh up to 2A.
MascaratumB
MascaratumB's picture
Last seen: 6 hours 52 min ago
It will give you more juice, but less current !
At 1A, it is better than the white cells, but at 2A…not so much!
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3/ 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
thefreeman
MascaratumB wrote:
[ It will give you more juice, but less current ! At 1A, it is better than the white cells, but at 2A…not so much!
You mean in direct drive ? I meant at 2A constant current, with a nearly discharged cell current will start to reduce a bit sooner, 100 mAh sooner at worst, aside from that, current will be the same.
Superstocker
Superstocker's picture
Last seen: 3 hours 54 min ago
Thanks HKJ! Very impressive capacity for the its size at 1A and less. Much appreciated.
SKV89
Last seen: 30 min 38 sec ago
Another great option for 16340 lights. Thanks HKJ!
d_t_a
Last seen: 1 hour 50 min ago
Thanks for the test, HKJ!
Just wondering, the “date” in the info box indicates “5-2019” — does this mean it’s already more than 1 year old?
Just sharing test results of some just newly-bought Vapcell batteries (16340 white, 16340 purple, 14500 gold) with SkyRC MC3000, discharge at 0.25A down to 2.50v and got the following results:
HKJ
HKJ's picture
No, it means I made a typo. It is fixed now.
