[UPDATED M4D deal] Manker “EDC Muscle Combo – BLF Limited”
637 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 17 hours 44 min ago
UPDATED Aug 8 2020
Hello my dear friends!
Manker allowed me to collect a list for a special groupbuy:
Many people contacted them and me to restart the cooperation and Manker decided to create a special set for the BLF members.
The final name was decided to be “EDC Muscle Combo – BLF Limited” to make the Set unique (i try to get updated pictures)
-> This is a one time only groupbuy and this Set will not be offered later or be available from other shops
Below you find the updated rules and whats in the box!
Rules:
  • please check the Set that Manker offers for the community below
    (i linked to their shop for detailed product specs)
  • last night we reached 75 participants so Manker changed the price to 69.95 USD
  • If you want to purchase for the price:
    just leave your contact email in the form at the end!
  • You will receive a email confirming you are on the waiting list
    (please give it a few minutes and check your spam before entering a second time)
  • the list is open until Aug 20 2020 - then i send the email with the purchase information.
  • the orders need to be placed between Aug 21 to Aug 30 2020
  • Manker then produces the exact amount of sets and adds a unique Serial Number
  • shipping is expected to start week 1 or 2 in September
  • dates and times are CEST Wink
  • more information can be added when needed
the Set contains of (one each):
Manker MC13 (HEAD only)
Ultra-Throw Flashlight – Multi LED Option
PLUS:
Manker E14 III (HEAD only)
4000 Lumens 4x Samsung LH351D
Mini EDC Pocket LED Flashlight
PLUS:
18350 Tube for Manker MC13/ E14 III
PLUS:
18650 Tube for Manker MC13/ E14 III
* Price: 69.95 USD
* a new package box for this special combo
optional (10USD):
a Manker 1100 mAh 18350 + a 3100mAh 18650 battery
INTERESTED?
JOIN THE GROUPBUY!
 all new deals are also posted here: deals.m4dm4x.com
if you do not find what you are looking for :
ask MARTIN@M4DM4X.COM - i will save you money!
Edited by: M4D M4X on 08/04/2020 - 07:23
M4D M4X
M4D M4X's picture
MC13 pictures:
Product Description
Features
- LED Option1: OSRAM KW CULNM1.TG LED (white light)
                      Max. 950 lumens output, Max. 760meters beam distance
- LED Option2: OSRAM KP CSLNM1.F1 LED (green light)
                      Max. 1200 lumens output, Max. 858meters beam distance
- LED Option3: OSRAM KR CSLNM1.23 LED (red light)
                      Max. 260 lumens output, Max. 450meters beam distance
- LED Option4: OSRAM KY CSLNM1.FY LED (Yellow light)
                      Max. 350 lumens output, Max. 506meters beam distance
- LED Option5: OSRAM KB CSLNM1.14 LED (blue light)
                      Max. 115 lumens output, Max. 640meters beam distance
- Powered by 1x 3.7V 1100mAh high drain protected 18350 li-ion battery with Type-C USB port (Included)
- Working Voltage: 2.8-4.3V
- Driver: Most efficiency constant current circuit (Non-PWM)
- With advanced intelligent temperature regulation module,MC13 regulates its output and adapts to the ambient environment,maintaining optimal performance
- Anti-reverse battery protection & overdischarge protection
- Pocket Size, Compact, lightweight
- One-handed, one-button for easy and fast operation
- Lockout mode prevents accidental activation
- Moonlight Mode: Multiple user selectable levels
- Low battery voltage indicated & battery charging indicated
- Material: aircraft-grade aluminum body
                stainless steel button cap
- Surface Treatment: Premium type-III hard-anodized anti-abrasive finish
- Clip: Stainless steel deep carry clip
- Lens: Toughened ultra-clear glass lens with anti-reflective coating + high temperature resistant optics TIR Lens
- Tail stand capability
- IPX-8 waterproof standard (2 meters under water)
- Impact resistance: 1 meters
- Size: 90.75mm(3.57") length x 41.7mm(1.64") head dia. x 25.8mm(1.01") body dia.
