OTR i3 project [was: Need advice: Thermal paste between pill and body?]
15 posts / 0 new
Unheard
Unheard's picture
Last seen: 58 min 17 sec ago
Anyone tried to apply thermal paste to a pill?
I ask since this would be a one-way action for the OTR i3 due to the design of the pill (a reflector is screwed onto the pill, and the assembly can only be removed by grasping the reflector, which would unscrew from the main part, leaving it in the body).
Background: My i3 got a new driver, currently drawing 2.7A from a Nitecore NL166, but I plan to use a higher discharge, higher capacity Vapcell, so likely current will increase.
Theory pro thermal paste: There should be lots of air cushions between body and pill that could be filled.
Theory contra thermal paste: There’s enough surface left which makes good contact.
So, an experiment is needed, and maybe some of you already did this and know if heat dissipation can be improved.
Opinions are welcome, too.
Edited by: Unheard on 09/16/2020 - 08:37
Barkuti
Barkuti's picture
Last seen: 2 hours 10 min ago
I've applied some thermal paste a few times just for the sake of it. Can't provide measurements. There should be some improvement, but I think it's going to be quite small, and I mean rather quite small.
Some investigation would be of help, but needs some careful set-up, though.
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
Henk4U2
Henk4U2's picture
Last seen: 56 sec ago
You’re right, the middle of the threads wil make good contact.
But because of tolerances there will be air gaps at the top and bottom of the threads.
I don’t know if you gain a lot, but I think it won’t hurt to apply some thermal paste.
Downside, if that hardens (cures) it will be more work to get the pill out again.
So use thermal paste that stays soft and mushy.
PS, I don’t use thermal paste but I clean the threads very thorough after removing the pill.
That way I hope radiation will compensate for part of the missing contact area.
When assembling the light I re-apply some lubricant on the (outside) threads of the tube.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Unheard
Unheard's picture
Ok, Gentleman, thanks!
I’ll do it. Will measure and report back, but takes sometime until I have a proper cell.
contactcr
Last seen: 21 min 48 sec ago
I tried it once and it was too messy. Would not do it again personally.
If you ever have to adjust or remove the pill paste will get places you don’t want, even places where ground contact might be made. Nightmare to clean and requires a ton to “fill gaps” in something like threads. Dont bother.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 22 min ago
I tried it Once.. 6 years ago… Facepalm
KB1428 “Live Life WOT
moderator007
moderator007's picture
Last seen: 3 hours 11 min ago
The 502b had a poor heat dissipation design. You might look there to find a few different ways people tried to improve it.
http://budgetlightforum.com/node/8062
From some of the test on here I have sen about adding thermal paste, it seems when to much is added it doesn’t help that much.
A thin layer was tested as the best, in this situation for fill it should help but I would guess to say not alot.
Unheard
Unheard's picture
Not good?
Unheard
Unheard's picture
Ok Thumbs Up
Unheard
Unheard's picture
contactcr wrote:
If you ever have to adjust or remove the pill […]
Won’t – can’t. Difficult enough w/o the paste. But I had already in mind that it likely will be a mess.
Unheard
Unheard's picture
First impression of temperature regulation of Crescendo:
Will repeat with new cell.
Very rough lumen estimation: max. 900lm
Unheard
Unheard's picture
I messed it up. Ordered a 1×2mm Osram since I wasn’t aware the 2mm^2 LEDs are not square Facepalm
Also, it is not centered. Had no fitting gasket, and it is really difficult to do it this way.
But: It sucks 3,9 amps out of that old NL166 now and makes 51560 cd / 454 m.
Of course, the beam is full of artifacts. Looks terrible.
contactcr
The result looks fine to be honest, you can black out some stuff to clean up the artifacts and call it a day. On the much larger Z821 I was not able to break 7x kcd so your result looks good on paper. I tried a 1mm2 NM1 and the result was single digit throw increase, for sure not worth it and ultimately went back to 2mm2 LED.
Unheard
Unheard's picture
I’ll keep the LED Thumbs Up
Unheard
Unheard's picture
Sorry if there’s an obvious answer: Any way to switch off temperature regulation except just adjusting temperature in Crescendo (where it gets as hot as possible)?
And one remark on the performance in the wilderness ( Big Smile ): Breathtakening. Never thought a zoomie could be that impressive.
