Who to ask? I want to swap main kitchen florescent to high CRI LED strips
4 posts / 0 new
radg
Last seen: 1 week 4 days ago
I’ve been looking into swapping my main overhead kitchen lighting to LED strips or tubes. Willing to spend ~$300-750 but can spend more for much better results.
It is this recessed box style. 9× 4ft fixtures. 21-23,000 lumens @85-90 CRI, 6500k. Mix of GE & Philips higher quality tubes.
They are flickering; I am assuming some of the ballasts are bad. I want to replace them with a comparable or better LED setup.
I looked into it last year, and I think Waveform & Yuji were the recommendations. I am familiar with Virence here & e21a/optisolis. I know a bit about emitters & quality. I understand CRI & r9 numbers. I don’t 100% understand bbl graphs or d50/d65 ratings. I know tint/binning is very important & often not shared with consumers.
Any recommendations on where to ask this, or point to someone who has done this? I am not familiar with the types of florescent ballasts used, or how to swap from florescent fixtures to LED strips. I am assuming it is not too hard. I know Matthias Wandel & Big Clive on youtube have talked about & use them in smaller environments.
Any idea if heat is an issue? (If using strips in an enclosed space like the box lighting). They need to run at 100% for 4-8+ hours. I don’t know what kind of heat sinking would be necessary.
Any idea if tubes vs strips has pros/cons? Strips seem better – they are probably available in more variations, different emitter/m numbers, and it seems more logical to use a designed setup of ballast + strip rather than retrofitted adapter tube.
Thank you. Here are some old links I had bookmarked. Some apparently lead to optisolis/nichia/osram/sunlike flex strips.
https://www.rollitup.org/t/waveform-leds-d50-99cri-strips.982099/
https://www.ledrise.eu/led-strips-modules/led-strips.html
https://www.holectron.com/products/?id=155
https://store.waveformlighting.com/collections/t5-t8-led-tube
https://store.yujiintl.com/collections/high-cri-white-led-strips
pennzy
pennzy's picture
Last seen: 9 hours 11 min ago
I can tell you what I did. I removed the ballasts and wired the sockets on one end per the wiring diagram. The sockets on the other side are out of the circuit with this style set up. Very easy to rewire. One side black, one side white. Push in connectors. I found tubes of various temperatures online. About $12 a piece if I remember correctly. Probably can find high CRI. I didn’t look. Very happy with the electric bill since converting the entire house to LED.
Vegas LED Fan
Last seen: 2 weeks 7 hours ago
There sure is one hell of a premium on the price for high CRI LEDs. I never was much concerned about getting anything near perfect for the CRI. I’m much more of a fan of natural light rather than trying to mimic an incandescent bulb except in a bathroom.
I converted two ceiling lamps in my kitchen several years ago. I used LED strips in one that originally held four 8’ fluorescent bulbs. I converted them to 12V by using 12VDC strips and a 120VAC to 12VDC converter. With the strips separated by a couple of inches it never gets hot enough to be a concern. I mounted them on choroplast (corrugated plastic) for hanging in the fixture. This does not work on a circuit with a dimmer but I could have installed a remote controlled dimmer in the circuit if needed.
I used the same system but bar lamp strips for a smaller lamp that used two U-shaped fluorescent tubes. I don’t do photography in my kitchen so whatever CRI these are works for me. It probably cost me $25 for converting the larger light and under $20 for the smaller light.
Some of the products you showed come with an aluminum base that serves as a heat sink. The wider strips with the LEDs in the center line are never going to get hot enough to be a problem.
radg
Bump, thanks for the idea about single-ended sockets for the tubes