- Weight: 108.6g(3.83 oz) w/o battery, 136.7g(4.82 oz) w/ battery
- Accessory: 18350 li-ion battery x1, type-C USB charging cable x1, lanyard x1, spare o-ring x1, Manual x1
Output/runtime (White light)
Moonlight:                    0.5 lumens     82 hours
Low                             120 lumens      4 hours 05 minutes
Middle                          240 lumens     1 hours 47 minutes
High                            450 lumens                  45 minutes
Turbo                          950 lumens                  35 minutes
Strobe                         950 lumens      -
Peak beam intensity: 144,000 cd
Maximum beam distance: 760 meters
Waterproof standard: IPX-8,2M
Output/runtime (Green light)
Low                             45 lumens   11 hours
Middle                        190 lumens    3 hours 11 minutes
High                           520 lumens                53 minutes
Turbo                        1200 lumens               47 minutes
Strobe                       1200 lumens   -
Peak beam intensity: 184,041 cd
Maximum beam distance: 868 meters
Output/runtime (Red light)
Low                            60 lumens   25 hours
Middle                         90 lumens    2 hours 03 minutes
High                          152 lumens                57 minutes
Turbo                        260 lumens                53 minutes
Strobe                       260 lumens    -
Peak beam intensity: 50,625 cd
Maximum beam distance: 450 meters
Output/runtime (Yellow light)
Low                              50 lumens  14 hours
Middle                         120 lumens  3 hours
High                            240 lumens             57 minutes
Turbo                          350 lumens             54 minutes
Strobe                         350 lumens   -
Peak beam intensity: 6,000 cd
Maximum beam distance: 155 meters
Output/runtime (Blue light)
Low                              10 lumens   11 hours 30 minutes
Middle                          23 lumens     2 hours 35 minutes
High                             50 lumens                57 minutes
Turbo                          115 lumens               50 minutes
Strobe                         115 lumens    -
Peak beam intensity: 102,400 cd
Maximum beam distance: 640 meters
M4D M4X
M4D M4X's picture
E14 III
Product Description
Features
- Emitter: 4x Samsung LH351D (Cool White: 6500K, Neutral White: 4000K CRI>90)
- Maximum output: 4,000 lumens
- Maximum beam intensity: 6,000cd
- Maximum beam distance: 155meters
- With advanced intelligent temperature regulation module, E14 III regulates its output and adapts to the ambient environment, maintaining optimal performance
                copper heat sink
- Lens: Toughened ultra-clear glass lens with anti-reflective coating + high temperature resistant Carclo® optics TIR lens
- Install one removable silica gel light filter plastic sheet (green glow gadget)
- Size: 71.2mm(2.8") length x 28mm(1.1") head dia. x 25.8mm(1.01") body dia.
- Weight: 82.8g(2.92oz) w/o battery,109g(3.84oz) w/ battery
- Accessory: 18350 li-ion battery x1, type-C USB charging cable x1,spare o-ring x1, lanyard x1, Manual x1
Output/runtime
Moonlight:           0.5 lumens       82hours
Low:                   180 lumens        4hours 39minutes
Middle:               400 lumens         1hour  34minutes
High:                1000 lumens         1hour  15minutes
Turbo:              4000 lumens                    55minutes
Strobe:             4000 lumens            -
Anthony Nguyenn
Anthony Nguyenn's picture
Last seen: 5 hours 30 min ago
Done. Thank you Max & Manker. This deal finally happened. Thumbs Up
Lumintop Tool AA 2.0 Nichia + CW| Lumintop Tool AAA | Lumintop EDC 18 6500k| Lumintop EDC 01| Convoy S2+ 7135*8 5000k | Convoy S2 UV Nichia |Massdrop Vega AA NW |BLF A6 NW | Nitecore Tube 2.0 | Sofirn SD 05 | Sofirn 01S 4000k| Klaurus G15 | Klarus HR1 Pro | Thrunite T10T v2 NW| Thrunite T1 Black + OD Green | Thrunite Ti3 CW+ NW| |Rovyvon A3x Nichia | Rovyvon A5x Cree | Rovyvon A23 Nichia | Wuben E19 Nichia | MecArmy SGN 6 | Wowtac BSS V4 | Wowtac W1 | Wowtac H01 | Ultratac A3N Nichia | Wurkkos FC11 |  Wurkkos WK30
Thrunite T2 |
shirnask
shirnask's picture
Last seen: 27 min 30 sec ago
Thanks, signed up
SKV89
Last seen: 3 hours 7 min ago
Awesome. Been waiting for this! Both look like fantastic lights!
