ASTROLUX FT03 Mini NM.1
OSRAM Colored NEW USB-C 18650/ 18350 Flashlight
For reference, this is my order timeline for our Group Buy(1st batch).
Note: speed of delivery varies from country to country.
Group Buy Price: from $29.99!!!
Emitter: OSRAM NM.1
Brightness: 510 lumens
Beam Color: White/ Red/ Orange/ Green(brightest)/ Blue
Body color: Black / Blue / Green
Battery Type: 1* 18650 / 18350
Can't wait for our reply??
FLASH SALE Price: $32.99
Valid till: BGFMSS
WE NEED More SUBSCRIBERS!
www.youtube.com/embed/yn0VdISzIA0
Specification:
Brand & Model: | Astrolux FT03 MINI |
Material: | Aluminum alloy |
Emitter Type: | NM1 |
Light temperature: | White Red Orange Blue Green |
Output: | 510 Lumens |
Distance: | 860 Meters |
Beam intensity: | 185,000 CD |
Driver: | Texas Avenger FET Driver with charging |
Battery: | 1x 18650 (not included) unprotected 18650 recommended, and must use unprotected 18350 battery. |
USB Rechargeable: | Yes, Type-C (USB-C) Quick Charge |
Reflector: | High quality smooth reflector |
Lens: | Glass with anti-reflective coating |
Body: | Aerospace grade aluminium alloy |
Button: | Silicone rubber |
Impact Resistant: | 1.5 Meters |
Waterproof: | Equivalent to IPX7, do not immerse in liquids |
Body Color: | Blue / Green / Black |
Weight: | Approximately 136g without cells |
Size: | with 18650 tube: 144.8mm* 43.5mm* 25.5 mm (length* head diameter* body diameter) with 18350 tube: 113.7mm* 43.5mm* 25.5 mm (length* head diameter* body diameter) |
Package included: |
1x Flashlight Head 1x 18650 body tube 1x 18350 body tube 2 x Spare Waterproof O-rings1 x Lanyard 1 x User Manual
Operation UI:
Operate | Current Status | |
OFF | ON | |
Single click | Low | 1. Not at Turbo now: gear cycle (Low - medium1 - medium2 - high, then return to low and continue the cycle to high) |
2. At Turbo now, it will: return to the gear before the turbo | ||
Long press | Moon | Off |
Double click | Turbo | 1. Not strobe now, will go to: Turbo |
2. If strobe now, will go to: Quick flash-SOS - Candle flash (and cycle) | ||
Triple click | to Strobe | to Strobe |
Four click | Report voltage | No reaction |
Five click | 1.If locked state now, will go to: Unlocked | 1.If locked state now, will go to: Unlocked |
2. If standby state now, will go to: Lock | 2. If standby state now, will go to: Lock | |
Six click | Tactical lighting mode (this will be cancelled after power off) |
No reaction |
