As we know, by increasing battery systems’ energy density and reducing battery cells’ number, it can realize cost reduction. Among cylindrical Li-ion batteries, there is upgrading from 18650 to 21700/26650 for higher capacity.
Some surveys show that 21700 battery may be just a transition between 18650 and 26650 batteries, even though 21700 is the trend now.
From 18650 to 21700 and even 26650, it aims at improving batteries’ capacity on the basis of reducing the size of the device. The 26650 batteries typically deliver around 5000mAh, some brand even promote 13800mAh, which will work for much longer than 21700 and 18650 batteries. Just imagine that, a heavy torch with 2x18650 batteries and a handful torch with only one 26650 battery, which is preferred?
You know what I’m talking about. You don’t want the torch provides insufficient illumination, or runs out of power when you need it most, especially in camping, diving or a survival situation. The lack of power can threaten your safety.
There are already some 26650 flashlights in the market, such as XTAR D26 1600 dive light. With one XTAR 26650 5200mAh battery, it can reach max 1600 lumens output, working more than 2 hours.
What batteries do you use in your flashlights? Do you think 26650 batteries will be the trend in future?
Personally I’ve never been near those 21000 series battery’s.
Mine are mostly 70% 18650. 5 or 6% small ones, and 35ish %
26650. A mix of 4600/5000/5200.Cap.
The 26650 are that much more comfortable
I don’t know why anybody other than tiny hand persons
would even think of the 21000 series.
I’d love to see 26650 staying alive. This allows for a classical form factor fitting my hand perfectly. Would like to see more flahlights using those cells.
I like all of the forms to be honest, it`s a bit like AA, C and D cells really, there isn`t one really better than the other overall until you narrow it down to a specific quality that you value over others.
I would like to see protection circuits for 26650`s being readily available though, my D cell incans would love that!
At this moment, a vast majority of cells is produced for the automotive market.
A small part gets into the flashlight market or is used for vaping.
The most used format in the automotive market was the good old 18650 LiION cell.
Apart from being a transition (to non-cylindrical blocks) Tesla wanted to improve energy density.
Their top models used to have about 8,000 of the existing 18650 cells.
But also wanted to hold on to the existing setup of large numbers of round cells, spot welded together.
Special attention was given to the matter of heat shed. Initially they had an eye on the 20700 format.
After a few calculations a seemingly last minute decision was made to opt for the 21700 format.
My personal opinion is that the leading car manutacturers will hold on to the existing cylindrical cells.
At least until a big transition can/will be made to another chemical composition of the cell(s).
Even if the energy density of the 26650 can be improved, it won’t a winner because of bad heat shed.
And nobody in their right mind will invest in serious improvements for such a small market.
I am really liking the 21700 cell torches and my last 5 torches have been in the 21700 format. IMO the diameter of the flashlights using the 21700 cells are perfect for holding where the 26650’s can be to large in diameter. They hold more energy and produce more amps. It hard to beat the 30T and 40T in performance right now, I see a long future for flashlights using the 21700 cells.
The 21700, because flashlight technology is growing fast and an 18650 can not produce the capabilities to keep up with power and amp demands. My new 20V DeWalt use the same Samsung 21700 cells and as everyone my have noticed there are a lot of flashlights coming out in the 21700 format, Tesla vehicles use them as well. They will be around for a long time to come.
I think 21700 cell was made for improved surface area for cooling while charging in car battery pack.
They did a lot of research and 21700 was right now the best size for cooling, capicity and costs.
26650 batteries’ development seems to be in a stall, because no new notable releases I have seen recently.
One battery with ~5700mAh and 20A sustained current, and that is all.
The most recent batteries are now with better power and energy density in the 21700 format.
Personally, I would be happy to see 26650 batteries in the future, but for that, new development would be necessary.
Trying to extrapolate performance weightwise, I guess, there should be already e.g. 6500mAh 20A and 5500mAh 30A and 4200mAh 40A batteries, but development is nowhere near.
You are right in some way, there were not stated, but battery chemistries, which are considered fully charged at 4.2V were compared (IMR, INR, NCR, etc.)
Regarding IFR (briefly at ~3.6V, when fully charged), the 26650 batteries are much better than their smaller format siblings.
For some applications, they are the best without question, but most of the recent flashlight designs cannot do their best with IFR batteries (maybe this could be also changed).
EDIT: I just overlooked, that you mention IMR, then it is hard to believe. Can you show me that one? (Please keep in mind, that some ridiculous “pulse” current ratings cannot be taken into consideration - the ratings should work from 100% to fully discharged state /while battery remains in the safe temperature range/, that is why they are continuous ratings.)
I haven’t checked for a while, but last time I did, I couldn’t purchase a 26650 from a reliable brand like Panasonic, Samsung, Sanyo, or LG. Xtar, Efest, Vapcell, EVVA, Golisi, Nitecore, etc. might manufacture (or re-wrap) some great batteries. That was one bad sign for me.
Secondly, 26650s are harder to get than 18650s. They’re just not as widely used or sold, and maybe manufactured. 21700s are now easier to find and buy than 26650s.
Once Tesla started using 21700, and I could get the same capacity in that format, I decided to get off the 26650 train. I still like the ones I have, but 21700 is a better, probably safer choice for me.