Edit: I just realized the MC13 uses the CULNM1.TG Oslon Boost HL!!!! It’s the first stock flashlight to use this emitter!
id30209
id30209's picture
Last seen: 15 min 54 sec ago
At last! Signed and ready for payment
WTB Titanium 4sevens 2xAA tube
takumi86
Last seen: 1 week 3 days ago
i signed up as well!
d_t_a
Last seen: 44 min 8 sec ago
Just curious, what’s the difference of the CULNM1.TG with other Osram/Oslon LEDs (eg. compared to the Osram NM1 or PM1)?
will34
will34's picture
Last seen: 2 hours 48 sec ago
Signed up, but for the batteries would it be possible to buy just the 18350?
varbos
Last seen: 2 weeks 2 days ago
Seems like a good deal, congrats
weklund
weklund's picture
Last seen: 2 weeks 5 days ago
Nice … signed up … Smile
... Happy Landings ...
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 25 min ago
Wow, interesting. I didn’t expect to ever see another Manker group buy on BLF. Maybe it means the issues of the past are finally healing? That would be cool.
I’m a little confused about something though. Why is there a BLF logo on the lights if BLF wasn’t involved in designing them? Is there something different about these?
Skylight
Skylight's picture
Last seen: 1 day 15 hours ago
Will Manker sell this BLF combo also at their Aliexpress store?
MascaratumB
MascaratumB's picture
Last seen: 10 min 38 sec ago
Precisely my question!!
What is the BLF on this sale?
Is it a way for Manker to be more BLF friendly?
Or was someone from BLF involved in the design of these lights?
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior / OW Mini // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R / E61 // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review’s Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
lukehale
Last seen: 10 hours 14 min ago
It looks like BLF is only on the versions in this “combo” deal and not on the individual lights for sale. So maybe it’s intended to be just a special “BLF group buy” edition and that’s why? It doesn’t appear they are tying to claim the lights themselves are BLF designs since it’s just on the group buy images. I could be wrong, of course. It certainly would not be ok with me if they just threw BLF on there as a sales tactic on all the lights.
freeme
freeme's picture
Last seen: 17 hours 58 min ago
This is NO BLF Special Edition flashlight ...
pinkpanda3310
pinkpanda3310's picture
Last seen: 3 days 10 hours ago
I really want an E14iii but also want to see a review first.
SKV89
http://budgetlightforum.com/node/71301
will34
will34's picture
That clears things up, however being the CULPM1 I suppose it could be driven harder than 950lm?
id30209
id30209's picture
Another bump...
Need this package!
varbos
It says BLF Special Edition because it is a package deal negotiated by Martin on request of BLF users.
LumenLucas
Last seen: 4 days 15 hours ago
Interested and signed up!
id30209
id30209's picture
That is what i’m thinking and i like it!
Every deal negotiated with BLF members should carry BLF tag if you ask me.
Mankerlight
Mankerlight's picture
Last seen: 5 days 8 hours ago
  we did got many requests from BLF members, so that's why this happen.
Mail:sales@mankerlight.com
Web: www.mankerlight.com
Welcome to join Mankerlight Group in Facebook.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 hours 15 min ago
Mankerlight, can you please tell us at what driver temperature MC13 and E14 III will step down? Thank you!
Mankerlight
interesting, I think many BLFer know there were some manufacturers copy our design and even copy our manuals.
Mankerlight
 55
Mankerlight
 won't
Lux-Perpetua
Mankerlight wrote:
 won't
That means we will order directly from www.mankerlight.com or is there any 3rd party involved?
sarge12
Last seen: 2 weeks 6 days ago
Done
